What gas mileage you get towing?
Discussion in 'Towing' started by 05RedTaco, Sep 17, 2012.
  1. Oct 7, 2012 at 11:32 AM
    turbo325ii
    turbo325ii Active Member
    Brett
    Provo
    06' Double Cab TRD off road
    none
    +1 Thats why I want a pop up trailer.
  2. Oct 7, 2012 at 9:23 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I hear you turbo.
    I want a TrailManor but MAN, those dudes are pricey.
  3. Jan 17, 2013 at 6:01 PM
    lotsip
    lotsip Well-Known Member
    cape cod, ma.
    '12 Tacoma Access cab, 4x4, off road, v6
    wdh, sway bar, firestone air bags
    Nice looking rig! I came very close to buying that exact camper last week! I chickened out and got a hard sided pop-up , the A122, by Forest River/Rockwood, instead.
    How do u like the Camplite so far ?
    here are some pics of the A122, picking her up tomorrow.
  4. Jan 17, 2013 at 8:20 PM
    MGM Tacoma
    MGM Tacoma Well-Known Member
    Dunn NC
    13 DCSB MGM TRD OR
    15-16 hwy at 70-75, 6x12 open trailer
  5. Jan 19, 2013 at 7:29 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Around 15 mpg at 65 mph towing 5500 lbs. The difference tends to come from which way the wind is blowing. As a rule of thumb it is always blowing against me.
  6. Jan 26, 2013 at 10:00 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Have been testing fuel economy for a few months towing a 1500lb CampLite 11RD with two Kayaks mounted on pickup shell. Last weekend towing through Charleston SC averaged 18.5MPG @ speeds up to 50MPH. With no wind got 17.5MPG @ 53MPH average in 4th gear. Heading home on the interstate @ 55MPH in 4th gear @ 2500 RPM with about 10MPH headwind, only got 15.5MPG. Fuel results from ScangaugeE. The above results in eastern SC (no mountains) with a 2.4L/manual 5 speed. Can get up to 31MPG with this Taco empty without Kayaks on the shell.
  7. Mar 5, 2013 at 10:34 PM
    Rocknroll
    Rocknroll Well-Known Member
    Devin
    Ventura County, CA
    2020 TRD Offroad DCLB 4x4
    A new one was way out of my price range. I ended up finding a five year old 2720 for 16,000.[/ATTACH]
  8. Mar 16, 2013 at 2:32 AM
    Tuckaseetacoma
    Tuckaseetacoma My toy taco
    Gary
    Fort campbell
    Worktoycoma
    Toolbox , dog poo and one bullet hole! Three inch aal,overload spring pack for towing Chevy coils ,and leveling kit up front Spidertrax 1.25 spacers 285/75r16 bfgat with extra siping for rock grips Demello bumper Warn m8000 commercial grade winch with bigger spool Cb in cab Toolbox light Band-aid on door ding Anytime on backup camera Oil cooler and aftermarket trans cooler from desert rail High lift jack mount amid a custom block and tackle for side pulls
    Truck weighs empty 2800 or so . It's a 2011 taco dbl cab lb with three inch lift aal spring pack an 295 bfg at with Demello bull bar and winch. Before mods I got 20 empty on the highway ,17 on interstate going 78 . Now empty I get 17 on interstate .
    Towing my 18 ft utility trailer that weighs 2k empty and 3 k with two Polaris 4x4s on it i get any where between 10 to 15 on a 700 mile trip to Texas twice a year.
    If you have oversized tired don't forget to factor in the mileage you lose on the odometer . I lose ten percent when I do my mileage.....I.e; if I go 200 miles on 14 gallons I have to add twenty more mile to the odometer reading. Before I divide for the mpg. The bigger tires make less revolutions per mile so your odometer won't record the correct distance travelled!
    I didn't think of that at first and I thought my milage was really bad .but it was not that bad . Our tacos get the same milage towing as most trucks get empty
  9. Mar 19, 2013 at 10:59 PM
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    How! I struggle to get 20mpg in my 2012 4cly when shifting at 2500rpm... How are you getting 31?
  10. Mar 20, 2013 at 3:50 AM
    exploringcarolina
    Bill
    North Carolina
    Travel back roads around 50 to 55MPH in 5th gear. Non mountain areas, no Kayaks on top of shell, A/C not operating, tire pressure @ 40PSI, nothing in the back of bed, not maintaining speed up hills (slowing down), gaining speed down hills, and not towing anything. Can exceed 31MPG driving like this. My Taco is stock except for Leer Shell, Class III hitch, Firestone air bags, ScanGaugeE, and 7 pin electrical connector. Run Synthetic transmission/differential lubes with 5W30 dino in the engine. My 2003 Standard Cab 2WD Taco is smaller & lighter than late model Tacos. My Taco empty curb weight without shell is 2750lbs according to the following link.
    Have noticed fuel economy is terrible "until" engine reaches normal operating temps indicated on stock temp gauge. Will check normal operating temps with ScanGauge out of curiosity.
    Here are specs found on line for the 2003 Taco.
    http://www.new-cars.com/2003/toyota/toyota-tacoma-specs.html
    Here's a 4 cylinder Taco MPG thread:
    http://www.tacomaworld.com/forum/4-cylinder/174620-4-bangin-fuel-sippin-full-tank-challenge.html
    Checked engine operating temp today and it runs @ 175F
    Checked RPM today @ 50MPH is 1850 and 55MPH is 2025 in 5th
  11. Mar 20, 2013 at 8:35 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Looks like you have this down to a science. I have a 2012 AC 4x4 with sliders on it it's a 5spd and I'm in MD so the gas is probably full of corn
  12. Mar 21, 2013 at 5:55 AM
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    Congrats, nice trailer!
  13. Mar 21, 2013 at 6:17 AM
    exploringcarolina
    Bill
    North Carolina
    Been learning a lot from folks on this forum. The ScangaugeE was a lot of help showing me where to change my driving habits to get better fuel economy when towing or without trailer.
    Checked out your build thread and you have a "very" nice Taco!
  14. Mar 21, 2013 at 6:34 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Pulling 2 four-wheelers (a Honda Rincon and a midsize polaris) I get around 13mpg average going ~200 miles
  15. Mar 22, 2013 at 11:21 AM
    #35
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    2005 DCSB w/towing package and w/URD TCAI
    Trailer = Jayco Sport 165; 2800lbs dry
    Drove 170 miles from 7000ft to 1500ft and got 14mpg
    Drove back and got 11.5mpg
    This was my first time towing this trailer with this truck so I was "learning" on the way down.
    I would like to tow this on a stretch of relatively flat road to see what I would get.
    I also felt like it was tough to get up to 70mph most of the time and not have the RPMs at 3000. What was everyone else's RPMs?
  16. Mar 24, 2013 at 8:04 AM
    #36
    Kaos
    Kaos Member
    Lake Country
    Tacoma
    Stock but upgrades coming
    Nice rig! How does it tow? I'm new to the Tacomas and just purchased a 4,400 lb dry weight tt. After towing home from the rv dealer I'm thinking I now need a tow rig. The truck seems gutless when empty so I think it just shouldn't be used for towing. Once I fill trailer with water/cargo will probably be 5,500lbs can't imagine going up a hill.
    Did you install a performance chip or something?
    Thanks
    Ken
  17. Mar 24, 2013 at 11:12 AM
    #37
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I normally get 14-15mpg city/hwy mix.
    This weekend I was towing a 1200lbs u-haul trailer, loaded to 3000lbs gross weight. The truck has a fully loaded bed, 4 passengers, and all their personal stuff.
    Amazingly, I'm averaging a consistent 16.76 mpg on mountainous curvy roads going 55-60mph. My transmission is shifting at much lower RPM's and seems to be adapting extremely well to these conditions. I'm blown away by my numbers.
  18. Mar 25, 2013 at 6:42 AM
    #38
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    I have a 24ft HiLo 4200 empty, plus 300 lb motorcycle in the bed that BluTaco pulled to Corpus Christi and back to beautiful NE Iowa where it is still winter. maintaining 60mph as much as possible 12.3 on the way down, maintaining 65 as much as possible on the way back 10.8 No problems with the moderate grades of the Flint Hills in KS but was down to 3rd and 4000 rpm a few times.
  19. Mar 25, 2013 at 12:37 PM
    #39
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    Nah, my drivetrain is stock. I think it pulls pretty good. Not much different than the 05 f-150 5.4 liter that I traded for the Tacoma. I rarely if ever tow with any water on board. I fill the fresh water when I get where I am going if there aren't fresh water hook-ups where I am camping. I also dump my waste tanks before getting back on the highway. It ain't no cummins diesel, but for the ease of around town driving and commuting gas mileage I will tow a little slower over the mountain, but on flat ground or rolling hills I can tow faster than my wife wants to ride
  20. Apr 1, 2013 at 5:01 AM
    #40
    exploringcarolina
    Bill
    North Carolina
    Just got back from another camping trip. This is the second trip we took the bicycles on hitch rack between the Taco & Travel Trailer. Started using a 2" drop/extended hitch on the previous camping trip because it works with the bicycle rack instead of using the 3/4" lift hitch.
    On the last camping trip learned I could tow in 5th gear up slight grades and never had enough power when using the 3/4" lift hitch in the past. By lowering the hitch, it "must" have decreased TT wind resistance. I still have to use 4th gear on steeper grades, but now use 5th gear the majority of the time on interstates.
    Found the fuel economy improved to 17MPG @ 60MPH average going 65MPH down hills and 55MPH up hills in non-mountain areas in central Carolinas.
    Additional info: Approximate weight of the CampLite 11RD TT, Bicycles/rack, Kayaks/rack, and additional camping gear in the truck bed is probably 2000lbs. MPG results using ScanGaugeE with a 2003 2WD 2.4L 5 speed manual Taco with Firestone air bags on the rear differential. It was not windy during this trip. Tire air pressure cold 40PSI Taco & 50PSI TT. Best fuel cost found in SC @ $3.32 per gallon.
