What do I need to supercharge my truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jcarp05, Sep 28, 2020.
  1. Sep 28, 2020 at 3:35 PM
    Jcarp05
    Jcarp05 [OP] New Member
    I have a 2002 3.4L V6 extended cab with a manual transmission as well as about 200,000 miles on it, should I supercharge it and if so, what do I need to supercharge it?
  2. Sep 28, 2020 at 3:39 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are a lot of threads on this topic already. I suggest searching for them and reading up on it.
    Hobbs, 1997tacomav6, TacoBike and 4 others like this.
  3. Sep 28, 2020 at 6:30 PM
    1997tacomav6
    Denver
    Jcarp05[OP] likes this.
  4. Sep 28, 2020 at 6:48 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Probably gonna need a supercharger.
  5. Sep 28, 2020 at 6:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A lot of money.
  6. Sep 28, 2020 at 6:49 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    That was my first thought too. My second thought was a pair of hands that had fingers to manipulate the search bar.
    Dalandser likes this.
  7. Sep 28, 2020 at 6:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No but seriously. Those 3.4L engines are solid runners. That being said, no engine is exempt from making sure things are looking copacetic before throwing a blower on it. Making sure things are copacetic would entail doing a static compression test on it and making sure you are at least 160 psi on all cylinders. A 20 psi variance and I wouldn't even touch a blower at that point as you are just opening the door for further valve or piston rings leakage. A dynamic compression test wouldn't hurt either. You don't want to vary more than 5 psi on the dynamic test, otherwise, don't touch a blower on that either.
  8. Sep 28, 2020 at 7:08 PM
    1997tacomav6
    Denver
    AND plan on replacing the fuel pump with a new one so you know the pump is working at 100 percent,
    fuel filter and get the fuel injectors serviced and cleaned,
    Before you install the supercharger.
    It’s an expensive rabbit hole
    AND you need an AFR Gauge
    AND
    AND
    AND
  9. Sep 28, 2020 at 7:30 PM
    jbrandt
    Justin
    You could just tape a pencil to your forehead and peck at the keyboard, too...
    Gunshot-6A, Wyoming09 and Jcarp05[OP] like this.
  10. Sep 28, 2020 at 11:34 PM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Honestly, I'd do an afr gauge first, stock is just fine if it is in working order with the stock pulley. It can tell you if your pump is not doing enough.
  11. Sep 29, 2020 at 5:48 AM
    1997tacomav6
    Denver
    With An AFR Gauge you will ALWAYS know the health of your fuel system.
    It can be added later or you can do without and never know your AFR numbers.
  12. Sep 29, 2020 at 5:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe.
    At a minimum you need a compression and leakdown test to determine some rudimentary health of the engine. An oil sample to Blackstone labs would be on my list of deciding factors as well.
    Has the clutch been changed?
    Has the diff and connecting driveline been well maintained?
    Are you willing to step up to the cost of premium fuel?
    All things to consider. No use in painting the house if its full of termites.
    Besides the readings provided by others above, I'd suggest at least a good friend who was experienced or very mechanically adept. 2 sets of eyes/hands are very useful on initial projects like this. Of course the other option is paying a pro to do it.
    In terms of parts, you need
  13. Sep 29, 2020 at 1:10 PM
    jbrandt
    Justin
    Yeah, as these other guys have said, you really should ensure that your engine is in tip top shape first.
    Not only will a properly maintained engine maximize the power/efficiency that it's already capable of (might even be enough that you don't feel a supercharger is necessary), it will ensure that it's least likely to blow up when you start forcing more air/fuel inside it.
    My 3.4L certainly isn't a powerhouse, but it's got enough power that I don't feel throwing a few grand at it is necessary. It does what I need it to do.
  14. Sep 29, 2020 at 3:02 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The real Question is Why??
  15. Sep 29, 2020 at 3:05 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    BassAckwards likes this.
  16. Sep 29, 2020 at 3:07 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Coming from 1000 hp funny cars in my younger days If the reason is pure Horse Power Muscle Cars are a better choice then a 4x4
  17. Sep 29, 2020 at 3:09 PM
    jbrandt
    Justin
    Reminds me of the "my 4x4 doesn't corner nearly as well as my 5 series did, should I add a rear sway bar?" type threads.
    Gunshot-6A likes this.
  18. Sep 29, 2020 at 3:09 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    As stated earlier! :spending:
  19. Sep 29, 2020 at 3:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    looks like alot of lameos in here... i boosted my shitbox and it was the best decision ive made. turned a fun truck into a hilariously fun truck.
  20. Sep 29, 2020 at 3:19 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I agree 100% with this. My truck had 260k on it and ran great so I decided to throw a blower on. Turns out it was just an act and shortly after putting the blower on I started having head gasket issues, so I had to pull the blower back off so I could keep driving it.
    If this isn't your daily I say go for it, but if it is, I'd want to do a leak down test, and compression test at a minimum to get an idea as to the health of the motor. The last thing you want to do is spend big money and then just have it cause problems on your daily. But with that being said, you should absolutely supercharge it if everything checks out, you'll fall in love with your truck all over again!
