Wet Okoles on a 2012 AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owl, Jun 13, 2012.
  1. Jun 13, 2012 at 4:43 PM
    Owl
    Owl [OP] Active Member
    Eric
    Asheville, North Carolina
    '12 AC 4x4 2.7L 5spd
    My Wet Okoles finally arrived today, more than a month after I placed the order, but I get it, they're custom made. Problem is they don't fit that great and the stitching looks like it was done by an amateur. I only ordered the front, but they are bulky and bunch up around the seat controls. They just seem like they're too big for the seats overall. Anyone else have that issue?
    thanks in advance
  2. Jun 13, 2012 at 6:39 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Wow, thanks for informing! I wanna order for my '12 AC soon but hopefully it was just a defective one you received. I would try calling them.
  3. Jun 13, 2012 at 7:04 PM
    Owl
    Eric
    I did call and they said it would be 'OK'. I don't want OK for $300, I want a glove, and this isn't a glove-type fit. I'm wondering if the seats changed for 2012 and they're using 2011 measurements?
    I actually just went through something similar with Weathertech floor mats. They make them for an 2012 automatic but not a manual. A local shop said they'd be fine and ordered them, but the fit like shit. The shop said it was normal and that in a few weeks once they got warm they'd mold to the floor. Bullshit.
  4. Jun 13, 2012 at 7:32 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    Might check that you didnt mix up the drivers and passenger side covers. I did that at first and they fit alot better once swapped them.
    I also had to remove the seats and do alot of tucking in to get them to fit just right, but im pleased with them overall.
  5. Jun 13, 2012 at 7:41 PM
    Owl
    Eric
    They were kind enough to label the driver seat with a tag. Also, both the driver seat and passenger seat fit baggy.
  6. Jun 13, 2012 at 7:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I think Weathertech intends for you to trim the mat around the clutch pedal. At least that's the case with the floorliners.
  7. Jun 13, 2012 at 7:45 PM
    KenLyns
    Belly of the Beast
    Wonder if they sent you TRD seat covers by mistake?
  8. Jun 13, 2012 at 7:53 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    Sounds like a mistake to me too, they should fit fairly tight. Youll have to call them, prolly more than once, to get that fixed tho.
  9. Jun 13, 2012 at 7:55 PM
    Owl
    Eric
    That's a possibility. I'm going to call them tomorrow. As for the Weathertechs, they didn't fit flush near the door sills, everywhere else they seemed OK. But clearly not made for my floor wells.
  10. Jun 13, 2012 at 7:58 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  11. Jun 13, 2012 at 8:42 PM
    Owl
    Eric
    I'll try to grab some pics tomorrow.
  12. Jun 14, 2012 at 3:43 AM
    MSU Spartan
    MSU Spartan Well-Known Member
    Mid Michigan
    '12 Double Cab TRD Sport 4x4
    Did the floormat retaining holes line up? If they then did, then they should be for the right model. My passenger side didn't sit correctly around the door sill at first, but corrected itself within a couple of days. Drivers side fit perfectly.
  13. Jun 14, 2012 at 7:01 AM
    Owl
    Eric
    The holes were close, but pulled at the posts in the carpet that holds them in place. I was worried they'd pull the posts out of the carpet. I called Weathertech and they confirmed that they don't fit my truck and don't currently make a set that does. However, they have a request form on their website, so I suppose if enough people ask, they'll make them.
  14. Jun 14, 2012 at 5:25 PM
    Owl
    Eric
    My pics suck - you're just gonna have to take my word that the fit blows on these.
    For those of you who have Wet Okoles and are happy with them, do the seat fronts fit tight against the seats, or is there space between them and the Tacoma seats? Mine aren't tight against the seats and I feel like they should be. I had Tacoma seat covers on my '08 and they were pretty damn good.
  15. Jun 14, 2012 at 6:16 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Mine started out like yours. These pics both look like the bottom of the seats, try pulling them further back. The fit really tight under the back of the seat and I had to pull hard on mine to tighten them down. The spot that doesn't look good on the bottoms is around the lumbar support knob. This area definitely could have been better. The cut out looks to be a half inch to an inch too far forward. Other than that both covers fit very well. Just had to really pull them to back of the seat.
    The only things that are baggy are the inside of the head rest covers. Might switch them around tomorrow and see if that changes anything. I also put the straps that run front/back over the bar for seat adjustment. It helped tighten them up and doesn't interfere with the bar.
  16. Jun 14, 2012 at 11:11 PM
    Owl
    Eric
    Thanks for posting that, Hartford. Maybe I'm just being too picky?
  17. Jun 15, 2012 at 2:21 AM
    DMS
    DMS Well-Known Member
    HI
    '11 MGM DCSB TRD Sport
    Owl and Hartford...It looks like you guys have the seat bottom covers installed incorrectly. The covers should be tucked behind the plastic trim piece on the side of the seat bottoms, and not over them. Take a look at my post #535 on this thread: http://www.tacomaworld.com/forum/gr...up-buy-sept-27-2011-thru-oct-9-2011-a-27.html
    That's at least part of the reason the covers look so sloppy. Tuck them behind the plastic piece and I think you'll be much happier.
  18. Jun 15, 2012 at 5:04 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    sorry to thread jack but will the WO from my 2011 trd sport fit my 2012 sport?
  19. Jun 15, 2012 at 5:31 AM
    MTL Tacoma
    MTL Tacoma Well-Known Member
    Montreal, Canada
    2016 DC LB TRD Sport
    X2 - its a PITA to do but it will look/fit much better
  20. Jun 15, 2012 at 6:47 AM
    Duke
    Duke Active Member
    Denver
    '12 TRD Sport Access Cab
    Haven't ordered wet Okole's yet but I can confirm that the weathertech's do fit weird at first. Ordered a set for my 2012 AC and my girlfriends '02 4runner and it took a little while for them to relax and sit snug against parts of the floor.
    Also if you have a manual you may have to notch the mats where the clutch goes in. Mine kept snagging on the clutch pedal every time I shifted. I pushed the pedal in by hand and notched around it and haven't had a problem with them since.
