What do I look for next ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Poon, Sep 8, 2011.
  1. Sep 8, 2011 at 6:54 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    As soon as I got my Taco about 6 months ago I replaced plugs, wires, filters, just to make sure everything was good on it. Well lately when I hit a hill and the truck down shifts I can feel it starting to skip and sets a CEL light. It idels and runs smoothe otherwise. The first time it set the light I had it scanned and it said cylinder 3 missfire , so I thought coil, and replaced it. Well.. it did it again, this time it said cylinder 6. I replaced that coil. Damn thing is still doing it. I haven't had it rescanned yet, but now it has new plugs, wires and 2 of the 3 coils replaced. What else could cause this skip when it down shifts and revs up ? Note it will also skip if I pull off with it on the floor, I just hardly ever do that so the only time I notice it is on down shifts.
    Thanks
  2. Sep 8, 2011 at 11:45 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Are any of your plugs fouled? Best rescan it too. Brand new plugs can still get fouled. Just an easy thing to (re)check.
    You might want to do a compression test on all your cylinders.
  3. Sep 9, 2011 at 5:17 PM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    I haven't pulled plugs yet because they only have a couple thousand miles on them, but I will do that soon to see if any of them look bad. I just rescanned it and it still says cylinder 6 misfire after I replaced the coil for what I think is #6. I replace the coil fartherest back from the front. That is # 6 isn't it ?
    Code it's throwing is P 0306
  4. Sep 15, 2011 at 11:37 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    Pulled plugs and they looked like they were burning very clean. Ran a tank of fuel through it with seafoam and did the seafoam through the vac line. Started looking for any vac leaks and I haven't found any at this time. Anything else to look into ? There are 2 vac lines on the top of the intake that are just blocked off. Should they be ?
  5. Sep 15, 2011 at 11:49 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I have the same 2 blocked off so im geussing yes, but good luck figuring out youre problem
  6. Sep 16, 2011 at 11:04 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    Thank you.
  7. Sep 16, 2011 at 10:04 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    This ^
    or check to see if your MAF sensor checks out to FSM, within specs.
  8. Sep 17, 2011 at 8:11 AM
    scocar
    scocar hypotenoper
    OP, are you using the stock Denso or NGK dual-electrode plugs?
  9. Sep 19, 2011 at 5:08 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    Plugs are just single post plugs. I can't remember what brand. I would be happy to have the injectors rebuilt. What company will I contact to have that done ?
  10. Sep 19, 2011 at 9:59 AM
    scocar
    scocar hypotenoper
    Do the look like this (dual ground plugs):
    Using single-electrode or other non-spec plugs can cause problems. Just want to make sure this is not a contributing factor.
  11. Sep 19, 2011 at 11:16 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    Not at all. Just regular old school style plugs. I am going to replace them this week I think. The guy at parts store told me it didn't really matter , so I took the cheap route, but I knew better.
  12. Sep 19, 2011 at 6:54 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Its for emissions but it was not used. Only place it would be used is in california thats is questionable( i havnt seen it so i cant say for sure).
  13. Sep 19, 2011 at 7:02 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Toy's run much better with the dual electrode plugs...try one of these and I bet your problem will be solved. :cool:
    Denso plugs - pk16tr11
    NGK plugs - bkr5ekb-11
  14. Sep 19, 2011 at 7:04 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I'm pretty sure you need the twin electrode plug with both gaped appropriately.
  15. Sep 20, 2011 at 5:55 AM
    Poon
    Poon [OP] Member
    Thomaston GA
    98 Tacoma V6
    OK. Thanks. I'll be getting plugs this weekend and swap them out.
  16. Sep 20, 2011 at 6:06 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I swapped out single electrode for the proper dual electrode plugs last fall and truck seems to start much better with a bit better power but the one thing I have been doing and did it in my 289k Jimmy as well was fuel injector cleaner every second or third fillup. It does make a difference and its one of the first things mechanics around here do when someone complains about a loss of power.
  17. Sep 21, 2011 at 11:14 AM
    glamis3000
    glamis3000 Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    i had the same thing it was my 3rd cylinder injector, i replaced all coils and wires and plugs, then did all injectors and that finally fixed my problem runs so much better and im getting better mpg too.. i am actually going to sell my old injectors for 75 dollars.. one of them is bad but for all 6 its not a bad price.. or ill sale you only the however many you want to buy.. they are off of a 96.
