What do you have mounted to your PrinSu Roof Rack?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtsohgxx, May 10, 2019.
If you could only choose one ...
  1. Roof Rack Mounted Lightbar
    26 vote(s)
    44.8%
  2. Front Bumper Mounted Lightbar
    32 vote(s)
    55.2%
  1. May 17, 2019 at 10:50 AM
    #41
    FlyingMonkey
    FlyingMonkey Well-Known Member
    2017 Tacoma OR/LB Quicksand
    Leer topper w/ Prinsu racks. Bilstein 5100's & Falken 285's
    thanks, uh...bruh! i appreciate the link. gonna give that a try...much more elegant solution. still might try the EVA foam. found a yoga mat at the discount store made of 5/8" EVA...i can use it to make 2-3 layers of extra material under the deflector, sprayglued together.
    Teegs[QUOTED] likes this.
  2. May 22, 2019 at 9:35 AM
    #42
    FlyingMonkey
    Holy shit...I just got that strip and tried it out. Solved the problem completely. AND, that is one robust strip...clips tightly and takes the curves at the bottom of the deflector like a champ. Thank you! It was a little too thick to keep on the bottom most set of mounting holes...it was rubbing against my truck and didn't want to trap dirt or create wear on the paint...so I had to lift it up one notch, but not to any detriment from what I can tell.
    you simply MUST make a "Use this for your Prinsu" top-level thread and include this product.
  3. May 22, 2019 at 9:46 AM
    #43
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Um... direct from the Prinsu website:
    Hunter399 likes this.
  4. May 22, 2019 at 9:50 AM
    #44
    FlyingMonkey
    well, first...that option wasn't present when I first bought my Prinsu. and second, I talked to them about it after the fact, they said they had the trim, but it sounded like it was a very small bit of trim and didn't reduce the sound very much at all (and it was $25, whereas this was only $9 from Amazon). This trim seems a lot thicker than the one Prinsu sells, or recommended when I talked to them over a year ago.
    Teegs likes this.
  5. May 22, 2019 at 9:51 AM
    #45
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    An RTT, kayaks, stuff, just not a hammock! @AKLA98 :boink: Poor guy.
  6. Jun 19, 2019 at 10:31 PM
    #46
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    Randy, I thought that was an RPG in the right case! I’m reading on my phone from my rack in the sand box! Never considered my long gun Pelican would hold a prop shaft!
    EatSleepTacos[QUOTED] likes this.
  7. Jul 1, 2019 at 6:23 AM
    #47
    Mikenewgun87
    Mikenewgun87 Active Member
    Sparta, Wi
    19 Cement DCLB OR
    Dude, I thought you had a 60mm mortar tube for a second haha.
  8. Mar 26, 2020 at 12:18 PM
    #48
    Facedog703
    Facedog703 Member
    2018 Tacoma TRD Off Road
    What brand is that recovery box? How do you secure it to the rack?
  9. Mar 26, 2020 at 3:21 PM
    #49
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    sand trax
    Recovery gear box
    ARB 2500 awning with detachable tent.94E66B39-5CA6-4D28-83A0-B76450759843.jpg
    TacoTim85 and Fixxxer like this.
  10. Mar 26, 2020 at 7:20 PM
    #50
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    My wife and kid ...
  11. Jan 16, 2024 at 8:13 PM
    #51
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    I'm wanting to hook up an axe to my prinsu as well. What mounts are you using for your axe?
