Wet carpet, floor drain?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Jun 14, 2014.
  1. Jun 14, 2014 at 12:46 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    So a couple of weeks ago I had posted a forum about wet carpet in my truck.
    Today when I was installing new xtra cab window latches, I decided to pull up the carpet and I found that the source of the water was most likely from a rubber piece covering a hole that goes out of the truck... Since there was water around that gasket/ rubber thing What would be the best way of fixing it?
  2. Jun 14, 2014 at 1:12 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  3. Jun 14, 2014 at 1:17 PM
    Tjsingle26
    Tom
    PA
    Well, its not my AC, cause the passenger side is dry as a bone. The firewall grommet area looks fine. And the water is centralized around that drain, it gets drier towards where the wires are coming from the firewall. I guess just use silicon and seal it, let the carpets dry out too?
  4. Jun 14, 2014 at 1:20 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Seems weird for water to come up through the floor grommet, unless you park in deep puddles.
    I ran a dehumidifier in my truck for a few hours to dry the carpet when it got wet. Just lifted it with a block so air could get to the underside.
  5. Jun 14, 2014 at 1:24 PM
    Tjsingle26
    Tom
    PA
    Yeah thats true, it is possible that the carpet just keeps getting wet and then staying wet. I mean pulled off the grommet to see if was messed up and it looked fine. The frame is right there so really how much water can get up there? Idk, Ill let it dry out though
  6. Jun 14, 2014 at 1:41 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    The other place that sometimes lets water in is the door seal. It will run down the channel and onto the floor where it will pool.
    Pull the carpet up, run a garden hose around the door and see if you can see water creeping in.
  7. Jun 14, 2014 at 1:48 PM
    Tjsingle26
    Tom
    PA
    I noticed that some water, not a whole lot was creeping in when i did that
  8. Jun 14, 2014 at 1:53 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Doesn't take a lot for the carpet to get soaked, especially if it rains for a day or two.
  9. Jun 14, 2014 at 1:55 PM
    Tjsingle26
    Tom
    PA
    Well thank you for your help, Ill let it dry out for a while
  10. Jun 14, 2014 at 1:55 PM
    samsquamch1981
    samsquamch1981 Well-Known Member
    Tacoma
    the best way to seal the grommets is atv/silicone sealant. I know you already figured out the water source, but just answering the question about fixing a leaky grommet.
  11. Jun 14, 2014 at 1:58 PM
    Tjsingle26
    Tom
    PA
    I still will seal the floor grommet to be sure, and the firewall one as well. It has been raining a lot lately, and another thing was for a long time I have had rubber mats and any moisture will get trapped under there.I am not entirely sure about the door leak, but I think its very possible
  12. Jun 19, 2014 at 5:26 PM
    Tjsingle26
    Tom
    PA
    UPDATE:
    I found the leak, it was raining and i found that the grommet to the fire all actually did leak! Sealed with silicone.
    Thanks for the help guys
  13. Jun 19, 2014 at 5:29 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    NICE-glad you FIXED IT!!!!
  14. Jun 20, 2014 at 9:21 AM
    samsquamch1981
    Tacoma
    good to hear....i hate any issue dealing with water, leaks, pipes, toilets....a huge pita....but i'm glad you solved the mystery.
  15. Jun 20, 2014 at 10:52 AM
    Tjsingle26
    Tom
    PA
    Yeah seriously, I found a pinch weld was leaking too, so all those are getting sealed too, did the drivers side already
