wet carpet
Discussion in '1st Gen. Tacomas (1995-2004)' started by steve, Nov 14, 2006.
  1. Nov 14, 2006 at 3:08 PM
    steve
    steve [OP] New Member
    Have a 2001 tacoma that has a water leak , carpet on drivers side rear floor is wet. Is this a common problem with these trucks? thanks
  2. Nov 19, 2006 at 5:49 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Does it rain a lot in your area? If so check the weatherstrip around the doors.
  3. Nov 19, 2006 at 11:52 AM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    check on condensation in your truck. the leak probably drips down to your carpet. hope this helps.
    ldytaco05
  4. Nov 29, 2006 at 6:31 AM
    avettese
    avettese Member
    I've had the same problem but on the passengers side of the truck, didn't relize the problem for months after it was new. Still haven't find it the source yet. It's a 1999 TRD.
  5. Dec 16, 2006 at 7:19 PM
    Cracker
    Cracker New Member
    There is a TSB for 97-00's for water leaks coming from the cowl and/or side seams on the firewall.
    It also mentions to check the water barrier behind the door panels.
    Mine was ripped open, from the dealer techs who jury rigged the broken window track, so I bought some 3.5mil (IIRC) plastic drop cloth from Wallyworld. It seems about the same thickness, and is clear just like the OEM.
    I just traced the old one onto a new piece, and ran a bead of windshield adhesive (the gooey black stuff) around the outside of it. Looks just like OEM.
  6. Jan 12, 2007 at 5:52 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i was having a prob with water too it was leaking from the top of the windsheild
  7. Jun 23, 2008 at 4:45 PM
    edave5
    edave5 Active Member
    San Bernardino, CA
    '02 PreRunner, 3RZ, Reg-Cab
    3" body lift; 3" suspension;added power windows, locks, and mirrors; bucket seats; regeared to 4.56
    yes, i'm having a problem with evaporator condensation. for some reason, it is not draining, and when i make a turn i can hear a sizzling-like sound and freezing cold water will sometimes soak my shoe. mostly it splills out on hard left turns and soaks the passenger side carpet. i'm guessing the line that goes through the firewall from the drain pan is blocked, might want to check that out if you're having a similar problem.
  8. Jun 23, 2008 at 4:58 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Get underneath the truck and locate the rubber drainplug for that area-it could be missing.
  9. Jun 23, 2008 at 5:01 PM
    edave5
    San Bernardino, CA
    There is no drain plug. It's just a hose that goes through the firewall. The drain pan is holding water, so even if there is a plug, it's still there, because it's spilling over the top when i make turns. (read my whole post)
  10. Jun 23, 2008 at 5:11 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Sorry buddy I was answering the ORIGIONAL post in this thread. Why dont you kik off a fresh thread for your problem?:)
  11. Jun 23, 2008 at 5:15 PM
    edave5
    San Bernardino, CA
    yeah that might be a good idea
  12. Jun 23, 2008 at 8:01 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    i have a double cab 2001 tacoma and on the back wall of the truck at the bottom corners there are 2 rubber plugs that i had takin out to run my cb wires through the hole and my rear carpet would get wet everytime it would rain and i never could figure it out until the day i took the cb wires out and put the plugs back in
    may want to check and see if the plugs are still in there.
