What gauge wire do I need for fridge circuit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Dec 14, 2018.
  1. Dec 14, 2018 at 11:05 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’ve got my fridge mounted in the bed near the tail gate.
    I don’t recall how many amps it draws, I’ll have to check in the a.m., but can someone tell me what gauge wire I need, and what size fuse? I am currently only using the stock battery but will be adding a second in a couple of months. To help keep the battery charged I’ve got a 100w solar panel on the roof.
    Also wondering if I need to run the neg all the way back to the battery (can I just run negative to chassis somewhere closer to the fridge?).
  2. Dec 14, 2018 at 11:21 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You really need to know the amps to know how to wire this because if you use too small of a gauge, the refrigerator won’t work well or worse :bananadead:
    Running the negative to a ground (with at least the same gauge wire as the positive conductor) on the battery is preferable to using the frame when dealing with higher amp circuits.
    Use this chart to help figure your wire gauge based on length needed and load (amps): https://www.google.com/amp/s/www.engineeringtoolbox.com/amp/amps-wire-gauge-d_730.html
    Also, note that your 100w solar panel will work to top off the battery, but also check to see it it will keep up with daily use of the fridge:
    amp = watt / volt
    amps = 100W / 12V = 8.3333A
    And, since you are only using one battery, get a jumper pack just in case you chill your beer for too long! I made that mistake, but it was a good one- I was camping on a beach in Baja California with a girlfriend and we had the place to ourselves with plenty of supplies, so a dead battery was fine for a couple days. :)
    SR-71A, Rujack[OP] and Fluffymonkey like this.
  3. Dec 14, 2018 at 11:24 PM
    Rujack
    Ok, that’s what I figured, on all accounts.
    I’ll have to check the amperage in the morning.
  4. Dec 14, 2018 at 11:27 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    need to know the specs of your fridge. should have amps listed on it. and there are numerous charts online to help you determine wire gauge. depends on you length of run from AND back to the battery. As said above I wouldn't use the frame as the ground for high current uses.
  5. Dec 14, 2018 at 11:42 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s not just amps but also length of wire as well, single wire, bundled etc
    Wsteven and synaps3 like this.
  6. Dec 14, 2018 at 11:59 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Fridge current < fuse rating < wire rating. The fuse protects the wire not the fridge.
  7. Dec 15, 2018 at 2:26 AM
    jcos112
    jcos112 Well-Known Member
    12
    r1200gs4ok likes this.
  8. Dec 15, 2018 at 8:32 AM
    Rujack
    13a, maybe a 25’ run from batt to fridge
  9. Dec 15, 2018 at 8:34 AM
    OnHartung'sRoad
    One more suggestion- use larger guage cables than you think you will need for future mods back there. Then iin your camper, use a ground plate and a fuse block to terminate your power cables in the camper so you have a way to attach other goodies. Many out there, like these, but there are some smaller ones available, too:
    https://www.amazon.com/dp/B001P6FTHC/ref=cm_sw_r_cp_api_i_i1sfCbND4S79Z
    https://www.amazon.com/Blue-Sea-Sys...ocphy=9031498&hvtargid=pla-436661250661&psc=1
    I also put a fuse block between the possitive terminal of the battery and the positive cable- there are several types, including circuit breakers with power switches too. They make it a lot safer in case your long power cable shorts.
  10. Dec 15, 2018 at 8:40 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    If you have the owner's manual for the fridge you can find that info in there. Or prolly on the fridge manufacturer's website.
  11. Dec 15, 2018 at 8:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    I ran 10ga from the battery to under the drivers seat on mine. Works fine.
  12. Dec 15, 2018 at 8:52 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    For the dometic 3 way fridge, Id run 10 or 8 with a dedicated ground wire.
    Wsteven, JoeCOVA and Rujack[OP] like this.
  13. Dec 15, 2018 at 8:56 AM
    Rujack
    If I use too thick a gauge doesn’t it increase resistance? Anyway I’m just trying to get this hooked up last minute to get it off of propane...
  14. Dec 15, 2018 at 8:57 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Do you have the solar charger hardwired to the roof and battery or is it a temp type thing you set up when you arrive.
  15. Dec 15, 2018 at 8:58 AM
    Rujack
    Cool. So if I want to allow for future accessories and a fuse block as @OnHartung'sRoad suggests, should I use 6, or smaller?
  16. Dec 15, 2018 at 9:04 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Personally, I would not put the fridge on a fuse/fuse block. I would (and did in the Airstream) run it with a Bussman breaker of appropriate size.
    JoeCOVA and ScottyR like this.
  17. Dec 15, 2018 at 9:08 AM
    Rujack
    Permanent
    MrBrooks and FFBlack[QUOTED] like this.
  18. Dec 15, 2018 at 9:10 AM
    Rujack
    I considered this and may go that route, but the breaker ant be sourced today
  19. Dec 15, 2018 at 9:15 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    You have the best bed rack in the whole world!
  20. Dec 15, 2018 at 9:37 AM
    Rujack
    I’m a fan myself!
    bajatacoguy[QUOTED] likes this.
