What are my tire size options?
Discussion in 'Wheels & Tires' started by 05MaroonTacoma, Jul 16, 2012.
  1. Jul 16, 2012 at 1:32 PM
    05MaroonTacoma
    05MaroonTacoma [OP] Member
    GA
    Tacoma PreRunner
    I know this information is around here somewhere. 2005 Tacoma PreRunner, 17 inch stock aluminum alloy wheel. What is the max tire size I can get away with without rubbing? I drive this truck on the interstate 52 miles a day for work, anything i should be aware of before purchasing tires?
  2. Jul 16, 2012 at 1:41 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    265/70/17
  3. Jul 16, 2012 at 1:46 PM
    05MaroonTacoma
    GA
    Tacoma PreRunner
    what is i installed a 3 inch leveling kit?
  4. Jul 16, 2012 at 1:51 PM
    lionhunter93
    lionhunter93 Well-Known Member
    Vinnie
    NM
    06 Doublecab lifted TRD Off Road
    Icon Coilovers with add a leaf in rear, banks monster exhaust, 16" Toyo Open Country MT 255/85 Kenwood dvd reciever,
    You could go with 255/80's. I used to have 285's and they would rub alot when doing a hard turn
  5. Jul 16, 2012 at 1:56 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    A lift has nothing to do with what size tire you can clear unless you modify the bump stops and trim the shit out of the fenders.
    If you simply lift the truck it still maintains the same tire travel.
    Bigger isn't always better :)
  6. Jul 16, 2012 at 2:00 PM
    lionhunter93
    Vinnie
    NM
    Um, I dont think you know what lifts are really for? Lifts are made to fit bigger tires so you have more ground clearance, depending on what size of tires you run there is no need for trimming
  7. Jul 16, 2012 at 2:02 PM
    XXXX
    sKiP
    05 Prius
    Yea your right. I'm clueless. :rolleyes:
    Please show me how strapping on a shock that has stiffer coil springs for a 3" lift will stop the tire from hitting the cab mount or fenders.
    Ill be waiting for your reply :popcorn:
    simple geometry is simple
  8. Jul 16, 2012 at 2:07 PM
    lionhunter93
    Vinnie
    NM
    I know it wont hit from experience on my own truck and I have never hit my cab mount or fenders and I have flexed my suspension a lot
  9. Jul 16, 2012 at 2:11 PM
    XXXX
    sKiP
    05 Prius
    Your running a 3" spacer lift with 255/85/16's :rolleyes:
    I'm running that size tire with 1" of lift.
    You have backed up your theory with nothing.
    Please don't mislead our members with BS. People actually read this stuff and spend their hard earned money on parts. Nothing is worse then saving up, doing research, getting the parts, then finding out someone gave you an incorrect answer and your screwed.
    If you would like to continue the discussion please PM me and I may be able to explain it better for you. No need to muck up OP's thread.
  10. Jul 16, 2012 at 2:11 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Stock
    ^^^This
    ^^^Truth!
    :crazy::smack:
    :ohsnap:
  11. Jul 16, 2012 at 2:13 PM
    XXXX
    sKiP
    05 Prius
    This is the correct answer op. There is a .00001% chance you might rub slightly depending on your caster, but nothing major at all. I had 35k on this same sized tire on my 08' 4x4.
  12. Jul 16, 2012 at 2:13 PM
    lionhunter93
    Vinnie
    NM
    Ya and he asked about a 3 inch lift not a 1 inch lift. no wonder why you had to do a lot of trimming
  13. Jul 16, 2012 at 2:20 PM
    XXXX
    sKiP
    05 Prius
    :goingcrazy:
    It doesn't matter what size lift unless it's DB or LT. By adding compression via a lift you lose down travel thus lifting the truck. Your wheels still maintain the same movements.
    I did NO trimming and never said I did any.
    Please stop while ahead or move to PM. You are 100% wrong.
  14. Jul 16, 2012 at 2:25 PM
    lionhunter93
    Vinnie
    NM
    ok whatever man, I dont see how there is anyway you can be clearing a 255 with a 1 inch lift
  15. Jul 16, 2012 at 3:10 PM
    lefthand6
    lefthand6 Member
    Mal
    Seattle/North Bend/Snoqualmie Valley
    PreRunner V6
    Lifting you truck allows you to fit a larger tire under your truck, but it doesn't change the distance between the wheel wells when you turn your tires. So the larger the tire, regardless of the amount of lift, will still have the same (or at least nearly the same) risk or rubbing. That's why issues with tire sizing is so confusing. Most folk don't seem to realize that you're not only increasing the height of your tire (y-axis, eg. 33", 31", etc...), and possibly the depth of your tire (z-axis, "width of tire", eg. 285, 265, etc...) but also the overall width of your tire (x-axis, again 33" across, 31" across) in how it relates to turning into your wheel wells.
    Does this make things a bit more clear?
  16. Jul 16, 2012 at 3:12 PM
    lefthand6
    lefthand6 Member
    Mal
    PreRunner V6
    Also, 255 only relates to to the width of the tire, not the overall height. Theoretically, you could have a 255/40/R13, which would give you an overall wheel/tire diameter of 18".
  17. Jul 16, 2012 at 3:20 PM
    lefthand6
    lefthand6 Member
    Mal
    PreRunner V6
    I've been really curious about this issue as well, which is why I feel confident to chime in.
    I understand the geometry of it all, but I guess all of us new jacks would basically like to know, how to compute/figure out what width and overall diameter we can get away with, with all of our different vehicles? A big lift may let a bigger diameter tire fit under the truck, but is still going rub the shit outta the wheel wells when you make a hard a turn.
  18. Jul 16, 2012 at 8:28 PM
    lionhunter93
    Vinnie
    NM
    You could go with a 255/80 for a 17 rim and for a 16 inch rim you can go with a 255/85
  19. Jul 17, 2012 at 5:04 AM
    XXXX
    sKiP
    05 Prius
    check my build out and you will see http://toyotaoff-road.com/threads/646-Oswego-s-Build?p=39016&viewfull=1#post39016
    The best way is to ask someone who has tried before. Even a wheel tire expert can't give you the best answer unless he has tried to fit the tire/wheel combo before. With over 80,000 members I'm sure someone has tried the set up.
  20. Jul 17, 2012 at 7:59 AM
    lefthand6
    lefthand6 Member
    Mal
    PreRunner V6
    How did you figure this out? Especially since you don't know what year, or package tacoma I own?
    I tried this weekend but got no real feedback. See this thread if you think you can help -- http://www.tacomaworld.com/forum/wheels-tires/229529-1st-gen-prerunner-max-tire-size.html
    The only response I got was another guy telling me if I lifted my truck more I could fit something bigger under there, so the same thing Lionheart is trying to say.
