Wet Okole Seat cover liability.........
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Aug 29, 2010.
  1. Aug 29, 2010 at 3:23 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    So i really want and need some new wet okole seat covers for my 2010. I do have side airbags in the seat, but i have a few concerns. I want to order the covers without the ugly slit in the side, but I am worrried about the liability. I talked to professionals and one said the airbag would punch right through and the other said it wouldn't. So I need your opinions. Thanks
  2. Aug 29, 2010 at 3:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    i believe they have a good reason for putting the slit in the sides, so I would get them
  3. Aug 29, 2010 at 3:34 PM
    fiestee23
    fiestee23 Well-Known Member
    Theresa
    SoCal
    05 prerunner SR5
    6" ProComp lift w/coilovers, 35" ProComp A/T tires, Volant Intake, MagnaFlow Exhaust, Pioneer In-dash Navigation, NFAB tube steps, 6500 lb tow package, POP n LOCK tailgate lock, Air lift Bags, and MORE.....
    x2
  4. Aug 29, 2010 at 3:42 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    The slit doesn't bother me at all. I'd just be safe and get it.
  5. Aug 29, 2010 at 3:56 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Get the gosh darn slits man ...... when fitted properly the "slits" are not seen, as the sides overlap one another. There is no way that the bags would burst through .... these things are bullet proof.
    Here are my SR5 seats with airbags, pictures don't lie (otherwise I would be 20 pounds lighter):
  6. Aug 29, 2010 at 3:57 PM
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    yep enough said. safety > cosmetics
  7. Aug 29, 2010 at 4:00 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    I had the same concern when I got the Toyota TRD covers. I went ahead and got them... looks like the majority of the seat sides are still exposed so I'm not too worried about it. I'm not sure exactly how the Wet Okole's are put together, but on mine if I wanted to I could cut the stiching in a few areas just enough for the cover to still hold together but would come apart if the bags were deployed. If your really concerned with a liabilitly issue you might want to play it safe and get the right ones though.
  8. Aug 29, 2010 at 6:32 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Those look killer. I dont know why but I have just seen alot that dont look as good as those
  9. Aug 29, 2010 at 6:33 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Pics??
  10. Aug 29, 2010 at 6:34 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    How hard are they to install. Yea I have basic tools and knowledge, but I am only 18.
  11. Aug 29, 2010 at 6:38 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    You can't even tell the slits are there. As far as install, simple. Best thing to do is pull the seats though, it will make it a ton easier on you. One hour tops if you pull the seats out...
  12. Aug 29, 2010 at 8:00 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    See well it seems that in general the ones without the slit fit better. I was just wondering. But I do see where your coming from, there is a purpose for the slit. Maybe I will get some small patches of velcro and stich them in there
  13. Aug 29, 2010 at 8:13 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I wouldn't want to take the change of somone getting hurt or killed in my truck because of something so trivial as how my seat covers look.
  14. Aug 30, 2010 at 1:47 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    The slits aren't even that noticable. I wouldn't worry too much about them at all look wise. Get the slits
  15. Aug 30, 2010 at 2:54 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    To OP .... this should be an non-issue brother ..... take a 2nd look at pictures posted ... including mine.
    Do you think that if the airbag would deploy through the seat side WO would go to the trouble of making the slit.
    Listen to the masses my friend ---- don't "mod" this ..... we are here to help.
  16. Aug 30, 2010 at 2:56 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Thanks for the comps .... I am a little anal ... took serious time installing them.
  17. Aug 30, 2010 at 4:23 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    ^ What he said. I just had my Wet Okole's installed last week with the airbag slits and it looks perfectly fine. You and your passenger's safety is definitely more important than worrying about a small slit in your seatcover...
  18. Aug 30, 2010 at 4:26 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Alright thanks I really appreciate your input. Thanks
  19. Aug 30, 2010 at 8:08 PM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I have a 2010 DC Pre-Runner - took it to the Wet Okole shop in Costa Mesa, Ca. They told me if the truck has seat side air bags, they have to do the slit. Something about a permit. I guess you could get around it if you wanted to, but why. I couldnt even tell there was a slit there - they fit like a glove. - Man, they are the best! A little on the pricey side, but for the durability and looks - it is worth the investment. I got the center console cover as well. Love them - get compliments all the time - Black with charcoal, no piping. with the white TRD and red lettering. I looked at the dealership TRD covers - not even a close second.
