Wet Sanding.. Uneven ClearCoat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 9, 2011.
  1. May 9, 2011 at 1:27 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    Hello all
    So I got a pretty deep scratch in my tailgate. It is a metallic gray finish. So I used touchup paint and filled the scratch, applied 3 coats and let it cure 24 hours. I then wet sanded the area with 2000 grit and the problem is I did it by hand. Did not use a block so I ended up applying uneven pressure causing a wave or dimple in the clear coat. The area around the scratch is a little lighter and a oval sized discoloration appeared. It is still grey but the metallic flake i is gone... not sure if I went through the clear coat.... I don't think I did.... anyway, I touched that spot back up but now it looks worse than before... like a dent.... so should I sand the whole thing over again using a block... or there is nothing I can do at this point?
  2. May 9, 2011 at 1:35 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2015 Double Cab TRD Off Road
    New to the forum...but "old" to the world. Been doing touch-ups for fifty years. Made lots of mistakes. Think you did too. You have a new truck and apparently you want it to look good. Time to head to a good body shop. Metallic paints are terribly hard to get right. Check this out before you attempt another touch-up. http://guidetodetailing.com/damage-repair/paint-repair-clinic/ Scroll down.
  3. May 9, 2011 at 1:47 PM
    RacerAV
    RacerAV Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    that site is amazing!! thank you... been reading for hours it seems...
    Adamo
  4. May 9, 2011 at 5:37 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Yes, lots of information there that I didn't know! Thanks for the link tguil, very informative. :D
