What did you 3D print today?
Discussion in 'Technology' started by slodoug, Apr 8, 2021.
  1. Jan 28, 2025 at 11:12 AM
    #1061
    millcho
    millcho Active Member
    Chicago burbs
    23 TRD OFF ROAD
  2. Jan 28, 2025 at 11:28 AM
    #1062
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Not printed today. But here are a few prints from the last few weeks.
    .劉煒 likes this.
  3. Jan 28, 2025 at 11:42 AM
    #1063
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    Quick preview of the drop in overhead mounts for 6/8 Gang panels I've been working on. No trimming, drilling, cutting, ect ect it just fits into the same space as the OEM panel and all the cables pass through the OEM holes in the back.
    I created 3 versions of the 6 and 8 Gang.
    Version 1: Only houses the panel
    Version 2: Houses the panel and 1 OEM style short switch. (So if you have a OEM short switch like the rear locker in that space you just install it on right side.)
    Version 3: Houses the panel with space for 2 OEM Style short switches. (Like in my case having the rear locker on the left side and the garage door button on the right.)
    PXL_20241217_212450746.RAW-01.COVER.jpg PXL_20241217_212508888.RAW-01.COVER.jpg
  4. Jan 28, 2025 at 11:56 AM
    #1064
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    Any updates in this?
    Out2gtcha[QUOTED] likes this.
  5. Jan 28, 2025 at 12:01 PM
    #1065
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    After the dicking around, I found the combination that is going to work. It printed all night and finished up this morning. Looks great. Glad I don't print much in ASA.
    TomTwo and Deathbysnusnu like this.
  6. Jan 29, 2025 at 5:13 PM
    #1066
    millcho
    Chicago burbs
    23 TRD OFF ROAD
    Even tho I've got 3D printed Aldi coin on my keychain, I still like to have place to store easily accessable quarters:thumbsup:. Printing another for the smaller blank insert at time of writing, will report. I'm liking the smaller coin holder better!
  7. Jan 29, 2025 at 10:01 PM
    #1067
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    She made it boys.
    Unfortunately I didn't get it all set up until after my 11mo old daughter went to bed and her room is right above my office so first print will have to wait until tomorrow night!
    I got orange, green, and PLA/PETG support material as my "free" sample spools. Interested to see how well the support material works. Then have about 8 other BBL lab spools plus probably half a dozen from my old printer ready to go, mostly PETG and PLA but a little TPU, too. I figure once I get a feel for the printer and work out any kinks (looking at you chamber fan causing lifting on some materials) I'll switch to the hardened nozzle and give some of the more exotic filaments a try. I have a few different motorcycle parts I want to get going on in a reinforced material.
    Hammerstorm, 95 taco, OPTIMUM and 2 others like this.
  8. Jan 29, 2025 at 10:04 PM
    #1068
    ITmaD
    Atlanta
    You're in for some fun man!
    Also when using the support material remember to set it to only use it on the interface layer so you don't waste it making towers/trees of support material.
  9. Jan 29, 2025 at 10:10 PM
    #1069
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Has anyone printed feet to connect the extruded metal to say a Yakima rack?
  10. Jan 30, 2025 at 1:45 PM
    #1070
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    I've been sanding away furiously, with my normal steps for ABS, brush on a thick-ish coating of some ABS supports mixed with acetone, then 100 grit > spray filler/primer > 180 grit > another round of filler/primer > 400 grit > silver paint for chipping > masking or chipping fluid > final paint.
    So far I've applied the ABS slurry to about 50% of the parts then initial sanding with 100 grit:
    I also purchased the needed 303 3/8" stainless steel rods for the elbow actuators and 1.6mm stainless steel tubing for the antenna set:
    I did end up having to take a break from sanding and filling, as I have begun to sort out the electronics that will make him "Roger Roger!":
    Once I get the electronics sorted, I'll return to sanding and filling, as it creates a hefty amount of dust.
  11. Jan 30, 2025 at 4:10 PM
    #1071
    Kilo Charlie
    Iowa
    Thank you for the update! Can't wait to see more!
  12. Jan 30, 2025 at 4:14 PM
    #1072
    xCaldazar
    xCaldazar Well-Known Member
    Los Angeles
    2018 SR5 Purple 4x4
    King shocks, Deaver rear leaf springs, Cab mount relocation, Howe TC Pump, 315/75/17, Outgear tilted rear bumper, Tune Outdoor M1 camper, Coastal Offroad Extreme Clearance front bumper & skids (aluminum), Cali raised kick out sliders, Alphaequipt carbon air intake (color matched) Clazzio leather seat covers, Sound Deadening, Dual battery
    They glow in the dark / black lights and have carmex inside them. Using them as trades for a multi day cyberpunk rave in the desert that only allows bartering
    Fargo Taco and spencermarkd like this.
  13. Jan 30, 2025 at 4:19 PM
    #1073
    OPTIMUM
    OPTIMUM YotaWerx Authorized Retailer OptimumTuning.com
    Grand Rapids, Michigan
    Definitely the best printer I've used!
    spencermarkd[QUOTED] likes this.
  14. Jan 30, 2025 at 5:01 PM
    #1074
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Um, we are gonna need a full report and pictures of this event. Sounds interesting.
  15. Jan 30, 2025 at 7:17 PM
    #1075
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Not printed but finally setup the desk I ordered to house the 3D printer, I had it next to my PC tower on an old table but with the square table and no supports it would shake pretty good while printing, so now this sits on the opposite side of the office, all 3D printing items will go on/under the desk. Got all the filaments organized and got most of the accessories on the desk, just gotta find my spare nozzles to put with it.
    Deathbysnusnu and Fargo Taco like this.
  16. Jan 30, 2025 at 11:37 PM
    #1076
    xCaldazar
    Los Angeles
    2018 SR5 Purple 4x4
    Here's some from last year
    mrtonyd likes this.
  17. Jan 31, 2025 at 4:57 PM
    #1077
    Murphy'sSidekic
    Murphy'sSidekic Well-Known Member
    MA
    2018 TRD Pro
    Made a holder for my laptop charger that has embedded magnets so I can quickly slap it onto the legs of my desk at work. Used TPU so that the charger was gripped by the material, but I could easily pop it out of the holder. Came out nice, only needed one first trial part to learn and tweak from, and the second one is the final part I've been using.
  18. Feb 1, 2025 at 7:41 PM
    #1078
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Picked up a humidity cabinet for filament and an extra AMS. Couldn't leave the cabinet/AMS empty, so had to fill them with filament and extra hotends, hardened extruder gears and a bunch of spare parts...
  19. Feb 1, 2025 at 8:16 PM
    #1079
    spencermarkd
    Spencer
    Y'know, I was on the fence about the AMS when I put in my order. I didn't think I'd do much multicolor printing (still don't think I'll do much of it, honestly) but MAN is it convenient to just leave a few colors in there and just hit the button to switch between when you're doing different prints. I get why people get more of them.
    Is that dessicant pods i see sitting next to the second AMS? Which ones did you print? I have a quart of dry and dry waiting to go. I pulled a spool of old filament out (honestly probably 3 years old) and tossed it in my dryer in anticipation of using it on a big print, and it was 15% off the bat. My house is dry as hell right now.
    Today I printed out some 4 post lifts for my lego speed champion sets (i need to print another 3 or 4 of them..) and am currently printing the first 20 or so layers of a mandalorian helmet so I can see if it'll go over my giant noggin or not.
  20. Feb 2, 2025 at 11:26 AM
    #1080
    Gen1FTMFW
    I printed these units since they have a spot for a hydrometer...
    https://makerworld.com/en/models/149506?from=search#profileId-163128
