What cold air intakes are you running
Discussion in 'Performance and Tuning' started by tacomathunder, Feb 22, 2010.
  1. Sep 1, 2012 at 3:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Looks like the times have changed. ;)
  2. Sep 5, 2012 at 1:17 AM
    Peewee1618
    Peewee1618 Active Member
    Texas
    2001 SR5 4WD
    AFE Air Intake with a PRO Dry-S filter, AFE throttle body spacer, Borla exhaust system, Full Donahoe suspension lift kit (coilovers and add a leaf), HID Light conversion kit, JBA cat-forward headers.
    AFE air intake with a pro dry-s filter.
  3. Sep 5, 2012 at 2:16 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    K&N with AEM dryflow filter......if you want sound it's cool, if not save your $$ and get a good drop in!
  4. Sep 5, 2012 at 2:16 PM
    MMAN412
    MMAN412 Well-Known Member
    Fruit Cove, Florida
    07 dbl cab
    bull bar, custom Got Duals w/ 4in tips, off road lights, general gabbler AT2 tires, cb with whip, 100w pa system, 3in Procomp Suspension
  5. Sep 6, 2012 at 6:09 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
  6. Sep 6, 2012 at 6:43 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    Volant with optional skewp
  7. Sep 6, 2012 at 2:33 PM
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    k, thanks! i just need to find that money tree
  8. Sep 6, 2012 at 2:43 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Lol
  9. Sep 6, 2012 at 2:54 PM
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    lol true. but i am looking for more power. even though you can't do much with tacomas unless you supercharge it. Any suggestions or insight anyone might have?? thanks
  10. Sep 6, 2012 at 2:57 PM
    BAMFTACO
    Juan
    Kings bruh
    Urd intake/exhaust/ urd maf calibrator this setup will give you the little power you want
  11. Sep 7, 2012 at 1:41 PM
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    do you have a maf calibrator? i've heard mixed things about it. and basically everything i have is stock except exhaust, what about tuning??
  12. Sep 7, 2012 at 1:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The MAF Cal, is for open loop tuning. So any time you get into open loop (outside of cruising, or closed loop) is what it is for. No necessarily for only WOT. Under certain instances that can be just past 30% throttle.
    A noticeable gain in power can be had with it. HP and TQ. Between 10-15 whp,depending on what other mods you have. And being the cheapest of the good tuning devices out there, it is a worthy investment for someone who wants a little extra power, as well as not a lot of coin spent.
  13. Sep 7, 2012 at 2:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :thumbsup:
  14. Sep 7, 2012 at 2:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No harm no foul my man. :thumbsup:
  15. Sep 7, 2012 at 2:57 PM
    #35
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    alright cool thanks!
  16. Sep 8, 2012 at 10:42 AM
    #36
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    There is a lot of tuning the URD MAF Calibrator in closed loop mode. You cannot alter the fuel mixture in closed loop mode with it, but you can do a lot of tuning there. We have other products that are used for altering fuel mixture in closed loop.
    There are a lot of intake systems on the market that are not very well designed and cause a lot of significant induced MAF sensor error. For example on the 5vz the K&N Series 63 will cause the engine to run very lean and cause a significant positive fuel trim deviation. The Volant for the 1GR Tacoma makes the engine run very rich and causes a significant negative fuel trim deviation in closed loop from the ECU trying to compensate for it. The there is the new TRD for the 1GR Tacoma that make the engine run lean and a significant positive fuel trim deviation in closed loop.
    We use the MAF Cal in closed loop to recalibrate the MAF sensor to the new tube and fix the induced sensor errors caused by poorly designed intake systems. Still tuning closed loop and fixing problems. So, yes there is a lot of closed loop tuning to be done with the MAF Cal.
    You can also compensate for injectors that are different size from stock.
    Just wanted to clear that up, the rest of the post is on target.
    G
  17. Sep 8, 2012 at 10:45 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you sir! Clears things up perfectly. :)
    Looks like we all learned something today....
  18. Sep 8, 2012 at 11:06 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You sir need to read this thread.
    http://www.tacomaworld.com/forum/performance-tuning/229882-n-power-gains-dynos-w-mods.html
    Then you will see that when you find your money tree, it will be well spent on increased power, as long as spent on good performance parts.
    The power is there to be had, and the gains are proven. I don't care how anybody 'feels' about it. You cannot deny it.
    If you have questions, ask me. Another place to check ou that has TONS of info, is www.xr-underground.com. Let me politely correct you. You can do plenty with your Tacoma, even being N/A.
  19. Sep 8, 2012 at 9:00 PM
    #39
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    i dont have am x-runner. i have an 07 dbl cab prerunner trd. still the same you think?
  20. Sep 9, 2012 at 7:47 AM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Like Wolfpack said. It is the same engine. There is a 4Runner dyno in thst thread as well. :)
