What are you towing?
Discussion in 'Towing' started by SmokeEater, Oct 20, 2010.
  1. Oct 20, 2010 at 6:07 PM
    SmokeEater
    SmokeEater [OP] Member
    JOHNNY
    Potomac Falls, VA
    2011 TACOMA
    K&N Drop-in Painted grill New TRD center caps & other little things here and there......
    What are you towing behind your Gen2 TAC?
    - how much does it weight
    - how does she do pulling it
    - any regrets in buying a TAC
    We're looking into a pop-up camper and boat and Im trying to get an idea on size, towing capabilites, etc.
  2. Oct 20, 2010 at 6:11 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Towing capacity is 6500lbs.
    I tow a 4000lb Mastercraft regularly. No issues. Love the way it tows.
  3. Oct 23, 2010 at 5:55 PM
    SmokeEater
    JOHNNY
    Potomac Falls, VA
    2011 TACOMA
    Thanks - the boat we're looking at is just over 5000 lbs, so we might have to hook it up for a test run.
  4. Oct 23, 2010 at 5:57 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  5. Oct 23, 2010 at 5:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  6. Oct 23, 2010 at 5:58 PM
    FlyingTaco
    FlyingTaco Well-Known Member
    GA
    '10 4x4 DCSB SWB
    Trimmed mud-flaps, engine de-tick, FJ wheels, avid off road light bar(one of a kind), truck covers bed cover and decals by sockmonkey so far.....
    How much over 5000lbs? Remember that you're gunna put gas in the boat and play equipment and all the other stuff we take boating. Not likely to put you over 6500 even if its at 5900lbs already but be mindful.
  7. Oct 23, 2010 at 6:33 PM
    moelov
    moelov Well-Known Member
    USA
    09 PreRunner SR5 Lifted
    Removed the Mud Flaps, Rock Deflectors and Head Rest. Limo Tint, I had 3" Toytec Lift, Procomp Nitrogen ES6000 shocks and Struts. AllPro UCA, AFE Pro Dry drop in filter, WeatherTecs. Now I have LR UCA's, Maxtrac Spindles, Eibach's, 5100's up front, Expos, 5160 for the rear, U Bolt Flip Kit, and Extended Brake lines.
    Dunn know how much but it does it fine.
  8. Oct 23, 2010 at 7:04 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I tow a 97 Four Winns Sundowner 205 almost every weekend in the summer. I think that with fuel and fear I'm right at about 5500lbs. You definetly know its back there. On some of the bigger hills you really slow down but nothing the 3rd gear handle. Your gas millage will suck as mine is somewhere between 9-11mpg. It does a decent job through, but I would suggest an AAL or airbags for the rear as it gives the truck a must more stable ride while towing. I guess it would all depend on how often and how far you towed. If you are towing alot of long distance trips I would probably get something bigger. If you are like me and usually make short trips with the occasional long trip, the Tacoma gets the job done.
  9. Oct 23, 2010 at 9:34 PM
    sdtag
    sdtag Well-Known Member
    So Cal
    2015 TRD Sport DC LB
    lifted 2", snug top, tube steps
    It did great delivering a machine
    The machine didn't weigh much, less than a ton I'm sure.
  10. Nov 16, 2010 at 4:47 AM
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    tows awesome for me..
