What buttons light up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carone, Nov 3, 2009.
  1. Nov 3, 2009 at 7:35 PM
    Carone
    Carone [OP] Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    Ok i'm trying to find out if my car is messed up or if its normal.
    At night the only button on my door panel that lights up is "AUTO" on drivers side window switch.
    Mirror control doesn't light up nor does door lock or other window button and on passenger door nothing lights up.
    confirm or dis-confirm...
  2. Nov 3, 2009 at 7:43 PM
    Fly5465
    Fly5465 Well-Known Member
    Gilbert, Arizona
    02 4WD TRD
    36,000 miles
    Confirmed!! I have 2 - 2002 Tacoma xtra cab trucks and I just checked they are both the same. Just the "Auto" lights up.
    Fly5465
    Gilbert Arizona
  3. Nov 3, 2009 at 7:52 PM
    Carone
    NOR CAL
    Look at my Build
    DAMMIT!
    I was afraid of that. I was actually hoping for a problem.
  4. Nov 3, 2009 at 8:07 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I wonder if there is someway to hook up a LED light in there that will light them all up...
  5. Nov 3, 2009 at 8:10 PM
    Carone
    NOR CAL
    Look at my Build
    maybe swap lexus or 4runner buttons?
  6. Nov 5, 2009 at 12:31 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    haha never realized this.. my 04 does the same thing! O_O
  7. Nov 5, 2009 at 8:33 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I noticed it, but didn't think much of it. It is kind of strange, if you're gonna go through the trouble of lighting one up, why not make both light up? and power mirrors, if so equipped (mine's not)
  8. Nov 5, 2009 at 8:49 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Also, I guess Toyota figures no one would ever need 4WD at night since the 4WD switch doesn't light up!:( Or that no one needs to know for sure if the fog lights are on since nothing lights up on the instrument panel!:(
  9. Nov 6, 2009 at 9:20 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    none of mine light up I have to crank the windows! :eek:
  10. Nov 6, 2009 at 9:30 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    If you cant find the pass side window button, knowing that it is to the right of the drivers side that is lit, then you are a complete idiot
  11. Nov 6, 2009 at 10:24 AM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I just realized my crank doesnt light up either :eek:
