what do people think about the truxx lift?
Discussion in 'Suspension' started by johnw, Aug 10, 2009.
  1. Aug 11, 2009 at 2:37 PM
    #41
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You don't want a negative rep from me. :spy:
    Wait, are we talking about rep??? :locked:
  2. Aug 11, 2009 at 2:41 PM
    #42
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Let's see...
    $299 for Billy's all around from DSMS.
    Definitely go with an AAL and no blocks, because blocks give a harsh ride and can cause axle wrap. So the AAL would be about $80 from ToyTec.
    And a top plate spacer like Cliff said would only be about $10-$20.
    That'll definitely work too.
    $300 for Billy's all around.
    :popcorn:
  3. Aug 11, 2009 at 2:44 PM
    #43
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
  4. Aug 11, 2009 at 2:46 PM
    #44
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    thanks to everybody for help i will do that and have money left over for my "new" 1955 buick special with 18000 original miles so extra cash woll go to that
  5. Aug 11, 2009 at 2:46 PM
    #45
    Incognito
    VA
    Let us know how it goes!
  6. Aug 11, 2009 at 2:48 PM
    #46
    johnw
    john
    orlando florida
  7. Aug 11, 2009 at 3:19 PM
    #47
    johnw
    john
    orlando florida
    is that bad coils and shocks ?
  8. Aug 11, 2009 at 3:25 PM
    #48
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    I'm not sure what you are asking?:confused:
    If you were to buy the Billy's you'd either have to buy new coils for the fronts or your your stock ones and still need a aal for your rear. This lift will give you your FULL 3" like you wanted and you can mud and wheel. It comes with everything.
  9. Aug 11, 2009 at 3:32 PM
    #49
    johnw
    john
    orlando florida
    no i was saying that to oakly trd or however you spell that because of his comment i just need to call procomp and ask if they have the tsb AAL
  10. Aug 11, 2009 at 5:39 PM
    #50
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    I would have to say that for his uses that kit is fine. It will keep the same factory ride and not stiffen it up. I do not know why people are saying this will stiffen the ride, it can't it is a top plate not preload spacer.
  11. Aug 11, 2009 at 10:40 PM
    #51
    sincitytaco
    Las Vegas
    well there is slightly more travel than the OEM strut will allow so you do get a little more downtravel than you are saying. And it should still top out the strut because I know you do not need to compress the coil to fit them in between so there must be enough room somehow.
  12. Aug 12, 2009 at 7:07 AM
    #52
    mjp2
    NJ
    "Harsh ride" is the term that's been used, not stiffness.
    Don't forget that the shock is now the bumpstop since it will bottom out before the LCA has a chance to hit the factory rubber.
  13. Aug 12, 2009 at 8:57 AM
    #53
    sincitytaco
    Las Vegas
    I was told this was not the case by fat bobs garage. They said it will still use the bumpstop. Even if it does not contact it you can put in a longer bump stop to fix that.
  14. Aug 12, 2009 at 9:04 AM
    #54
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    And there is the key to your statement. Take that sentence out, and your statement is false.
  15. Aug 12, 2009 at 9:14 AM
    #55
    sincitytaco
    Las Vegas
    So are you guys saying this lift will ride bad and be unsafe it the truck is used 99.99999% of the time on the street and the rest on dirt roads. I know people who have used these kinds of lifts for years and never had a single problem with ride or stuff breaking.
    Hell if you have a lease I would do it for sure. I have a lease and have Icons, but if I had it to do over again I would think long and hard about saving some more money.
  16. Aug 12, 2009 at 9:25 AM
    #56
    johnw
    john
    orlando florida
    ok thanks oakleytrd
  17. Aug 12, 2009 at 9:28 AM
    #57
    johnw
    john
    orlando florida
    nope no lease truck was payed for completely before it even left the truck lot
  18. Aug 12, 2009 at 10:27 AM
    #58
    johnw
    john
    orlando florida
    sorry for being so difficult but your dealling with it.
    ok that lift is for the regular leaf spring package i have the tsb i called that website and they didnt know what tsb was they called procomp when i was on hold and procomp didnt know what tsb was ????????/ UGH
  19. Aug 12, 2009 at 10:35 AM
    #59
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I saw something in the October 2009 issue of Off-Road Magazine that has a picture of a Tacoma in a Bilstein 5100 advirtisement that says you can now get up to 2.75" of lift. Maybe there is a new design? You could look into that.
  20. Aug 12, 2009 at 10:36 AM
    #60
    johnw
    john
    orlando florida
    alright thanks will look into that
