What are the stock tires on an '07 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jordank, Jan 18, 2012.
  1. Jan 18, 2012 at 2:04 PM
    jordank
    jordank [OP] New Member
    Hey guys,
    I'm looking at picking up a 2007 Tacoma, but it has only 20,000 kms on it. It's a little fishy for a 5 year old truck to only have 20k on it, so I asked to see the Car proof (Canada's Carfax) and they have no odometer records. In order to determine if the truck has been rolled back I want to see if it still has its stock tires on it - the Tires are Dunlop AT20s on the truck, does anyone know the different tire options that were offered during that year?
    Thanks,
    Jordan
  2. Jan 18, 2012 at 2:07 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe it can vary a little bit by region and also depends on the model. If it is a TRD Off Road, it should have BFG Rugged Trails, TRD Sports would have either AT20's or Bridgestone Duelers, SR5 could have any of the above.
  3. Jan 18, 2012 at 2:33 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    those were the tires that came on my 2010 2wd access cab 5 lug.
  4. Jan 18, 2012 at 2:34 PM
    Large
    Large Red
    No odometer record should throw up a flag. Do they not have some kind of annual inspection?
  5. Jan 19, 2012 at 10:43 AM
    jordank
    Well apparently no odometer readings is quite common.This was at a VW dealership, and when questioned he showed me two more car proof reports, one for an F150 on the lot, and another for one of the employee's Audi S4 both of which had no recorded odometer readings. I also checked the headlights as you would expect some pitting or fogging of the headlights if the car was older then what they had stated.
