What are your honest thoughts on remote tailgate lock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by farmtacoma, Jan 20, 2021.
  1. Jun 10, 2022 at 3:59 AM
    #101
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    The OEM lock kit is one of the most functional mods you can do to your truck if you have a tonneau cover or a camper shell. Hell, even if you don't have a cover or shell it is still worth doing. And the install is pretty easy, even a caveman could do it.
    HisDad and TacoJoe480 like this.
  2. Jun 10, 2022 at 5:36 AM
    #102
    Tacoma1845
    Tacoma1845 Well-Known Member
    Anthony
    Central Virginia
    2018 Tacoma TRD Sport DCLB (Inferno- Premium/Tech)
    Installing the OEM tailgate lock was one of the best mods that I have done to my truck. Just click the remote or grab the door handle and it's unlocked.
    HisDad, TacoJoe480 and ORtoCOTaco like this.
  3. Jun 10, 2022 at 5:40 AM
    #103
    caribe makaira
    Caribbean, Puerto Rico
    Head Unit set to ALL DOORS UNLOCK first press.
  4. Jun 10, 2022 at 5:42 AM
    #104
    Tacoma1845
    Anthony
    Central Virginia
    Yep.
  5. Jun 10, 2022 at 6:29 AM
    #105
    Chucky888_2021_TRD_OR
    Chucky888_2021_TRD_OR Live free and drive Taco
    Ching
    Osseo, MN
    2021 TRD OR DCSB
    I second that. OEM lock kit is not that much more that Pop-n-lock, it plugs in nicely into factory harness. What is there to think about?
    Tacoma1845[QUOTED] likes this.
  6. Jun 10, 2022 at 7:12 AM
    #106
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    After having full keyless entry back there, I would never go back.
  7. Jun 10, 2022 at 9:42 AM
    #107
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    I would like to see an inline switch or key-press option to activate/deactivate the tailgate lock. Not too keen on auto unlocking and locking of the tailgate when simply using the truck but not the tailgate.
  8. Jun 10, 2022 at 10:12 AM
    #108
    willhahn24
    willhahn24 Well-Known Member
    2016 Tacoma
    Good to know!
  9. Jun 10, 2022 at 10:20 AM
    #109
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    That’s the default behavior when configured for one press driver door unlock. Two press does passenger and tailgate as the tailgate feeds off passenger.
    Perhaps you are keenly concerned about the extra cycles and routinely take passengers with you?
    replacing just the tailgate portion is 1/4 to 1/3 the work and no crawling. I’m not remotely concerned about wearing mine out.
    Pro-Taco likes this.
  10. Jun 10, 2022 at 10:34 AM
    #110
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    After watching a few videos, it seems very simple? Not many people like to pop off the panels, running boards, crawling under the truck and running the wires front to back. Un-locking the connections seems simple enough too.
    Today I prefer to have someone else do the work. Keeping my life more simple. (Retired).
  11. Jun 10, 2022 at 10:50 AM
    #111
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wouldn't worry about it at all personally, though you could do the switch method if you really insisted by running one of the wires through a switch mounted at the location of your choosing. Problem with that is if you put it in the cab, you will naturally find yourself hating it when you're standing at the tailgate, wanting to unlock the gate but you have to go over to the cab and reenable the switch again before the power lock will work. It would be faster at that point to just use the key to let yourself in which then defeats the purpose of installing the power lock to begin with. Plus, with the switch flipped you would not get the security of automatic locking like you get with the module working as designed.
    Usually these types of devices are pretty rock solid and last a long time. Hell, door locks don't act up all that much and they have cables involved in their operation. So personally I wouldn't worry about it. Absolute worst case, if the motor dies find a used one or buy a new kit and swap just the motor itself in about 10 minutes and be set for same length of time.
    Being tied to the passenger door and the second unlock click should at least spare it a little life, unless you changed the truck settings to do one click unlocks the whole truck. Even if you did that, I still wouldn't worry about the tailgate lock wearing out. Worst case if the lock module wears out then you're back to square one opening the gate with a key like you always did before. Just my thoughts anyways.
  12. Jun 10, 2022 at 10:52 AM
    #112
    lil gelato
    lil gelato Well-Known Member
    Does anyone have the remote tailgate lock AND the bed lighting kit? My dealer told me it's one or the other....
  13. Jun 10, 2022 at 10:52 AM
    #113
    BLtheP
    Plano, TX
    Any of the plug and play kits are very simple. I believe they are all plug and play by now. The worst part is lying under the truck on your back and zip tying the harness to looms or brackets on the frame, though that part isn't horrible either. The worst part to me was zip tying it in the muffler area because the muffler is close to the frame and makes it hard to get your arm up there. Obviously, let the exhaust cool off before digging all up in that area.
  14. Jun 10, 2022 at 10:54 AM
    #114
    BLtheP
    Plano, TX
    I added the OEM tailgate lock kit and the OEM bed lights to my 2021. They have nothing to do with each other at all, sounds like the dealer is out of the loop. On a 2020+ the wiring is there for the bed lights in the tail light area. Just pull the tail lights, pop in the lights and plug them in after removing the dummy plug that seals the stock unused wiring.
    The tailgate lock has nothing to do with the bed. it goes into the tailgate and the wiring runs through the tailgate, into the bottom of the bed and down the frame and up into the cab.
  15. Jun 10, 2022 at 11:01 AM
    #115
    lil gelato
    I thought it sounded odd, too. However, my salesman sent me pics of the order screen indicating that both accessories weren't compatible. Assuming you're correct, I'll be adding the lights myself after I take delivery. Thanks!
  16. Jun 10, 2022 at 11:04 AM
    #116
    BLtheP
    Plano, TX
    could be a glitch, but the same lights and tailgate lock are supposed to fit a 2022 that fit my 2021, so you should be good.
    Power Tailgate Lock
    Bed Lights
    Those are what I got for mine.
    lil gelato[QUOTED] likes this.
  17. Jun 10, 2022 at 6:33 PM
    #117
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    My two cents my wife is an insurance adjuster and says that with parts being scarce she is seeing a lot of claims for stolen tailgates. That is why I put one in. I lock the doors and the tailgate is locked.
    HisDad likes this.
  18. Jun 10, 2022 at 6:53 PM
    #118
    Lava-road
    2019 trd-off road
    Every heard of Ravelco Anti-theft Device! There has never been a vehicle stolen using the Ravelco Anti-device.
    Disarms the electrical systems. Cost with installation is &649.00. California & ?
    Google this for more info’s.
  19. Jun 10, 2022 at 6:57 PM
    #119
    caribe makaira
    With a 9v DC battery
    the tailgate solenoid is "defeated".
  20. Jun 11, 2022 at 5:54 AM
    #120
    Molina67
    Ken
    2022 Tacoma SR5
    This is the one I got and installed. Very easy to do the only issue I ran into was the harness referenced in the video does not exist on my Tacoma so I just zip tied it to the frame. https://youtu.be/Hf5Mr-6PbVU
    OldSaltyDog and HisDad like this.
