What gauge wire do I need for fridge circuit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Dec 14, 2018.
  1. Dec 19, 2018 at 9:13 AM
    #41
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Everyone should invest in a hydraulic crimpers. You can't buy good wire cheaply, but you can get 25' x 8 gauge jumper cables for $10. Use the crimper to make new lugs and run them to a distribution junction.
    RushT likes this.
  2. Dec 19, 2018 at 10:18 AM
    #42
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Larger cable = less resistance = less voltage drop = more capacity.
    6 AWG cable is overkill, and the earlier chart posted isn't granular enough for lower amperage connections. This is a far better chart for low amperage applications...
    You'd could use 14 AWG if you're only doing the fridge but you'd be pushing it; 10 AWG would probably be better. At the end of the day bigger is better to a point for safety, but there's no reason to waste money on huge cables for a low draw application.
    With that said, you could EASILY tap into the power on the trailer hitch for that low of amperage without having to do any wiring whatsoever. https://www.etrailer.com/faq-wiring.aspx has info on what wire to tap for that off of the trailer hitch. That's the fastest, easiest, and cheapest option -- plus it's already fused. You'd just splice in on the battery output and be done.
  3. Dec 21, 2018 at 11:01 PM
    #43
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I think it's 13A not 1.3A. A house fridge has ten times the voltage so amp draw for that isn't an apt comparison. I'd be fine with multiple power outlets on a single fused circuit as long as the total draw didn't exceed the wire max but even in homes relatively high draw appliances are separately fused. That's part of the UBC and should be applied as common sense to our truck mods.
    synaps3[QUOTED] likes this.
  4. Dec 22, 2018 at 5:55 AM
    #44
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    Agree in no way its 1.3 amp draw and I offer 6 AWG is whats needed though 8 awg may be fine depending on run. 14 gauge is for much smaller draw. I did an interior inverter install and due to length of run it required 6 awg and a 150 amp breaker near the battery.
  5. Dec 22, 2018 at 6:31 AM
    #45
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    IIRC, resistance is roughly inversely proportional to diameter (it’s a surface area thing since current tends to run in the surface rather than through the whole wire). That’s in solid wire. Braided gets more complicated.
  6. Dec 22, 2018 at 2:27 PM
    #46
    synaps3
    Dave
    Los Alamos, NM
    There is no way a mobile fridge draws 13A current continuous. The current may peak a bit higher when the compressor starts, but operational amperage will be far less. My CC40 is rated to draw 1.10 Ah/h usage against a power bank, which converts to 13.2w... At 12v, that's 1.1A.
    I adjusted my post assuming 13A in case I'm still wrong (which happens), but I still think 6AWG is way overkill.
    Mountain2018 likes this.
  7. Dec 22, 2018 at 4:01 PM
    #47
    Mountain2018
    2018 4x4 SB gray
    I do agree that the fridge should not draw that many amps or close to it. I beleive the issue is usually startup and most use a factor of 5 in figuring possible draw. So for the that start up you have quite a bit of juice on the line compared to normal operation. I in no way claim to be an electrical engineer but have fair amount of experience working with inverters (have one in my Tacoma that I use often) and other electronics installation experience.
  8. Dec 22, 2018 at 4:56 PM
    #48
    bagleboy
    Scott
    Norcal, Santa Rosa
    13A at 12V is only 156 watts so it seems reasonable to me. 13A to a house fridge at 110 AC is 1430 watts. Unless it's poorly insulated it shouldn't run all the time but when it does it will draw close to that amount which is still only a small fraction of what an moderate air compressor draws @ 30-40A. I agree that #6 is overkill for just the fridge alone but not for an auxiliary fuse block while at the same time #14 is not nearly enough for any distance at that current and even #12 would be pushing it with only 10 ft of wire.
  9. Dec 23, 2018 at 9:04 AM
    #49
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I hope OP included the amps for his blender in the calculations before running those wires, because right now he’s probably camping on the beach in some warm blue tropical water cove in Baja California fixing to make another round of Margaritas with it and is either noticing that his blender and fridge don’t work well together and there’s a bad smell comming from his truck, or they’re both purring away and he’s passed out after his fourth round:drunk: I hope he’s getting sunburnt.:D
    Ok, I’m just jealous because I didn’t get to go to Baja and drove to Texas instead, the lucky bum!:oops:
