Went to Start and Lost Power
Discussion in '1st Gen. Tacomas (1995-2004)' started by LSUdude, Aug 7, 2022.
  1. Aug 7, 2022 at 11:30 AM
    LSUdude
    LSUdude [OP] Active Member
    1999 Tacoma trd
    99 Taco 4wd 3.6
    Went to the woods this morning. Got back and went to restart to go to the dump and pushed in clutch and turned key to start and lost all power.
    Hooked to my Tundra to see if battery had lost power but am thinking fuse or battery fault.
    Any idea where to start and main fuses to check?
  2. Aug 7, 2022 at 11:32 AM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    No lights or anything?
    id start at battery terminals, make sure they’re tight. Then the under hood fuse box.
  3. Aug 7, 2022 at 11:39 AM
    LSUdude
    1999 Tacoma trd
    No lights or anything.
    Checked terminals and all is tight.
    Bout to start troubleshooting with meter
  4. Aug 7, 2022 at 12:28 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner
    Ha this just happened to me!
    did you hear one fast click then everything went dead? I pulled the terminals cleaned everything really good tightened back down. Also unplugged the starter solenoid connector and plugged back in.
    Check your voltage on the posts, check to fuse box. Check to starter. Mine fired right up after reconnecting the starter connector. Thinking the solenoid is binding causing something to flip.
  5. Aug 7, 2022 at 2:51 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Did you just check if there terminals were tight? I've had tight clean looking terminals that were corroded, a quick clean and everything was good.
    Check grounds and fuses.
  6. Aug 7, 2022 at 3:54 PM
    LSUdude
    1999 Tacoma trd
    Lol this was it!
    Crazy huh
    KdF and stftaco like this.
  7. Aug 7, 2022 at 4:05 PM
    noodles93
    Charleston, SC
    Did you replace the starter or just disconnect/reconnect everything?
    Crazy how it can kill all the electronics in the truck... must be some self-resetting breaker somewhere.
  8. Aug 7, 2022 at 4:06 PM
    LSUdude
    1999 Tacoma trd
    Disconnected, cleaned and then relanded.
    Never would have thought that but did hear the one click thing and thought something was seriously messed up
  9. Aug 7, 2022 at 4:36 PM
    noodles93
    Charleston, SC
    If it happens again let me know. Going to be running new electrical cables soon and was thinking of replacing the starter while at it... just to be safe.
