What are your honest thoughts on remote tailgate lock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by farmtacoma, Jan 20, 2021.
  1. Jan 21, 2021 at 2:26 PM
    #61
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    I installed mine in 2019 just after I bought my truck. Popnlock was the only option, Toyota wasnt offering one at the time. So following others lead, I sourced and bought and installed my own kit and am glad I did. Cost me about 25 bucks, as I bought a stronger actuator. I park my truck in my garage at night, try not to go to sketchy places if possible. But I do travel, and have to leave it at the airport from time to time. But when I do, I feel good that my three thousand dollar tailgate is fairly secure ( I also have a hose clamp on the hinge and did the cable washer mod). Sometimes its a tiny bit of an inconvenience to have to unlock it, but its worth it for my peace of mind.
    ORtoCOTaco likes this.
  2. Jan 21, 2021 at 2:49 PM
    #62
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    It was the only option installed on my SR, works great, it’s awesome!
  3. Jan 21, 2021 at 2:54 PM
    #63
    AJ`s Inferno Offroad
    AJ`s Inferno Offroad 2018 offroad fire ball
    Maryland
    2018 TRD Offroad inferno
  4. Jan 21, 2021 at 3:01 PM
    #64
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    As far as I'm concerned, it's a must have.
  5. Jan 21, 2021 at 3:13 PM
    #65
    Jkline101
    Jkline101 Well-Known Member
    Josh
    Houston, TX
    2020 Black Tacoma TRD Sport 4x4 DC
    SEMA TRD Pro wheels, Falken Wildpeak AT3 tires, Bakflip MX4 Tonneau, 3D Maxpider Kagu floor mats, TRD Pro skid plate
    I have a Bakflip MX4 and get into the bed at least a couple times a week. Tired of using the key inside the fob to lock/unlock the tailgate. I ordered an OEM kit yesterday and am stoked to install it when it arrives!
    TacoJoe480, Doc62 and ORtoCOTaco like this.
  6. Jan 21, 2021 at 3:35 PM
    #66
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    Only option I ordered on our new TRD Pro. I installed one in our 2019 Tundra, and it worked fine--I just did NOT wish to do another install on the Pro--too much cold concrete. We had the factory tonneau cover on the Tundra and are getting a Smart Cap for the Pro. Just an extra level of security that I'm glad we have.
  7. Jan 21, 2021 at 3:41 PM
    #67
    pochoboy
    pochoboy Well-Known Member
    Really like our OEM tailgate locking kit. I don't know how the pop n lock works but with the OEM kit which we installed I'm having to unlock all doors with the key fob to unlock the tailgate. Unlocking the driver side door via the handle will not unlock the tailgate.
    Is there a work around to have the tailgate unlock with the 1st depression on the keyfob or using the driver door touch sense pad?
  8. Jan 21, 2021 at 3:47 PM
    #68
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    I'm guessing the tailgate opens with the "secondary" doors. I would assume that if you change the settings in the radio to "One-stage unlocking" (aka unlock all doors with one press) it would work. Perhaps you have your truck set up to ONLY unlock the driver's door on the first key press/touch sensor.
  9. Jan 21, 2021 at 3:52 PM
    #69
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    Works great ... simple install. Can't believe it wasn't standard on my 2019?! Having to use the one provided key was a bit funny.
  10. Jan 21, 2021 at 3:56 PM
    #70
    pochoboy
    Thanks, we'll look into that.
    on another note, I've installed aftermarket door actuator kits on a couple of vehicles prior and experienced actuator failures after 3-4 years of use, I would assume the oem kits are less prone to actuator failure? Longevity of aftermarket pop n lock actuators?
  11. Jan 21, 2021 at 4:21 PM
    #71
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    Not sure but I bought an inexpensive generic actuator when I built my kit. Honestly if it goes out after 3 years I don't think I'll be too upset, since it was $7 and would take me less than 10 minutes to swap.
    Also, I agree with the user above who suggested charging the door lock settings in the head unit. I'm quite certain that'll do what you want. I happen to have mine set to open only the driver door with first press/door touch because I don't want to overuse the cheap actuator when I don't need to unlock other doors or the tailgate.
    pochoboy[QUOTED] likes this.
  12. Jan 21, 2021 at 4:25 PM
    #72
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    I would think so! My only experience with aftermarket actuator kits is with the Miata community, and from what I've seen, most aftermarket kits have: (a) rods that are designed to bend to accommodate different mounting locations, (b) cannot (always) be mounted in "good" locations which leads to excessive wear, and (c) have cheap parts and plastics. These are all failure points that cause excessive wear on the poor quality motor and linkage.
    Seeing as there is a factory mounting location available, the pop n lock is built specifically for the Truck, and the sheer volume they sell; I would think the quality would be just fine. Additionally, there is no need for a long linkage for the tailgate; less torsion/forces/wear/etc.
    OEM is probably similar; maybe better quality, maybe not. I doubt there is "much" of a difference between the two, besides the wiring methods. I also don't think there is a huge price difference between OEM and aftermarket kits.
  13. Feb 3, 2021 at 5:49 PM
    #73
    DawgLover
    DawgLover Well-Known Member
    Jordan
    McDonough, GA
    2020 Cement SR5 DCSB
    Leather, TRD cat-back performance exhaust, Predator side steps, black overlays, 4R TRD Pro wheels, Nitto Terra Grappler G2s 265/70/17, TRD Pro shift knob, bed mat, Diamondback SE, TRD Pro grille, OV Tune, interior LEDs
    How long did the install take for some people? I watched one video, and it seemed complicated.
  14. Feb 4, 2021 at 11:09 AM
    #74
    ORtoCOTaco
    Colorado
    It took me about 2 hours to build mine from scratch, that included new wiring connectors and stuff. I'm not great with electrical stuff so I took my time.
  15. Jun 8, 2022 at 8:10 PM
    #75
    RNILT
    RNILT Well-Known Member
    Luke
    2022 TRD Off-Road DCLB Barcelona Red
    I’m here way after the fact, researching the OEM tailgate lock. Getting my new taco delivered soon and trying to decide whether to have the dealership do it or do it myself (though I am admittedly not handy or mechanical!). Then I noticed you said Mountain Hatch - that’s a replacement part for the tailgate, right? My wife and I love to sit on the tailgate to picnic. Can you do that MH install after you’ve installed the tailgate lock? Thanks in advance
  16. Jun 8, 2022 at 8:14 PM
    #76
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yes, though they are a decent combo to do together since you remove the tailgate skin to install the lock (regardless of which one you get.)
    RNILT[QUOTED] likes this.
  17. Jun 8, 2022 at 8:17 PM
    #77
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Yes, you can add this tailgate covers anytime. please also look at Snail Armor all aluminum tailgate $200. Super easy install with the right torx tools.
    I like my Hooke Road tailgate cover, Amazon prime $169.00
    in your case better to have the dealer install the tailgate lock!
    RNILT likes this.
  18. Jun 8, 2022 at 8:25 PM
    #78
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Easy to install the OEM and it works well. Several YOUTUBE videos on how to install and the only tools needed are a 30 Torx and a 10mm socket.
    RNILT likes this.
  19. Jun 8, 2022 at 8:33 PM
    #79
    daveeasa
    David
    PNW
    I'll disagree with my Lava braddah and say with 100% confidence that the OEM tailgate lock is a 1/10 difficulty and should be on everyone's DIY list. The instructions make it foolproof. You don't need any prior experience with anything, just patience and a willingness to crawl under your truck and zip tie stuff, ability to use a 10mm socket wrench, and I guess ability to read and follow directions (or ask questions on TW).
    My reason for liking MH is that I received a personal reply after hours from the owner about hardware which I had lost, directing me to the correct solution (stainless 1" lag bolts available at home depot) which solved my install that evening.
    As a dabbler in my own small business, I was a hooked customer for life on that one exchange. I like to try to supply this level of support to my customers and with so many examples of companies who don't, I gladly give my $ to those who do.
    With that said, lots of great options for tailgate panels which don't leave marks on your bum after sitting on them like the OEM one does :)
    RNILT likes this.
  20. Jun 8, 2022 at 9:12 PM
    #80
    Lava-road
    2019 trd-off road
    Simple for some? Best to watch several videos (Pop N Lock ) is a popular brand. Plug and play, but lots of running of wiring to the front cab areas. Expect a novice to spend as least one hour or more. Lots of thing to remove?
    just like wood flooring, Home Depot and Lowes told us so simple , just snap and go. The part they don’t tell you is how to measure , how to fit in hallways to match the bedrooms, living rooms, kitchen. Where to start First.
    We just did my house, glad I had a semi- professional floor guy helping us. ( family) For one bedroom , no problem. We did the whole house. Took two days. Lots of ripping, cutting and fitting. Oh a few mistakes too.
    Again after watching a few videos and you do feel confident! Go for it. If not have the dealer do it. For me , paying my mechanic is cheaper. If something goes wrong? My problem but his job to correct it.
    1/10 difficult, “. um “ looks like a 3-4 difficult to me , maybe more for some? Lol
    All a point of view.
    I know guys who cannot remove the spare tire, when doing for the first time, lol
    RNILT likes this.
