What backspacing to get?
Discussion in 'Wheels & Tires' started by NCTacoma09, May 25, 2010.
  1. May 25, 2010 at 6:39 AM
    NCTacoma09
    NCTacoma09 [OP] Stand for Nothing or Die for Something
    Andrew
    North Carolina
    Black 09 Double Cab 4x4 V6
    Ok so just ordered my 3 inch lift from toytec and now im going to get new rims and tires. I already have the rims I want picked out but im confused as to what back spacing I should get. I want to go with 285/75/r16 tires and the rims I am going to get come in 4.0 and 4.5 backspacing. The website says that if I go with the 4.0 backspacing that it will give me more clearance with the UCA's but it will also make my tires stick out further. I realize I will have to trim inside the wheel wells to make the 285's fit without rubbing. Will I be ok with this setup or is there something I am forgetting.
    Edited Post
  2. May 25, 2010 at 12:08 PM
    NCTacoma09
    Andrew
    North Carolina
    anyone??
  3. May 25, 2010 at 12:39 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can fit the 285/75/16's with the 4.5" backspacing with a little trimming. Most folks on here run the 4.5" BS rather than the 4.0".
  4. May 25, 2010 at 12:47 PM
    NCTacoma09
    Andrew
    North Carolina
    Why do they run the 4.5 instead of the 4.0?
  5. May 25, 2010 at 12:51 PM
    rick
    rick `
    4.0 will stick out to much
  6. May 25, 2010 at 12:55 PM
    NCTacoma09
    Andrew
    North Carolina
    Anyone have pics of their truck with a 3 inch lift and 285's with a 4.5 backspacing.
    Edited I had the wrong backspace number up there
