What does TSB stand for?
Discussion in 'Suspension' started by mball, Mar 11, 2010.
  1. Mar 11, 2010 at 4:54 AM
    mball
    mball [OP] Active Member
    Texas
    01 PreRunner
    Blisten 5100s up front and spacers in rear. Painted grill. Leer color matched topper.
    I am looking at lifting my truck a little bit and have been reading some of the threads on here and people keep referring the the TSB rear. I know it can stand for technical service bulletin, but that didn't seem to make any sense. Any help??
  2. Mar 11, 2010 at 4:57 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    In this case it has to do with the leaf springs. It fixes the sag in the rear which results in loading the bed with weight. In my case, I have a 3 leaf spring which isn't sufficient to keep the rear from squating when I put weight in the bed.
  3. Mar 11, 2010 at 4:59 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    It's something that Toyota knows about and can be fixed, but only if you complain about it. Most common seem to be 2nd gens with automatic transmissions that shift badly and 2nd gens with weak rear springs. Toyota will fix them, but they do not require a recall as it is not a safety issue in their opinions.
  4. Mar 11, 2010 at 5:20 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    There is no TSB for your 01.
  5. Mar 11, 2010 at 6:07 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Is there a TSB for the 06 Double cab I just bought? Thanks for the info..
  6. Mar 11, 2010 at 6:11 AM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
  7. Mar 11, 2010 at 6:23 AM
    DOERanger
    DOERanger Well-Known Member
    Jordan
    Knoxville, TN
    2010 DC Sport SB
    No Mudflaps, Fog lights on all the time, Map light/Dome light mod, Door sill protectors, In-channel window guards, Re-badged and sock-monkeyed,many more to come.
    To Shit Bricks
  8. Mar 11, 2010 at 6:28 AM
    Jimmyjohn
    Jim
    06 SR5 4x4 DLB CAB
    Angus Thanks I printed the list out. That's a big help for someone who has never owned a Toyota before.
  9. Mar 11, 2010 at 9:01 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    So how much do you want to lift your rig?
    Do you want to do the standard 3 inch's in the front and 2 in the rear or a little less? What is your over-all budget?
  10. Mar 11, 2010 at 2:43 PM
    mball
    Texas
    01 PreRunner
    I would like to lift it maybe 2.5 to 3 inches. Not sure yet. If I use the Biltstein shocks what do I do to the rear end? What is this AAL that I keep seeing everyone talking about? I've got about $500 to spend.
  11. Mar 12, 2010 at 7:36 AM
    Toytec Lifts
    Rocky Mountains
    If you go with the Bilsteins up front, you can get your 2.5 inches of lift. In the rear, we make a custom long AAL with anti friction pads that work very well with your leaf pack for a lift of 2 inches. With an 01, like mine, I had to replace my leaf pack because my pack actually had a reverse arch to it. I went with the Custom Alcans because my truck had a shell on it and I wanted to dial in my load capacity a little bit. But OME makes a great full leaf pack under the DAKAR name. But with your budget, you will probably have to wait on those, but can upgrade down the road.
    We should be getting the shocks in next week.
    [​IMG] <<-- click-able
    Hope that helps.
  12. Feb 28, 2012 at 4:17 AM
    record catfish
    record catfish Shaka Bro
    Chuck
    NC
    09 DCLB 4x4 SR5 TRD Sport
    None yet. Finally joined to read and respond to the "how to" forums :D
    i have a 2nd gen with automatic transmissions that shifts badly from 1st-2nd, do they know why and can they fix that?
