What are the biggest tires.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coastie76, Feb 9, 2008.
  1. Feb 9, 2008 at 1:45 PM
    coastie76
    coastie76 [OP] New Member
    SR5
    I was wondering if anyone new for sure what the biggest tires your able to fit under a 2006 double cab 4x4. Looking to move up in size without having to lift or level the truck. Thanks.
  2. Feb 9, 2008 at 2:59 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Welcome to TW, coastie. Blow the dust off that search option up top and key in "biggest tire on stock truck". You'll have to sort through some xtra crap, but I'm sure you'll find some good info in there. I'm not trying to be a dick, just trying to help you learn your way around TW. Good luck.
    BTW, I think the answer is 32", but double check that.
  3. Feb 9, 2008 at 3:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    265/75/16.......biggest you can go without a lift.
  4. Feb 9, 2008 at 4:31 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    thats what the 4x4s come with
  5. Feb 9, 2008 at 5:29 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Hey coastie,welcome...I just put on 265/70/17's (31.7") on my stock '07 TRD.
  6. Feb 9, 2008 at 8:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually, i think they come with 265/70/16.
  7. Feb 9, 2008 at 8:16 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I do believe you are correct.
  8. Feb 10, 2008 at 6:49 PM
    coastie76
    SR5
    Hey guys thanks for all the answers. I was searching around in here tring to find the asnwer to the biggest tires you can fit under a stock 06 4x4 doublecab and everything I have read talks about lifts prior to the size tire they use. I measured and it look like I have about 2 inches all around not including suspention travel. Would like to bump it up to a 285/70/R17. Just wondering if anyone has done it or tried doing that.
  9. Feb 20, 2008 at 9:46 PM
    melissa0031
    melissa0031 Just enough knowledge to be dangerous
    melissa
    Northern Greenville South Carolina
    2015 silver metallic 4Runner trail edition
    Traded my taco for a 2015 4Runner trail edition..let the fun begin...
    i just had 265/75/r16's put on my 2005 4x4, they dont scrub, but its close. i was told by 3 different tire shops if i went any bigger i would have to have a lift or i would have some major scrubs, they also said if i didnt get the lift i might could get away with some trimming and takeing the mud flaps off, so anyways i went the safe route and stuck with the ones they said and im happy with the size they look sooooo much better than the stock 245's now the 4x4 looks like a 4x4:)
  10. Feb 21, 2008 at 9:09 AM
    Soul
    Soul Well-Known Member
    07 PreRunner SR5 Black
    Bad idea coastie... that would do rub ur fenders a lot. Even if you had a 3" lift it would rub a tab bit. Get 265/75/16 and you shouldn't have no rubber issue. I know for sure people with Destination A/T don't but people with ranger R/T do sometimes.
  11. Feb 21, 2008 at 3:24 PM
    Jake
    Jake Member
    2007 Access Cab - Silver
    Bed D-Rings, Speaker Upgrade using TacoTunes Kit, Hitch w/ wire kit, Suspension TRB, More mods in process...
    The people at Revtek Lifts recommend the 285/70/17 with their 3" lift.
  12. Mar 5, 2008 at 1:42 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Hi there...I'm wondering the same thing -- what's the biggest tire size I can go on my stock rims/suspension. I have the TRD Sport package on an '08 Tacoma Double Cab and it came with 265/65/17's. They look to be 30.6" tall. I've done a bit of reading and it looks like the stock suspension should be able to accomodate 32" tall tires. If I do the math right (which I may not be doing so feel free to criticize), I should be able to clear 265/70-17's which would be an inch taller at 31.6". I'm assuming that 265/75-17 tires at 32.6" would rub. I know that different tire vendors' tires vary in dimension. Any help would be greatly appreciated. THANKS! G²...
  13. Mar 5, 2008 at 2:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u can run 265/70/17's w/ no prob
