What did you 3D print today?
Discussion in 'Technology' started by slodoug, Apr 8, 2021.
  1. Jun 27, 2024 at 7:14 AM
    #521
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    Cleaning up my work bench and finding a place for everything so i created this little fellow.
    ERod27, TomTwo, watkins303 and 6 others like this.
  2. Jun 28, 2024 at 6:13 PM
    #522
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Guys,
    I know my school printer setup isn't ideal, but to help out the school I'm trying to trouble shoot any issues the printers are having to train the teachers this summer to be able to use them this year. I've narrowed problems we've been having down to files with a big footprint (roughly larger than 30mmx30mm) that have a hard time sticking to the platform, despite me going through an entire cailbiration routine with calibibrating the height on all corners and midpoints of all sides of the platform. I followed all the included instructions with the printer with no success and after googling and hearing someone mention the same thing, would there be a glue / spray that I could use to help the base or raft stick to the platform for my larger prints?
    Here's one of the successful prints with the small footprint:
    Here's one that would not stick.
    Any advice is appreciated.
    Thanks.
  3. Jun 28, 2024 at 6:21 PM
    #523
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Just my drink ignorant ass shooting off, but that large first layer looks like too high of a z offset and possibly too low of a bed temperature.
    That's throwing me though. I've not seen a small base print when a large base wouldn't. I usually get the opposite.
  4. Jun 28, 2024 at 6:23 PM
    #524
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    I would double check the bed material is compatible with the material being printed, and possibly up the plate temp too. If plate temp is too low and the filament is one that's prone to curling, it can be mitigated some with a higher bed temp.
    For some filaments/beds glue helps and for others it doesn't really make a difference. If you're going to use glue, use a glue pen, the sticks are total pain to clean off the bed.
    What material are you trying to to print?
  5. Jun 28, 2024 at 6:25 PM
    #525
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So is the Z offset between the base plate and the first layer or between the first layer and subsequent layers? I calibrate the z / height right before every print with a piece of paper sliding under the extruder with a small amount of friction.
    One thing I noticed is that the base plate is not consistently flat. It's like 1/32" plastic and the tutorial that came with the printer shows the person bending it to make the print pop off which will make it less flat. I just use the scraper they included and try to flick an edge off or just slowly rock the print back and forth instead of bending the base plate.
    Is the bed temperature the actual bed that's changing temperature or the temperature of the filament coming out on the first layer?
  6. Jun 28, 2024 at 6:40 PM
    #526
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    To be honest I didn't even know the plate can heat up nor do I know if I can modify that in the print options I'm given in the software I got from the school. Maybe that's an option that I could find on the touch screen menu on the printer itself, but I'll have to check on Monday.
    Here's the filament I believe I'm using.
    Appreciate it
  7. Jun 28, 2024 at 6:42 PM
    #527
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Z offset is between bed and first layer. That first layer is tricky- especially if your bed isn't perfectly flat. Heck, I'm on an aftermarket bed that is a machined aluminum block and it still has a curve to it. My printer, however, has a probe that maps the bed surface and then compensates for it.
    But from what I can see, your first layer isn't showing that right kind of "squish". And if a small base is printing successfully while a large print isn't, it's possible that your bed is warped.
    See if you can find and download a "first layer test".
    It will look similar to this.
    Do a few runs of that until you can get consistency in all corners and the center. A successful print means your bed is truly level.
    ... As for temperature, your printer should have two heat controls- one for filament and one for bed. Filament controls the temperature of the melted plastic right before it gets extruded, bed controls the heat of the bed. The bed needs to be hot to make a naturally sticky surface. Many materials recommend 60 degrees C, but I personally like to run mine really hot, in the neighborhood of 80 degrees.
    Dalandser[QUOTED] likes this.
  8. Jun 28, 2024 at 6:59 PM
    #528
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    A warped bed is what I've been leaning towards too, however I have absolutely no experience with a 3D printer until I was asked to run these for the school this year.
    Here's the calibration video I was following, the link should go right to that part of the video. There's a "fine tuning" calibration where it also does the middle of each side and all 4 corners. I have not seen noticable improvement when doing that over the calibration of only the center of the plate.
    https://youtu.be/kY90P420oxc?t=169
    Also, here's a link to the section of the video where he bends the plate to get the print to release. It didn't look good to me even before I started doing anything with the machine and less so now that I have been getting an understanding of how it may harm our larger prints.
    https://youtu.be/kY90P420oxc?t=373
    I'll look for a first layer test. What / is there a standard file type for printers?
    I'll look into increasing the bed temp.
    Here are a few more pictures of failed prints - the first one was the piece that was supposed to be in the back, middle.
    This is another one that took 3 tries:
    And a couple examples of bigger prints with small footprints that came out pretty well:
    The part that messed up was just a support piece here.
  9. Jun 28, 2024 at 7:42 PM
    #529
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Turn the bed heat up to at least 70c, your screen shot shows 50c.
    The print temp of 220 is fine, mine does the first layer at 220 then 215 from then on. Heat on the bed and a flat first layer are critical to having it stick and turn out well. It's the foundation for the entire print.
    Some prints need an extra adhesive layer.
    PVA (dilute Elmers glue) works the best and cleans off easy.
    Cheap aerosol hair spray works well.
    Regular old glue stick works too, may require a bit of soaking to bet it to release.
    I had issues with adhesion when I started too. The software with my printer was set at 50c as well. Advice from this thread prompted me to turn it up and that was the key.
    Subsequent software updates have finally got the settings in line with what they should have been to begin with.
  10. Jun 28, 2024 at 8:04 PM
    #530
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Oof I didn't see but it's right there. Ok I'll increase the bed temperature on the bigger prints. I'll try a glue pen / hair spray / glue stick or something else recommended here if it's still not sticking.
    Deathbysnusnu[QUOTED] likes this.
  11. Jun 28, 2024 at 8:10 PM
    #531
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'd start with just increasing the bed temp first and printing the test prints first to see how they turn out. I rarely use any glues anymore, mainly just for small footprint things that stand tall and are on the bed for long periods of time.
    You can design your own test prints, just lay out a few 40mm x 60mm rectangles at .5mm thick to see the first layer and the top layers.
    Heating element on mine is in the center of the bed. The edges and corners of the bed can be "cool spots" and lead to edges lifting, so don't be afraid to bump up the bed temp if the center sticks well and the edges don't.. Brims are helpful to keep the edge down and easy to trim off.
  12. Jun 28, 2024 at 8:39 PM
    #532
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Wow, I have been thinking in the back of my head (Even though I know it's wrong by now) that 3d printing still has a long way to go before I'd consider using it as a hobbyist.
    This post proves me wrong. That looks amazing.
    rob1208 likes this.
  13. Jun 29, 2024 at 8:57 AM
    #533
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, 60C bed is the lowest I've ever used. Clean the surface after each print. I've used the Elmer's Glue sticks, and water seemed to be the best for cleaning it off.
    Dalandser likes this.
  14. Jun 29, 2024 at 9:47 AM
    #534
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Glue is usually my absolute last resort, and 90% of the time I can go back and work out the underlying issue that caused me to use it as a crutch in the first place.
    Often right before I'm about to start an overnight print with a lot of complicated support, I'll level my bed (using the sheet of paper method) and then I'll take 5 minutes to print a simple first layer test. There are many designs out there, I like this one for it's speed and simplicity:
    https://www.thingiverse.com/thing:2879437
    It looks like this.
    Then I check each corner of each square for adhesion, and I look at the layer lines to make sure that they are sufficiently even in width, that they are overlapping consistently, and that no individual line looks "rounded" or is lifting off, and similarly, no line is spread so thin that it looks pinched.
    ^^^ If I can print that simple thing without imperfections, then a larger print should present no issues. As Snusnu said, the first layer is the critical layer. If a flaw shows up there, it only gets amplified.
    It's not sexy, but I would practice with first layer tests, and I would start my bed temperature at 80.
    Deathbysnusnu likes this.
  15. Jun 29, 2024 at 12:31 PM
    #535
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Embarrassing as it sounds, I don’t have any drawing software. Are there any decent free programs out there for Mac or PC - really free not a gimmick.
  16. Jun 29, 2024 at 12:33 PM
    #536
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    Autodesk still has a personal license for Fusion 360 that's free. You can pretty much do everything you need in it.
    https://www.autodesk.com/products/fusion-360/personal
  17. Jun 29, 2024 at 12:43 PM
    #537
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Free and easy, has tutorials to get started.
    https://www.tinkercad.com/
  18. Jun 30, 2024 at 4:18 PM
    #538
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    Printed some bed cubby covers to cut down the dust in the bed.
    Rock Lobster and Deathbysnusnu like this.
  19. Jun 30, 2024 at 4:59 PM
    #539
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Dang I just had to go find that file. That's on deck next.
  20. Jun 30, 2024 at 5:22 PM
    #540
    lupercal
    Portland, OR
    2020 OR DCSB
    I've had the files for months and always forget about them.
    I just went to install these and realized I printed the wrong number of parts. I need to print one more hinge cover for it to work.
