What are your thoughts on AFE Pro-Dry S Air Filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josepenajr, Jul 21, 2013.
  1. Jul 21, 2013 at 5:16 PM
    josepenajr
    josepenajr [OP] Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    any one have one of these on a 2013 taco?
    any feed back ?
    thanks
  2. Jul 21, 2013 at 5:20 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you want a washable filter, it's a great option. It won't do much for performance gains though, if that's what you're after.
  3. Jul 21, 2013 at 5:21 PM
    josepenajr
    Laredo , Texas
    Im looking for better MPG...
  4. Jul 21, 2013 at 5:25 PM
    Pugga
    Massachusetts
    I had the TRD filter, no MPG or noticeable performance gains. The intake is a CAI as it is, keep a clean filter in it whether it be a Pro Dry or OEM and it'll function well. highaltitude is selling an intake manifold spacer that seems to be getting the owners some minor MPG gains but it's not overly cheap.
    http://www.tacomaworld.com/forum/pe...57-intake-manifold-spacer-4-0l-coming-60.html
  5. Jul 21, 2013 at 5:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Won't help.
    All it will do is save you $20 every 2 years... and allow more dirt to enter your engine.
  6. Jul 21, 2013 at 5:34 PM
    josepenajr
    Laredo , Texas
    Thank you
  7. Jul 21, 2013 at 6:23 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I don't know about letting more dirt into the engine, I believe that's just a myth. I have had mine for 2+ years now with no problems. The big reason I bought one was because its easy to clean and doesn't have to be replaced. I might have gotten some performance upgrades but they were too little to notice.
  8. Jul 21, 2013 at 6:25 PM
    Pugga
    Massachusetts
    In areas of fine silt, the high flow filters can let more fine particles past the filter. Higher flow comes with that trade off.
  9. Jul 21, 2013 at 6:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Used oil analysis consistently confirms elevated silicon levels. I've seen it on my motorcycle, and it's been seen on reports posted on the forum.
    The increase is dramatic enough that Blackstone will comment that levels are high and the intake system should be checked for leaks or a damaged filter.
    That is dirt being ingested and passing the rings.
    It causes cylinder scoring (I've seen it), which leads to increased oil consumption.
    I ran a K&N on my '94 and at 200k it was burning 2 quarts between changes.
    Always joked with my wife that I really didn't need to change it, just replace the filter.
    And that is all beside the issue of over-oiling of oiled filters (and it's very easy to do) fouling the MAF and causing codes.
  10. Jul 21, 2013 at 6:32 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    ^^^ somebody has done some research haha. If that's the case if I run a can of sea foam thorough the engine every oil change, shouldn't that help ?
  11. Jul 21, 2013 at 6:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nope.
    The damage is done when the dirt scrapes past the rings on it's way into the crankcase.
  12. Jul 21, 2013 at 6:37 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Your making me want to take mine off Rich. Another reason why I love this forum.
  13. Jul 21, 2013 at 6:37 PM
    Pugga
    Massachusetts
    Damn, Rich... That was slightly more technical than my explanation :laugh:
