What do you think about this lift set up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 619ivanru, Feb 22, 2013.
  1. Feb 22, 2013 at 1:48 PM
    619ivanru
    619ivanru [OP] Well-Known Member
    San Diego
    08 prerunner offroad package
    So this is the set up I want, I have been researching...there is too much info so this is the best I could come up with
    Front:
    MT Spindle
    Fox 2.5 coil over
    extended brake lines
    Rear:
    Fox 2.0
    AAL 1.5 in
    Wheels and tires:
    Toyo MT 305/70r16
    KMC Enduro 16in
    Will it all fit without any problems?
    Will I need to upgrade to aftermarket UCA?
    Is there any way to add fake beadlocks to the Enduro rims?
  2. Feb 22, 2013 at 2:52 PM
    619ivanru
    San Diego
  3. Feb 22, 2013 at 2:55 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    With a lift of 3 or more inches you really need UCA's to keep your alignment where it should be.
  4. Feb 22, 2013 at 3:18 PM
    619ivanru
    San Diego
    is it recommended or necessary?
    would the tires fit ok?
  5. Feb 22, 2013 at 3:24 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    How much lift is the spindles gonna give? If you only go up a bit with the coilovers then no. But if your going really high with the coilovers it would be a yes.
  6. Feb 22, 2013 at 3:27 PM
    Manwithoutaplan
    ID
    Looks good but i would look into leaf pack instead of AAL.
  7. Feb 22, 2013 at 3:31 PM
    619ivanru
    San Diego
    spindles are 3in
    coils will be set at 0
  8. Feb 22, 2013 at 3:38 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    or progressive aal at worst....not a fan of single aal "jolts" when driving over rough stuff.
    + some Wheelers bump stops
  9. Feb 22, 2013 at 3:41 PM
    619ivanru
    San Diego
    bump stops?
  10. Feb 22, 2013 at 3:43 PM
    XXXX
    sKiP
    05 Prius
    yep these
  11. Feb 22, 2013 at 3:44 PM
    XXXX
    sKiP
    05 Prius
    oh and extend the rear brake lines as well if you get a new leaf pack. actually do them anyway regardless.
  12. Feb 22, 2013 at 3:49 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    X2
    and if you are spending the money on fox, dont get an aal in the rear. Get new leaf packs. I would also recommend new ucas
  13. Feb 22, 2013 at 3:53 PM
    Manwithoutaplan
    ID
    I would look into the All pro Leaf pack.
  14. Mar 3, 2013 at 11:47 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    at what point in a lift do you need extended brake lines?.. my set up is bilstein 5100s all around front set at 0.85 and skyjacker AAL in rear..
  15. Mar 3, 2013 at 1:10 PM
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    3+ id recomend them for the rear or any LT set up.
  16. Mar 3, 2013 at 2:06 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    whew.. just under it and she is a road queen if u can't tell by my sig..lol
  17. Mar 3, 2013 at 2:24 PM
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    I have 3" on my rear and wheel the crap out of it and @ full droop I still have slack in my lines.
