Went to get an alignment yesterday, bad news!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cotruckin, Aug 19, 2011.
  1. Aug 19, 2011 at 8:08 AM
    cotruckin
    cotruckin [OP] Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    So I went to Firestone yesterday to get my alignment done after putting my Built Right uni-ball control arms on and this is what the guy had to show me. The bolt is seized inside the lower control arm and one of the tabs on the arm that allow for proper alignment was bent. I let there and went to the dealer to see what they would say. The service writer said I would most likely have to replace the lower control arm in order to get the bolt out. What do you guys thinks, anyone had this issue yet? Anyone looking to sell a passenger side lower control arm?
  2. Aug 19, 2011 at 8:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yep, it's quite common issue.
  3. Aug 19, 2011 at 8:10 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    how would replacing a LCA fix a seized bolt?
  4. Aug 19, 2011 at 8:14 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Dam man that sucks just buy a and cut the nut off and tap the bolt out. Buy the TC alignment gussets & a new bolt and weld them on you don't need to replace the LCA that's the dealer trying to get more money from you. If you do all of this yourself you could fix it for under 100 bucks 250 if you don't have a welder and call a mobile welder to come burn it in for you.
  5. Aug 19, 2011 at 8:30 AM
    cotruckin
    Westminster, CO.
    Lifted 06 TRD Sport
    Does anyone have a write up on this? I am looking into the TC alignment gussets right now.
  6. Aug 19, 2011 at 8:35 AM
    JLee
    Jerry
    Benicia, CA
    I don't think so but I just welded some on for a member a few weeks ago and there easy to install. Take off on the other hand not so much. TC has instructions with the gussets but you need a welder because they come in a bunch of pieces.
  7. Aug 19, 2011 at 8:40 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Cover it in panther piss and give it hell, It'll budge, mine was sized too, I just turned into the hulk and moved it out the way. As far as the tab... heat it up and bend it back into place?
  8. Aug 19, 2011 at 8:42 AM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Do a search for username TacoBow and thread title LCA bashing press
  9. Aug 19, 2011 at 8:50 AM
    cotruckin
    Westminster, CO.
    Lifted 06 TRD Sport
  10. Aug 19, 2011 at 9:11 AM
    prerunner32
    prerunner32 TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Cause the only way to get it of is to put enough force on it till it snaps. then your stuck with a broken bold seized in the LCA
  11. Aug 19, 2011 at 9:14 AM
    JLee
    Jerry
    Benicia, CA
    That is not the only way to get it out cut the nut off and a BFH with get that thing out.
  12. Aug 19, 2011 at 3:07 PM
    afatgoat
    afatgoat New Member
    Max
    FSJ
    2010 stock 4L tacoma
    You could get that out with a blowtorch punch and hammer no problem.
