what does tsb mean??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meckleystephen, Jan 30, 2010.
  1. Jan 30, 2010 at 1:41 PM
    meckleystephen
    meckleystephen [OP] My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    i know i sound like a noob but i have no idea what it means also dc???
  2. Jan 30, 2010 at 1:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    technical service bulletin
  3. Jan 30, 2010 at 1:44 PM
    meckleystephen
    Stephen
    York, PA
    what exactly does that mean or refer to
  4. Jan 30, 2010 at 1:48 PM
    meckleystephen
    Stephen
    York, PA
    thanks now that u say it i feel like an idiot but that has been blowing my mind
  5. Jan 30, 2010 at 1:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    different problems that are related to your car or truck, that toyota has a fix to, that is really mostly privvy to a dealership,incase complaints are made by customers...the dealership will go by the tsb and fix what needs done. for the most part anyway.
  6. Jan 30, 2010 at 1:50 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    If you have less than 36k miles, search for "leaf spring tsb", print it out when you find the actual Toyota document, and get it done. I hate not having it because my 3-leaf springs absolutely suck, but I'm above 36k and out of luck.
  7. Jan 30, 2010 at 1:51 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    A TSB can refer to a repair or an upgrade that will make the truck "better". It's not a recall, but something that most likely should be done. A lot, if not all, of the time the work will be covered by the warranty, if you still have it. On the flip side, you almost have to prove to the dealer that you need a certain TSB completed-- it depends on the place.
  8. Jan 30, 2010 at 1:53 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    dc...double cab
    tsb...technical or Toyota service bulletin. As far as I know they're a service bulletin update the Toyota mechanics go by for fixing recurring issues that have been documented that are not safety related like when a recall is issued.
  9. Jan 30, 2010 at 2:00 PM
    meckleystephen
    Stephen
    York, PA
    some people talk about lifting the rear tsb???
  10. Jan 30, 2010 at 2:01 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    See that is one of the problems with TSB's you can only get it under the 3 year 36,000 mile warranty which is BS since Toyota has been using known weak springs for longer then that trying to keep the soccer Moms from complaining about buying a truck and then having it ride like a truck
  11. Jan 30, 2010 at 2:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    toyota replaces the rear 3 leaf pack with a new better 4 leaf pack....and some add an aal(add a leaf) to it.
  12. Jan 30, 2010 at 2:11 PM
    meckleystephen
    Stephen
    York, PA
    does anyone have any pics of this before and after and i am sure after they do that u could probally throw a 2 inch spacer from toytec to level it up
  13. Mar 2, 2010 at 6:27 AM
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    I had no idea what TSB meant till I read this. Now its making me wonder (along with the other thread) if this is something that I need to get done to my truck. Sorry for the noobness.
  14. Mar 2, 2010 at 6:29 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
  15. Mar 2, 2010 at 6:30 AM
    zimm52
    nothing yet!
  16. Mar 2, 2010 at 6:32 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Alrighty :D
  17. Mar 2, 2010 at 6:32 AM
    zimm52
    nothing yet!
    Thanks!!
  18. Mar 2, 2010 at 6:33 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    No problem. Just trying to help in a humorous way lol
  19. Mar 2, 2010 at 7:26 AM
    zimm52
    nothing yet!
    Oh I got it! Might need more coffee though!
  20. Aug 16, 2010 at 3:34 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    *spent 15 minutes researching TSB before I found this post*
    Glad I found this explanation. Wish I could get my crappy, ~straight leaf pack replaced for free.
