What do you use for diff fluid and transfer case oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matt Luce, Oct 30, 2024.
  1. Oct 30, 2024 at 4:34 PM
    Matt Luce
    Matt Luce [OP] Member
    HondaGM likes this.
  2. Oct 30, 2024 at 4:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Oct 30, 2024 at 4:45 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  4. Oct 30, 2024 at 4:46 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Any good quality 75-90 in the diffs is just fine as far as I'm concerned.
    NoCoTacoMan, HondaGM and TnShooter like this.
  5. Oct 30, 2024 at 4:47 PM
    kimosabe15
    kimosabe15 Well-Known Member
    2015 DCSB SR5
    I used Red Line 75W85 on the differentials and Motyl Gear 75W90 on the transfer case
    HondaGM likes this.
  6. Oct 30, 2024 at 7:15 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Ranch Dressing, but only the organic stuff.
    Matt Luce[OP] and HondaGM like this.
  7. Oct 30, 2024 at 7:32 PM
    TacoTuesday1
    FL
    Tcase I’d probably put syn 75w90 gear oil
    Diffs I have what ECGS recommends 75w140 figure they know what they’re talking about.
    HondaGM likes this.
  8. Oct 30, 2024 at 7:35 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  9. Oct 30, 2024 at 7:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    w/e the cheapest full synthetic 75w-90 is easily available changed at regular intervals will be better than ANY fancy high end super expensive gear oil changed only here and there.
    After inital breakin of front / rear / tcase change, realistically a 30-50k mile rear diff OCI and 60-100k mi tcase / front diff OCI depending on how heavily used 4wd is / loaded the truck is is plenty.
  10. Oct 30, 2024 at 7:55 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Good call… which part of that concoction is organic?
  11. Oct 30, 2024 at 8:09 PM
    NoCoTacoMan
    NoCoTacoMan Well-Known Member
    Brian
    Northern Colorado
    2010 TRD Sport V6 4WD Ext Cab Long Bed
    Stockish
    Greetings. I'm like most here I believe. The least expensive synthetic APL GL-5 75W-90 gear oil. In all the years I've owned a jeep or taco I can't say I've ever seen or noticed a difference. Like what was mentioned above, as long as you are using something the same as/similar to what is specified, probably the most important thing is to follow the service intervals.
  12. Oct 30, 2024 at 8:34 PM
    nd4spdbh
    SoCal
    THE ONLY CAEVAT is if you have an 08 or older truck with the mechanical LSD.... which you would need the LSD additive (which damn near most full syn gear oils have these days)
