What have you bought in the last 48 hours gun related?
Discussion in 'Guns & Hunting' started by Rmodel65, Jan 4, 2013.
  1. Apr 9, 2021 at 8:15 AM
    dantheman1540
    dantheman1540 Well-Known Member
    Dan
    Sugar Loaf Mountain
    2011 Access cab 6 speed 4x4
    Camburg UCAs, Bilstien 5100s/886, AAL, Falken AT3W, Allpro Bumper.
    Within 2 hours Zaffiri customer services responded with this. I'm pleased with their quick response when their contact page said to expect 48-72 hours. I will complete their suggestions and report back, now to find a couple hundred more rounds of target ammo.
    Hey there,
    Sorry you seem to be having some trouble with fitment of your new barrel No need to worry. Here are a few things you can do:
    - Apply excessive lube (gun oil) on the slide and barrel. Lube should cover all areas where you have metal on metal contact.
    - When you install the barrel into your slide you may need apply some pressure to make it "snap" into place. This is common with match grade barrels to fit tighter with less "slop" than factory fit.
    - Depending on the finish on your slide this may end up removing a small amount of cerakote from the face of the breach. This is normal with tight fitting match grade barrels in cerakoted slides.
    - Once you have the barrel in place it should be fully seated, and the chamber should sit flush with the top of the slide.
    - Install you guide rod and put your slide one to the frame.
    - Hand cycle the slide 20-30 times. Pull the slide all the way to the rear and let it go. Let the gun do the work.
    - Remove the barrel, and wipe off any debris, re-lube and repeat.
    Dry hand cycling hollow points or any other types of ammo are not a reliable test for new barrels.
    Fire 200-300 rounds of 9mm ball ammunition threw your new barrel for proper wear in.
    Please let us know if you have any other questions or need further assistance.
    Thank you,
    Gary @ ZP
    virginiamarine likes this.
  2. Apr 9, 2021 at 8:18 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    And she's nice to look at too....crap...did I just say that!!
  3. Apr 9, 2021 at 10:30 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
  4. Apr 9, 2021 at 12:04 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    600rnd of 22LR and 100rnd of 9mm at BiMart.
  5. Apr 9, 2021 at 4:37 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    It’s truly impressive how well it turned out. Especially for the first one. If I had been a little less aggressive with each pass, it would have turned out even better.
    The only issue I had was the takedown pin hole needed a bit of deburring. Aside from that, it was no different than my last build with an Aero lower.
    IPNPULZ[QUOTED] likes this.
  6. Apr 9, 2021 at 5:02 PM
    OnePuttBlunder
    AZ
    Condom for the can. Coletac high heat
  7. Apr 9, 2021 at 5:43 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    What does the condom do for the can?
  8. Apr 9, 2021 at 5:43 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I've been Brownelled!
    kmwilt, TomTwo, Vabunch and 1 other person like this.
  9. Apr 9, 2021 at 5:53 PM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    They have the Larue triggers in stock? I’ve been waiting for mine since early December. Getting fed up.
    cubie[QUOTED] likes this.
  10. Apr 9, 2021 at 6:02 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    No, only the buffer tube and super 42 came Brownells. The trigger and CH are off arfcom EE.
  11. Apr 9, 2021 at 6:07 PM
    OnePuttBlunder
    AZ
    Significantly reduces heat mirage. Protects your hands from being burned when you remove the can. Suckers get hot even if only running a handful of rounds
    Chew and cubie[QUOTED] like this.
  12. Apr 9, 2021 at 6:09 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thanks! I know nothing about em, only that they make your shot quieter. lol
    wilcam47 likes this.
  13. Apr 10, 2021 at 6:17 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I like that rear sight.
    cubie[QUOTED] and wilcam47 like this.
  14. Apr 10, 2021 at 6:41 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Now does she know you feel that way?
  15. Apr 10, 2021 at 6:54 AM
    IPNPULZ
    going to be fun!
  16. Apr 10, 2021 at 7:57 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    As a luddite, I just keep an old wool sock in my range bag.
  17. Apr 10, 2021 at 8:58 AM
    IPNPULZ
    going to be fun!
    I have seen them locally and was amazed at the fit, finish and cost of them @ over $600 bucks....
  18. Apr 10, 2021 at 9:08 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2009 Black DCSB TRD OR
    My LGS sells ammo for $2 above what he can get them for, with a 2-box maximum, so the Sig Elite was actually cheaper than the Blazer. :bananadance: It wasn’t the best price, but pretty damn good considering most places are still out.
    I also picked up some flip up/down sites for my AR.
    kmwilt, wilcam47 and IPNPULZ like this.
  19. Apr 10, 2021 at 1:38 PM
    IPNPULZ
    going to be fun!
  20. Apr 10, 2021 at 2:19 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    You should do a 1000rd review. I as well as every sniper ever have been looking for one that holds up. Only to be disappointed year after year...since 2008.
