What else do I need to install front 5100's
Discussion in 'Suspension' started by SR54x4, Aug 22, 2010.
  1. Aug 22, 2010 at 11:58 AM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    My front Billy 5100's will be coming in later this week and I want to install them this weekend coming up. I read on the DSM website where I ordered them from that they do not come with stem bushings. What does this mean?
    Also are there any other parts I will need to install them properly? I plan to set them at 1.75" on my 2010 Access Cab 4x4 SR5
  2. Aug 22, 2010 at 3:04 PM
    SR54x4
    Mark
    Hudson Valley
  3. Aug 22, 2010 at 5:30 PM
    Seener84
    Seener84 Well-Known Member
    Sean
    Denver, CO
    10 DCLB SR5 4x4
    Leer 100R
    bump. I'm interested too
  4. Aug 22, 2010 at 7:35 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    Nah they come with everything you need. The bushing is already installed in the bottom and the ones for the top are fine to reuse from the OEM assembly as long as they're not cracked, rotten, torn, etc. Good luck!
  5. Aug 23, 2010 at 1:45 PM
    SR54x4
    Mark
    Hudson Valley
    Sweet thanks for the response. I would say the bushing is fine to re use since the truck only has about 6k miles on it. Would you agree?
  6. Aug 23, 2010 at 4:03 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Absolutely. Just did mine with 43k miles and the bushing looked perfect still.
  7. Aug 23, 2010 at 4:06 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    you wants to get the spring compressors if you dont have them
  8. Aug 23, 2010 at 5:19 PM
    SR54x4
    Mark
    Hudson Valley
    well i don't have them but i will be doing this project with a friend of the family who is a mechanic and i told him what i needed done so i think he should have everything. i just want to make sure i have all the right parts so this install goes quick and easy.
  9. Aug 23, 2010 at 6:33 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Is an alignment needed after this too?
  10. Aug 23, 2010 at 6:37 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    It's a good idea to get an alignment done afterward if you're lifting... and if you're putting 5100s on I assume you're lifting at least a little bit :D
  11. Aug 23, 2010 at 6:40 PM
    johnw
    john
    orlando florida
    well just double check on the spring compressor would suck if they didnt have them
  12. Aug 23, 2010 at 7:15 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You might find these links useful.
  13. Aug 24, 2010 at 4:16 PM
    SR54x4
    Mark
    Hudson Valley
    thanks for these links! i needed to know what specs too torque everything too so they will come in handy. ill also double check on the spring compressor.
    also, yes it is recommended that you get an alignment afterwards. im doing the shocks before the tsb because i already worked it out with the dealership that they do a front and rear alignment during the tsb.
