What antifreeze to use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ph16drive, Feb 5, 2008.
  1. Feb 5, 2008 at 4:08 PM
    ph16drive
    ph16drive [OP] \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Now that I'm becoming more familiar with the 08 taco, I started wondering what type of antifreeze I'm supposed to use should my reservoir need refilling in the future. I searched the forum and did not find any threads about types of antifreeze. I saw Prestone had an "any vehicle" antifreeze the last time I was at Autozone but I assume it's green. Is that okay to mix with the factory red antifreeze?
  2. Feb 5, 2008 at 4:27 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    it is ok to mix it says on the bottle
  3. Feb 5, 2008 at 4:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the antifreeze in your radiator is toyota long life coolant, so thats what i got from the dealership, around $15 for a gallon of the pink 50/50 mix. i think its ok to use something else, as long as its a 50/50 mix.....just to be on the safe side.
  4. Feb 5, 2008 at 4:35 PM
    natrlyst
    natrlyst Well-Known Member
    Just a quick question, why do you need anti-freeze already for an 08 tacoma?
  5. Feb 5, 2008 at 9:15 PM
    emad
    emad Active Member
    belvidere il
    08 regular cab 4x4 sr5
    16 inch american racing chambers with teflon coating 275/75/16 nitto terra grapplers rear window tint and a winch bumper will be put on this spring
    he dosent he said if he needs to in the future he was curious on what to use
  6. Feb 6, 2008 at 2:51 AM
    ph16drive
    Paul
    Clevelandish
    Thanks for the info guys, I appreciate it . . . as emad said, I just wanted to know what to use in the future . . . the truck does not need antifreeze yet.
  7. Feb 6, 2008 at 4:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Good post. Something that often gets ignored....
    (not ignored, just forgotten about)
    This makes me wonder what our antifreeze protection is? I've got one of those cheesy little tubes w/ floaters in it to check the temp rating (I think).
    Laugh - that just shows how long its been since I used it. :rolleyes:
    ..too lazy to look it up and keep this topic going for the hell of it...
    What does the newer generation trucks recommend in the form of flushing & replacing? I think my 96 tacoma was 30k miles?
  8. Feb 6, 2008 at 4:20 AM
    ph16drive
    Paul
    Clevelandish
    Here's a link http://smg.toyotapartsandservice.com/index.php to a scheduled maintenance guide that I don't know if it's thorough enough . . . just something I found quick. You can use the pull-downs to find your vehicle. For an 08 Taco, I couldn't find an entry such as "replace engine coolant." What I did find were several entries for "inspect engine coolant" . . . this is what makes me think this may not be thorough enough.
  9. Feb 6, 2008 at 4:58 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The "new" pink toyota antifreeze is rated for 100,000 miles or 10 years. They reccommend every 50,000 miles or 5 years after that. They also state to NOT use any green antifreeze with the stuff. It a different chemical composition.
  10. Feb 6, 2008 at 5:24 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Thanks Roland for bringing that up. With that kind of rating, why would anyone concern themselves with replacing the fluid. If you need to add an amount of fluid you should have the dealer do some checking on where it went to! ! Just my observation! !
    Don G
  11. Feb 6, 2008 at 7:29 AM
    natrlyst
    Ssorry my bad, will read again next time...
  12. Jan 14, 2010 at 11:14 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    okay so we know it's the pink stuff, does anybody know the actual
    dealer number/name of the stuff either pre-mix or what?
  13. Jan 14, 2010 at 11:16 AM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Use the factory stuff from Toyota, it isn't cheap, but I would recomend it over anything else. It is not pre mixed, use it 50 /50 with distilled water
  14. Jan 14, 2010 at 1:43 PM
    esse10
    Texas
    I hear from my mechanic that 60/40 H2O/coolant is still acceptable. I believe that if you need to add a little to the reservoir topping it to the
    desired line with distilled/deminiralized water is okay. Just dont' put regular tap water man. your make a big NO, NO if you do.
  15. Jan 14, 2010 at 2:12 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    From the 2009 Factory Service Manual, Cooling page CO-3
    Use only Toyota Super Long Life Coolant or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology (coolant with a long-life hybrid organic acid technology consists of a combination of low phosphates and organic acids).
    Prestone Extended life coolant will work, even though its green.
  16. Jan 14, 2010 at 4:06 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Doesn't Prestone still make the long life orange antifreeze/coolant?
    Marc M
  17. Mar 30, 2011 at 5:25 AM
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    anybody have a DIY work up on flushing and refilling Taco's my 06 will be five this April.. but it only has 40k on it.. pictures are nice :) thanks..
    they want $89.99 at the dealer to this...
  18. Mar 30, 2011 at 8:32 AM
    House Doc
    House Doc Active Member
    Make sure if you do buy coolant it is SILICATE FREE. Otherwise you will introduce silicates and that will lead to premature wear on water pump, etc.
  19. Mar 30, 2011 at 9:05 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    easiest thing to do is go and get a jug from toyota. That way you know for sure its the right stuff.
  20. Mar 30, 2011 at 9:18 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I have a friend that works at a radiator shop. He said that the Red Toyota antifreeze is the best stuff he has ever seen. He also said that he would buy in drums if he could. He said that it does not last forever but it lasts longer than any of the others and I should continue to use it for the life of the truck.
