What are these shiny spots on the door panel top? Defect?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNumber6, May 18, 2015.
  1. May 21, 2015 at 5:55 AM
    #121
    TacoNumber6
    TacoNumber6 [OP] 6 TIMES A CHARM
    i admit that i am picky, but i have worked for everything i got. i was never given anything. i purchase anything with my money i expect it to be right, i dont let it go like some people. letting go is a sign of weakness
  2. May 21, 2015 at 6:49 AM
    #122
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Did you tell your ex that too when she caught you outside her window? :D
    Giving up doesn't make you weak, it means you are strong enough to overcome issues and let go. Is this door panel worth the stress? Maybe it is worth it to you and that's fine but I'd never waste the time or effort taking things as far as you do. That's not a sign of weakness to know there are somethings that are not worth worrying or troubling about.
  3. May 21, 2015 at 8:54 AM
    #123
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    The world of perfect flawless shiny things only exists in the movies, and RollsRoyce. that is it.
    ever been in the cockpit of any current fighter aircraft ? these things are the highest level of human
    engineering, and they have dirt and scrapes and scratches everywhere when you get up close to them.
    even the prettiest peacock on an farm... has a line of snot down it's beak and shit on it's feet
    Larikin and wake100 like this.
  4. May 21, 2015 at 9:03 AM
    #124
    Larry
    Larry CARL
    CARL
    The Serenity Prayer:
    God, grant me the serenity to accept the things I cannot change,
    The courage to change the things I can,
    And the wisdom to know the difference.
  5. May 21, 2015 at 10:26 AM
    #125
    TacoNumber6
  6. May 21, 2015 at 2:13 PM
    #126
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Because of Memorial Day and the number of boats needing to be completed, my Upholster had to reschedule installing my leather Katzkins till next Wed. I did get a price however of 100.00 per door to cover the areas we have been discussing here, with matching leather. He has a perforated charcoal leather that matches that area of the door panel perfectly. Instead of plastic it will be leather covered. I'm going that route then I'll have nice leather seats and that bad area on the door panel leather wrapped. Then the inside will be solid and look much more upscale. Cant wait. Katzkins come first then two weeks later the door panels will be done....
  7. May 22, 2015 at 5:14 AM
    #127
    TacoNumber6
    looking forward to seeing the final results
  8. May 22, 2015 at 9:48 AM
    #128
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    Wow. They look like tiny little arms with fingers. :)
    Two words: DERP IT.
  9. May 22, 2015 at 9:52 AM
    #129
    TacoNumber6
  10. May 22, 2015 at 10:53 AM
    #130
    labmannn
    labmannn Well-Known Member
    Bill
    Mt. Juliet, TN
    2013 Tacoma TRD Sport Pkg 4WD
    window tinting, N-fab light bar, 4 Hella fog lights, N-fab step bars, 3" Pro Comp lift
    Not sure if they had to replace the window with the new door panel but I got some glue on my door panel when I replaced a window and it looked very similar to that. The glue was was shiny but smooth in texture and wouldn't come off.
  11. May 22, 2015 at 11:34 AM
    #131
    TacoNumber6
    OH THIS IS DEFINATELY A FACTORY ISSUE. THEY ORDERED A NEW ONE AND IT WAS EVEN WORSE OUT OF BOX
  12. May 22, 2015 at 11:48 AM
    #132
    Larry
    Larry CARL
    CARL
    outstanding. We look forward to pics. :thumbsup:
  13. May 22, 2015 at 11:59 AM
    #133
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Well, two good things happened...you found out your panel was better than it could have been, and you saved some future owner from having a panel worse than yours, 'cause you had it ordered to replace yours. Now it will sit on some shelf and not bother any other ocd owner down the road. Good job!
  14. May 22, 2015 at 12:10 PM
    #134
    TacoNumber6
    NOTHING YOU JUST SAID MAKES ANY SENSE...ARE YOU DRUNK?
  15. May 22, 2015 at 12:18 PM
    #135
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Is your Cap Lock key stuck would be a better question.
  16. May 22, 2015 at 12:25 PM
    #136
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    caps lock is cruise control for cool
  17. May 22, 2015 at 1:53 PM
    #137
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    My 14' had these on the door panels from the dealership
  18. May 22, 2015 at 11:35 PM
    #138
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    WTF MINE IS STUCK, TOO
  19. May 24, 2015 at 11:32 PM
    #139
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    No.
    And, I'm not seeing any spots on my door panels either.
  20. May 25, 2015 at 4:14 AM
    #140
    Tango71
    Tango71 Well-Known Member
    The test driver for Toyota that gets behind every single Tacoma to make sure you are getting a fine quality vehicle is a greasy mofo and doesn't shower.
    Why not just grease up the rest of the panel? Problem solved!
