What causes an A/T to heat up?
Discussion in 'Technical Chat' started by knayrb, Mar 20, 2015.
  1. Mar 20, 2015 at 11:39 AM
    knayrb
    knayrb [OP] Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Teach me something.
    I do not have an issue with this but was wondering the root cause for the heat in an automatic transmission. Don't confuse this with the practice that heats it up like heavy towing. I want to know WHY towing or other uses adds heat to a A/T. In my mind I see the only areas of friction would be a clutch pack or band. If they are slipping or are engaging frequently that would cause heat. Other than that what really causes the heat. The gears are practically submerged in oil. There is no combustion going on. The torque converter is basically 2 turbines with oil between them so no physical hard surface contact. Some heat would transfer to the A/T from the engine block. I don't understand where the heat comes from.
  2. Mar 20, 2015 at 4:49 PM
    gearcruncher
    Canadain bumper technician
  3. Mar 20, 2015 at 5:02 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Shifting, shifting, more shifting. Under load, like vehicle weight, and towing. Oh and are you aware of how many clutch packs are in the A750F? 7 these packs are engaging and disengaging with each shift=HEAT
  4. Mar 20, 2015 at 6:03 PM
    knayrb
    Bryan
    Pure stock
    So if I get this right just having the fluid moving around inside a torque converter creates friction and heat? If that's the case then I can see how towing and other heavy use can cause heat. There would be more resistances on the fluid from the engine side to the drive side of the torque converter. I wouldn't think fluid movement would generate much friction.
  5. Mar 20, 2015 at 9:45 PM
    robssol
    Rob
    S. Wisconsin
