What do I need to lift my truck?
Discussion in 'Suspension' started by TreeFiddy5, Aug 18, 2014.
  1. Aug 18, 2014 at 12:26 AM
    TreeFiddy5
    TreeFiddy5 [OP] Member
    Angelo
    2000 3.4l v6 sr5 Trd
    okay.. well im willing to spend tops maybe 1300 for everything said and done (16 year old minimum wage budget) and im looking for a lift kit. I dont know a lot about suspension but I dont want a spacer kit. The whole reason for this is that I want more travel in the front. I was thinking of buying a set of fox 2.0 coilovers- http://www.autoanything.com/suspension-systems/fox-2-performance-series-coil-over-ifp-shocks
    and then some rear shocks - http://www.autoanything.com/suspension-systems/61A7748A0A0.aspx
    anyway, what would i need to do basically? would installing these alone lift the truck? what ideas do you guys have on a lift, anything helps.
  2. Aug 18, 2014 at 12:38 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Do some more research, but I'll tell you off the bat that you wont get any more travel with an OEM length shock. You'll need extended travel shocks with either a taller coil, or an adjustable coilover, and a leaf pack or add-a-leaf to lift the rear. Simply bolting in 2.0 foxes will give you the lift, but not the travel if they are OEM size.
  3. Aug 18, 2014 at 12:41 AM
    TreeFiddy5
    Angelo
    hm. well I say I want more travel because I just bottom out a lot. I spend more time going faster over rough roads rather then slow crawling.. Would the new shocks help with that? and also is it as simple as "bolting it all on"
  4. Aug 18, 2014 at 12:52 AM
    The Traveler
    SoCal
    The new shocks will have better valving and better spring rate so they wont bottom out as much. Better bumps will also help you.
  5. Aug 18, 2014 at 12:55 AM
    TreeFiddy5
    Angelo
    Thanks, well Ill go ask around at locl 4x4 shops I just wanted some opinions. would you/most people recommend the fox 2.0s?
  6. Aug 18, 2014 at 1:00 AM
    The Traveler
    SoCal
    Never ridden with them, but I like Icons and Kings more than Fox.
