What do you think about this?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by andy2003, Aug 27, 2010.
  1. Aug 27, 2010 at 10:21 AM
    andy2003
    andy2003 [OP] Well-Known Member
    Andy
    WV
    16 4Runner SR5
    Just to see what everybody thinks. I just changed my oil and swithed to mobil one full synthetic 5w30. I stayed with a toyota filter and just wondered what eveybody thought about letting it go 5000miles between changes like the oil calls for. I had a 07 tacoma and of course they all go 5000 now on changes but wondered on my 03 if I should let it go this long. I put almost 2000 miles a month on my truck all highway so it wont take 2 1/2 months till the next change anyway. Let me know what you think thanks.:confused:
  2. Aug 27, 2010 at 10:34 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I think you'd be fine for sure
  3. Aug 27, 2010 at 10:37 AM
    andy2003
    Andy
    WV
    16 4Runner SR5
    Thats what i was thinking cant hurt keep an eye on the oil starts to look bad change it.
  4. Aug 27, 2010 at 7:41 PM
    my6
    my6 Well-Known Member
    houston,texas
    04 prerunner 2wd non trd
    i,m probably gonna get fried on this but i,m at 6k on my 100% synthetic and it,s crystal clear clean on the dip stick tonight. 90% highway miles. i planned on changing it this weekend anyway because it,s due. fire away guys.
  5. Aug 27, 2010 at 7:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no reason for anyone to fire away. i know some folks who run 10 to 15k on oil changes. i'd never do that......but some do. 6k aint too bad.
    i do all my oil changes at 5k miles.
  6. Aug 27, 2010 at 8:04 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    Highway miles are not as tough on your vehicle as stop and go city driving. Id imagine you could easily go twice as far between changes.
  7. Aug 27, 2010 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That has been my agenda for quite some time. If it were dino remains it would be different. Synthetics are great and M1 is awesome. I use the Toyota filter also.
    I have heard that synthetics (especially M1) are good for at least 10K. It is advised that the filter be changed before that though. I've read about folks that do just that, switch out only the filter at 5K. Might have to top off the oil cause there is some loss when you switch out the filter. You should be fine at 6K.
  8. Aug 27, 2010 at 11:02 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    i used to spend the money for moblie 1 and change the oil every 5-6k. switched to mobile clean 5000 and still change the oil every 5-6k.
  9. Aug 28, 2010 at 2:54 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    As long as you keep using a quality filter (the Toyota one you used, Mobile 1, Napa Gold, etc) and stay away from the Walmart and cheaper filters, I think you'll be plenty fine at 5-6k. With the synthetic and a healthy engine, you could easily go quite a bit longer if you were to just change the filter regularly.
    If you're really worried about it, send in an oil sample to http://www.blackstone-labs.com/ at 5k and see what they tell you about your oil quality, as that is the only true way to know how healthy your oil is.
    I'm on the other end of the spectrum with driving. I'll be lucky to drive 6k in a year, but since there are other routine maintenance items that should be checked regularly, I do it all twice a year. Little bit of a waste of money, but it makes me feel better to keep it maintained. Peace of mind has quite a bit of value as well.
  10. Aug 28, 2010 at 6:20 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    If you are running Synthetic oil and change it at anything under 5,000 you are throwing your money away. 7,500 is about right if you're running full Synthetic.
  11. Aug 28, 2010 at 10:17 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    +1 on Blackstone
    Always good to get a SOAP sample. We do on aircraft all the time. Why not your car?
    I still run dino oil and change every 3000k. Oil is cheap.
  12. Aug 29, 2010 at 5:58 AM
    andy2003
    Andy
    WV
    16 4Runner SR5
    Thanks for the tips guys makes me feel better about going at least 5000 on a oil change.
  13. Aug 29, 2010 at 6:12 AM
    supadave888
    supadave888 Well-Known Member
    morgan city La
    4x4 trd sr5
    ive went 10 before and the oil still didnt look that bad but i change mine at 8,000.. with synthetic you can easily go 7 and 8..
