what does a spindle lift do?
Discussion in 'Suspension' started by t.hornstra, Jul 22, 2009.
  1. Jul 24, 2009 at 12:31 AM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    so i found that the spindle lift i had posted is for "5 lug" will it fit on my prerunner? (6lug)??
    ChadsPride likes this.
  2. Jul 24, 2009 at 1:05 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I very highly doubt it.
  3. Jul 24, 2009 at 1:16 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    hey if i were to get spindles would that mean i would have to run 17" rims or bigger? or am i good with 16s
  4. Jul 24, 2009 at 10:40 AM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    TC spindles give 3.5 inches not 4 inches. And as far as the benefits of spindles, the extra lift is the least impressive thing about them. You can get spacers and body lifts, just for lifts. The way the spindles keep the stock geometry and suspension travel are the biggies. With spindles you get the ability to have more travel than with any brand of coil, spacer, coil-over or adjustable shock lift alone. Especially when you pair up the spindle with some nice coilovers and uca's. Long travel is the next step up from spindles. And if you have a 4X4 none of the spindle ideaology matters anyways.
  5. Jul 24, 2009 at 10:55 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I believe the Camburg spindles are 4" of lift.
  6. Jul 24, 2009 at 11:05 AM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    okay so im seeing alot of TC and Camburg spindles, but you guys all have 2nd Gens..
    any available for 1st Generations?!
  7. Jul 24, 2009 at 1:57 PM
    bermise
    Houston
    08 TRD off road
    You are correct. :thumbsup:
  8. Jul 24, 2009 at 2:03 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    ok so i get the tc spindles and get 3.5 inches of lift, now will that off set my 3 inch coil over or add to it?
  9. Jul 24, 2009 at 2:07 PM
    bermise
    Houston
    08 TRD off road
    Are your coilovers adjustable? The lift from the coilovers is in addition to the spindle lift. My front set-up, for example, can be at 3.5"-7" inches and everything in between by adjusting the coilovers. So unless you want 6"+ of lift up front you will need adjustable coilovers if you run the spindles. I hope that makes sense
  10. Jul 24, 2009 at 2:18 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    yes toytec adjustable coils, do u like your set up and how it rides, are u a 4x4
  11. Jul 24, 2009 at 2:24 PM
    bermise
    Houston
    08 TRD off road
    4x4's cannot use the spindle lift from TC or Camburg. And no I am 2wd.
    I like my setup much more now than when I had OME coils and Toytec spacers.
  12. Jul 24, 2009 at 2:29 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    how much lift do u have in the back? and what do u have back there, sry for all the questions just trying to think things out
    Xrs-fsho and ChadsPride like this.
  13. Jul 24, 2009 at 3:18 PM
    bermise
    Houston
    08 TRD off road
    2.75 inches in the rear. LOOK at my signature. It lists all my suspension mods.
    VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
    MightyMouseTom and ChadsPride like this.
  14. Dec 10, 2013 at 10:10 AM
    Mcarcaba
    Mcarcaba Member
    St. Aug Florida
    04 Trd Sr5 3.4l 5speed
    Billys..for now
    So can you spindle lift a 4wd? And what size does she have on hers?
  15. Dec 18, 2013 at 4:57 PM
    #35
    cpeterson24
    cpeterson24 Well-Known Member
    Christian
    SoCal
    '13 TRD Sport MGM
    Billies all around, 885's up front, 1.5" AAL in the rear ,Pro Comp 7032's wrapped in BFG AT 265/75/16, Locking rear cargo bins, interior LED's, Volant CAI with ram skewp, 5% back windows 20% tint up front, ImMrYo rear-view mirror mount, flowmaster 40 cut after axle drop, 886 reverse light mod, blacked out emblems, Grill Craft MX mesh upper and lower, UltraGauge, 10" JL sub behind drivers side rear seat
    you cannot use a spindle lift on 4WD. 2WD only
  16. Sep 27, 2016 at 9:14 PM
    #36
    Shizz
    Shizz Jack of all trades master of none
    Shane
    Honolulu
    O5 DCLB
    None
    New to forums and been hanging around reading threads pertaining to issues that I have with my ride. I am blown away with the info. Good job everyone! I just picked up my 2005 and was trying to level up the front because it is too low compared to back. I carry some payload sometimes as far as tools for construction and materials. But will spindles keep my ride when lifting compared to say a set of 5100's around or coiloverz. This off-road suspension thing is kinda involved as far as set up. Thanks for any help
