What Happens to the Tire Pressure Monitor When I Swap Wheels??
Discussion in 'Wheels & Tires' started by MikeDeason, Mar 28, 2010.
  1. Mar 28, 2010 at 8:03 PM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    I know on my previous vehicles the TPM didn't work w/aftermarket wheels and the warning light just stayed on constantly with no way to turn it off.
    Same on the Taco???
  2. Mar 28, 2010 at 8:04 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Black tape mod ,
    OZ
  3. Mar 28, 2010 at 8:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you don't swap the sensors into the new rims or use one of the trick methods (PVC pipe, tactor tire. black tape mod. LED crush mod) then yes...It will be stay on.
  4. Mar 28, 2010 at 8:11 PM
    MikeDeason
    What is there...a dash light indicator that stays on?????
    ...on one of my vehicles it Fuck*&^ BEEPED every 50k...That was ANNOYING.
  5. Mar 28, 2010 at 8:13 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    It really depends upon what type of rims you get. Some rims will accept the old TPMS sensors some won't. It's all about where the valve stem hole is located on the rim. Sensors are very easy to swap, they are generally a 12 mm nut or 1/2 nut depending. You just need to test fit it and see. If you are having someone else do the tire install like at Discount Tire (I'm not sure if they are national or just AZ) or someplace like that, they should be skilled in doing this type of thing. I have personally done this on many vehicles. I work at a dealer (Kia), but I work in the used car reconditioning department, we do this kind of thing all the time. But beware, aftermarket rims are more prone to breaking the sensors, especially on low profile type tires. Otherwise there is no way to turn off the TPMS system, you will just have to deal with the annoying amber light. You can thank Ford & Firestone for the TPMS systems on all new vehicles. Hope this helps.
  6. Mar 28, 2010 at 8:13 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah there is a little light that looks kinda like: [​IMG]
    You can also look up TPMS strap kits. Lets you strap any sensor to any wheel (in a given size range)
  7. Mar 28, 2010 at 8:20 PM
    MikeDeason
    At least it doesn't beep every 50m like my Ford....The indicator light I can deal with if the swap won't work.
  8. Mar 28, 2010 at 8:23 PM
    Gingrbredman
    Gingrbredman Love the Tick!
    G
    Chicagoland
    09 Double Cab Sport 4WD
    When I got a set of moto metals and new Revos, I actually purchased a set of sensors, and Discount Tire installed them for me. They had to program the sensors to work with the truck (or the other way around, I'm not sure), but they work fine.
  9. Mar 28, 2010 at 8:45 PM
    fhlashsf
    fhlashsf Well-Known Member
    Curt
    Danville, CA
    '10 Off Road Double Cab 4x4
    Weathertechs, Avid bolt-on sliders and light bar, 17" ATX Thug wheels, BF Goodrich AT 285/70/17 tires, Icom 2820 Dstar radio, OME 3" lift, color matched rear bumper and Grillecraft grille, Wet Okole seat covers, ARM bed extender, black badges, Sockmonkey decals, HID headlight and foglights, TRD cat back exhaust, TRD CAI, URD MAF calibrator, Kenwood 6960 HU, Image Dynamic front and back speakers, ARC Audio Sub in Mr. Marv custom sub box and amp rack, Tuffy security box for bed.
    Do you remember what those sensors and installation cost?
  10. Mar 28, 2010 at 9:31 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    I took mine to a local tire shop to have my tires mounted on my new wheels and they didn't have any problems swapping them over.
    You bleeped out the wrong part. LMFAO!!! I seriously laughed when I saw that. +1
  11. Mar 29, 2010 at 6:14 AM
    Gingrbredman
    G
    Chicagoland
    If I remember right, the sensors were like $80 each. No extra charge to install them cause I had Discount Tire mounting and installing the wheels and tires at the same time. I know, that's pretty expensive for an extra set of sensors, seeing as I already had a perfectly good set in my stock tires. But I want to swap out the sets between seasons, and I wanted sensors for each set.
    Plus, Discount Tire beat the lowest price I could find on the Moto Metals, and the Revos, so the out the door cost, including the new sensors, was pretty comparable to trying to find everything online and do it myself.
  12. Mar 29, 2010 at 6:31 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    my sensers for my snow set cost $85 each, proper fit to the wheels. Free install based on new tires on to 2nd set of wheels. Free rotation where i bought the tires too. They have a big hose clamp to keep the sensor in the tire too if you want to use old sensors.
    so far here are the choices by cost sorta:
    tape the light/business card.
    put em in a whell barrow tire n store near the spare.
    sensor companies sell a hose clamp device to put in after mkt wheels.
    4 new sensors orderd to fit the wheels.
  13. Mar 29, 2010 at 8:09 AM
    MikeDeason
    Apparently, you have to do something to get the truck to recognize the new sensors...I think I'm going to try and use the current sensors.
    I Imagine this will fuc^% up the warrenty on the sensors if I screw up the install.
    Total Price: $172.00
    [​IMG] Additional Information
    If you purchase a Tire & Wheel Package when you buy new sensors, the sensors will be installed on the wheels at no additional charge. Otherwise, you will have to arrange for installation by a trained technician after your new wheels are shipped to you. Tire Rack's Recommended Installers are available to help you with your installation needs and can be selected by ZIP Code in the shopping cart.
    Once installed, you will need to read your vehicle's owner's manual to review the proper procedure for allowing your vehicle to "recognize" the new sensors.
  14. Mar 29, 2010 at 8:45 AM
    Gingrbredman
    G
    Chicagoland
    I had to "match" the new TPMS sensors and my truck. By putting in aftermarket sensors, you can't just reset the light, and then they work. I kind of equate it to "pairing a bluetooth device". Not all tire shops have the equipment to pair the devices. I found out, not even all Discount Tire shops have the equipment, hence my wait until their roaming tech made it to that store that day.
  15. Mar 29, 2010 at 8:50 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    http://www.ez-sensor.com/
    Look at these. No strap ons. These sensors are designed to be programmed to the vehicle instead of programming the vehicle to see the new sensor. This would allow "Mirrored" sets of tires that the vehicle would be happy with.
    Interesting idea. I could not find a fitments list right out of the gate but I have an inquiry in on the technology.
  16. Mar 29, 2010 at 8:52 AM
    fhlashsf
    Curt
    Danville, CA
    Another $320 on top of tires/wheels....? Is this TPMS even worth it?
  17. Mar 29, 2010 at 8:55 AM
    MikeDeason
    I know TPS have been ridiculed but I actually like them.
    One less thing to worry about.
    I'm going to try and retrofit the OEM sensors.
  18. Mar 29, 2010 at 8:56 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Depends on what you mean by worth it.
    If you don't get something done- You'll have an idiot light on the dash all the time.
    I thought it was kinda silly until I drove over a sheetrock knife blade on the highway. I was doing 70mph and wouldn't have had to stop for hours to get gas...at which point I probably could have blown the tire out bad. BUT the light came on and I stopped at the next gas station- Swapped it right out.
  19. Mar 29, 2010 at 8:57 AM
    ShadowFalken
    Jim
    Maryland
    10 Off Road
    They said they had a roaming tech? Interesting. Were you there when this tech arrived? Was he in a company vehicle or uniform?
    The reason that I ask is that there are independent guys that are going around local areas and handling these technological issues for shops. They are not employees of the shop but more like an independent business that offer specialty services. Many go under the name "Mobile Diagnostic Tech". They tend to be highly trained techs that have invested in tooling and equipment above and beyond what most shops have. That can even include dealerships in the used car department. I wonder if that was the service they used. There are even some of these people that specialize in specific services. Modern locksmiths, airbag system specialists and electronic module repair services are just some of the list.
  20. Mar 29, 2010 at 8:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the shop that installed my stuff put my sensors into my new rims for me.
