What dimensions for a camper top for my 1996 ext cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, May 2, 2012.
  1. May 2, 2012 at 10:06 AM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    I am looking for the dimensions I would need for 96 ext cab sr5 because I measured it and then looked at some measurements for camper tops on and they say they fit my tacoma but the measurements don't equal out so I am just tryin to see exactly what I need and how it should be measured both on the camper top and the bed. Thanks for your help!
  2. May 2, 2012 at 10:10 AM
    Madjik_Man
    Colorado Front Range
    With the extra cab you also have to make sure that the front of the topper matches the curve of the rear of the cab.
    The ext cab has a different shape than the regular cab (which is more vertical).
    So technically there are toppers that have the same dimensions (width and length) that are different for ext cabs and reg cabs.
    This is the best picture I have that shows the profile of the ext cab and topper. See how the line of the cab moves forward and the topper matches it? The regular cab is more vertical. So if you accidentally buy a topper for a regular cab, you will more than likely rub the cab with the topper
  3. May 2, 2012 at 10:41 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Thanks that helps for sure. So chances are, it needs to be directly from an ext cab tacoma?
  4. May 2, 2012 at 10:57 AM
    Madjik_Man
    Yes, assuming the previous owner understood the difference as well.
    You'll easily be able to tell the difference of the front line of an ext cab versus a reg cab topper
    Here's a pic (after a quick search) that shows the difference hopefully
  5. May 2, 2012 at 2:11 PM
    thatSchusterguy
    thatSchusterguy Well-Known Member
    Cincinnati, OH
    96 X-Cab
    OME/881 Dakars Demello HD sliders Marlin 1200# Clutch Rust and Duct Tape
    Pretty sure you have that backwards, a regular cab topper will fit fine on an extended cab truck, but an extended cab topper will rub a regular cab truck.
    My topper doesn't have the slope forward and fits just fine, there's a bit of a gap but nothing terrible. OP get the best one you can find and definitely go for the windoors if possible!
  6. May 2, 2012 at 2:58 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Spot on. Although, I have sold a camper shell from my Xtra Cab to somebody with a reg. cab and it didn't rub really at all.
  7. Nov 12, 2020 at 2:20 PM
    1stTacoma!
    1stTacoma! Onlyfans.com/death713
    K
    ‘04 4cyl 2.7L Prerunner SR5 Access Cab w/150k miles
    And so nobody answered this guys questions I need to know the answer to his question please. I have an 04 SR5 xcab. Please help out with the dimensions I should look for on the topper/camper/shell. Thank you :)
