Well that was an easy dash cam install.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flipnidaho, Feb 1, 2020.
  1. Feb 4, 2020 at 12:24 AM
    #41
    sgmstr
    sgmstr Well-Known Member
    Thanks I'll be sure to look out for that.
  2. Feb 4, 2020 at 11:25 PM
    #42
    FourWD
    FourWD Well-Known Member
    19 Tacoma DCSB OR TRD
    crunchytaco13, yub, pokey1416 and 2 others like this.
  3. Feb 4, 2020 at 11:27 PM
    #43
    FourWD
    Theres no problem when driving the car, the issue is turning the car on from parking then it would overheat. But the video was uploaded in Aug 2019 so they might updated their hardware now, not sure.
  4. Feb 6, 2020 at 9:20 PM
    #44
    smk87
    smk87 Well-Known Member
    So did it work out the way you expected?
  5. Feb 6, 2020 at 9:30 PM
    #45
    Bobcat Luke
    Bobcat Luke IT
    Austin, TX
    2020 Cement TRD Sport DCSB
    Why tf would they remove it
    deanf likes this.
  6. Feb 6, 2020 at 11:18 PM
    #46
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    No idea but most likely it was a deal that go pro paid them for and they stopped paying
    deanf likes this.
  7. Feb 6, 2020 at 11:24 PM
    #47
    Fishnwiz
    Bill
    Yes, works great, I used a garmin gps sync cable and my 45w dash cam displays a this cable will not charge this device notice but it has stayed fully charged for 3 days now. From what I can decipher from their website it will charge it just not as fast
  8. Feb 7, 2020 at 8:02 AM
    #48
    Tarvis
    Tarvis Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
    Not too familiar with dash cams, but my worry has always been that I will forget to turn them on. Is there a way to get them to power on automatically when you turn the truck on, and turn off when the truck turns off? How does storage of the recording work? Is it looping and writing over the existing footage so that you don't have to constantly delete data to make room?
    DES2009 likes this.
  9. Feb 7, 2020 at 12:58 PM
    #49
    Fishnwiz
    Bill
    My only experience is with garmin 45w. It comes on when you start the truck and goes off when you shut down. It has a mini card in it. If I remember right it records 4 hours and then overwrites. Has a button you can push to save what’s there and auto saves on any impact.
    MrCball likes this.
  10. Feb 7, 2020 at 2:35 PM
    #50
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Anybody use the SimpleUSB adapter with a Garmin Dash Cam 56?
    Fishnwiz likes this.
  11. Feb 7, 2020 at 2:38 PM
    #51
    flipnidaho
    flipnidaho [OP] Well-Known Member
    2001 Tacoma Double Cab TRD
    The Garmin Mini Dash Cam automatically turns on and off with the ignition (I'm not sure how other dash cams work but I have to imagine they all work in a similar way). The recording loops but there is a button that allows you to save the current footage so it's not overwritten. It's pretty much set and forget.
  12. Feb 7, 2020 at 5:41 PM
    #52
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Just ordered this harness and a Rexing V1-4K dash cam. Thanks for posting. Should be a super clean, set and forget install.
  13. Feb 7, 2020 at 5:51 PM
    #53
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Nice I have the 45 as well and I'll be looking to see if this works for what I want
  14. Feb 7, 2020 at 5:53 PM
    #54
    Fishnwiz
    Bill
    So far so good, staying charged and I downloaded video to make sure it was working. I will look for a charge cable it will recognize
  15. Feb 7, 2020 at 6:02 PM
    #55
    smk87
    Is the dimmer function working on the mirror...lol
    Fishnwiz[QUOTED] likes this.
  16. Feb 7, 2020 at 6:06 PM
    #56
    Fishnwiz
    Bill
    Yes, the harness plugs into mirror and the mirror plugs plugs into it, just has a USB port added
  17. Feb 8, 2020 at 3:45 AM
    #57
    DES2009
    Southeast Louisiana
    2017 MGM Limited
  18. Feb 8, 2020 at 4:04 AM
    #58
    CassND
    CassND Well-Known Member
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    Is it fairly easy to get SD card out while camera is behind the mirror or do you need to take the camera down?
    Thank you.
  19. Feb 8, 2020 at 4:21 AM
    #59
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
  20. Feb 8, 2020 at 4:49 AM
    #60
    Fishnwiz
    Bill
