What did this man do to his IFS?
Discussion in 'Suspension' started by Bullfrog, Apr 23, 2013.
  1. Apr 23, 2013 at 12:27 PM
    Bullfrog
    Bullfrog [OP] "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    Looks like he basically made is own drop kit.
  2. Apr 23, 2013 at 12:31 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  3. Apr 23, 2013 at 12:33 PM
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    DIY to the max.
  4. Apr 23, 2013 at 12:34 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    It appears you are correct sir. More pics.
  5. Apr 23, 2013 at 12:37 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Cant imagine the alignment after that....
  6. Apr 23, 2013 at 12:42 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Shits custom yo
  7. Apr 23, 2013 at 12:49 PM
    Bullfrog
    McLaren
    North Bend
    What ever it is I want it done.
  8. Apr 23, 2013 at 12:54 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    No. You don't.
  9. Apr 23, 2013 at 12:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    thats like watching someone rub dog poo all over their body, then thinking
    "that looks fun"
  10. Apr 23, 2013 at 1:06 PM
    Bullfrog
    McLaren
    North Bend
    How? It would be like a drop style lift without loosing clearance and stability?
  11. Apr 23, 2013 at 1:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No
  12. Apr 23, 2013 at 1:11 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I would be willing to bet money, that the person who did that cannot get his truck to drive down the road in a straight line. An actual drop bracket is geometrically correct and stronger than stock, this dudes DIY project can't be geometrically correct and it is definitely weaker than stock.
  13. Apr 23, 2013 at 1:16 PM
    BulletToothTony
    You should try it.... Take pics after you go wheeling hard the first time so we can see how it holds up...
  14. Apr 23, 2013 at 1:30 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Do drop lifts ruin your CV axles and drive lines over time?
  15. Apr 23, 2013 at 10:11 PM
    BradyT88
    BradyT88 Well-Known Member
    The are supposed to be better for CV axles, basically the whole reason they exist. Probably not bad on drivelines, although lengthening them may be needed depending on how much lift you do.
  16. Apr 23, 2013 at 10:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I want to see how he lengthened the top of the spindle.
  17. Apr 24, 2013 at 9:53 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    Thats scary.. homemade DB lift but it doesn't lower your front axle except for the lower control arms. correct me if im wrong. Id cut that shit off and go back stock or get a real DB kit.
  18. Apr 26, 2013 at 9:38 AM
    Bullfrog
    McLaren
    North Bend
    Lets say it was build geometrically correct. And it was made to be stronger than stock. What would be the advantage to this? What if?
  19. Apr 26, 2013 at 9:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There's no advantage to the DIY abomination you pictured. It looks like a home made diff drop kit and home made drop bracket lift. The purchased drop bracket kits that require you to cut out the cross member replace it with another one that is just as strong. Think about the forces placed on those plates as the suspension cycles. You've basically added a torque block to the frame and removed the cross support that helps keep the front end rigid. The only advantage I can see is he saved a few hundred bucks in the short term but traded it for potentially having huge, expensive issues in the long term.
  20. Apr 26, 2013 at 9:47 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    You just can't make it geometrically correct and stronger than stock with a tape measure, welder, and a couple pieces of steel. The only advantage of this was that he didn't spend the money on a drop bracket lift.
