  1. Apr 27, 2020 at 10:11 PM
    Taco-Obsessed
    I think it's cool when you're doing a similar project around the same time someone else is on here. This is what I did for my disconnect of the panel, just used spade terminals. I decided not to learn how to do the fancier options.
  2. Apr 27, 2020 at 10:19 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Damn! Super clean.
    Hows the painted shift cover holding up? I want to paint mine but I'm scared I'll scratch the hell out of it
  3. Apr 27, 2020 at 10:20 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    I saw this posted yesterday so it kind of got me off my ass to get going on my wiring! I see you wired your positive and ground to both posts at the top and bottom of each switch. Are you not tapping into the factory dash dimmer wires? The green wires on my switches are going to be connected to the green (+) and green with white (-), behind the dash so my switches will follow what the dash does.
    ETA- I also wired my locker switches to my locker power so they won't be live unless it is switched on.
  4. Apr 27, 2020 at 10:27 PM
    Taco-Obsessed
    I opted not to do that, but know what you are referring to. I just jumpered my power and illumination together and my grounds together. It was simpler, my lower independent lights aren't that bright so I dont need/want to dim them, and I wired in a kill switch before the panel anyway to turn off the switches and to prevent kid fuckery (my kids playing with them). If needed and seems too bright I can kill it when not in use, but i personally dont see that being an issue (being to bright). My upper lights are brighter, but I like how they are, even at night.
    GonzoQuick and Sna[QUOTED] like this.
  5. Apr 27, 2020 at 10:35 PM
    Taco-Obsessed
    @Sna my panel is overhead so not an easy location to keep going back to. I got all paranoid or careful and used a test light to test all my outgoing wires to relays first before installing them using a battery, then again after connecting to the add a circuit (tapped the ACC fuse behind the coin tray)for power, then again after installation and running them through my firewall. I set all this up to do it right once. Now I'm moving on to my aux fuse panel. Then when money is right, add the accessory by simply running the relay to accessory wire and grounding that accessory.
    Just bought 4.88s a compressor and rear locker, so money wont be right for a while :bananadead:
  6. Apr 27, 2020 at 11:04 PM
    Sna
    Alberta
    Looks great...I'm the same way, do it right once so it doesn't have to be done again and it's safe. I have my CB radio mounted just ahead of where you switch panel is so I know it's a PITA to get at.
    I have an aux fuse panel already so the only wires I haven't run are the ones for the accessories (which right now are the switches for my lights). Once I get my switch panel, all I need to do it connect the red switched power wire to the ACC at the fuse panel by my left knee, ground the black wire, green and green w/white will be connected to my HVAC dimmer wires and then run the accessory wires (tied under the dash near the dead pedal). Under the hood I need to connect the corresponding accessory wire (from aux fuse panel) to the positive of the accessory and then ground all three under the hood. I will be ordering 4.56's and Harrop e-lockers this week so I know all about money being tied up :help::facepalm:...
    I'll end up spending more time running wires for my lockers and lights than it will likely take to install the switch panel etc. Everything will be connected to relays for safety. I also need to run 12v fridge wires from my bed to my house battery under the hood.
  7. Apr 27, 2020 at 11:16 PM
    Taco-Obsessed
    Maybe this helps. I grounded to a bolt behind the lower panel by my left foot. All grounding bolts have an E on it. I can take a photo tomorrow if you need it. Real close to the fuse panel behind the coin tray, so it's a good spot I think.
    Sna[QUOTED] likes this.
  8. Apr 27, 2020 at 11:21 PM
    ThePanda
    ThePanda Well-Known Member
    Kaelan
    Colorado
    6-Speed Manual 2010 Magnetic Grey Tacoma SR5
    Procomp 6" Lift ARB Front Bumper Brute Force Fab's High Clearance Swing Arm Rear Bumper Relentless Fabs Bed Rack Gen 2.5 Face-Lifted Exterior and Interior (mostly) -Fleabay Headlights -Heritage Grille -Scooped Hood Alpha Rex 3rd Gen Pro-Series Taillights Joying 10.5" Android head unit URD Short Throw Shifter Advanced Fiberglass Front and 3rd Gen Rear Fenders 3rd Gen Tailgate RSG Metal-Works Sliders ARB Simpson III RTT Panels Lined w/ Closed Cell Foam (In Progess...) QTP Reverse Screamer muffler TRD CAI SPC UCAs S.S. Brake lines front and rear S.O.S. Performance rear Disk Brake conversion w/PowerStop performance calipers, rotors and pads KMC Tank 17" beadlocks wrapped in 35x12.5" KO2s Long Range Offroad Extended Range Fuel Tank ATO Dual Battery tray w/ 34D Optima Yellow tops and Blue Sea ML-ACR ClutchMasters Hydraulic Throwout Bearing
    I gotta do that. But if I do there's no guarantee that the same seats will go back in...
  9. Apr 28, 2020 at 1:41 AM
    fs007
    fs007 Well-Known Member
    06 AC 4x4 4cyl
    thanks man totally agree! got the raptor lights too but haven't installed them...just not convinced of the look yet
    YotaProject[QUOTED] likes this.
  10. Apr 28, 2020 at 1:42 AM
    fs007
    06 AC 4x4 4cyl
    already listed in the classifieds! you want it?
  11. Apr 28, 2020 at 3:37 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    My Paranoid bracket came in.
  12. Apr 28, 2020 at 4:03 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Yes Sir
  13. Apr 28, 2020 at 4:41 AM
    TigerTacoma
    TigerTacoma Well-Known Member
    Upstate South Carolina
    ‘14 MGM Access Cab 4x4
    Dobinson’s coils and shocks. SOS sliders, ditch light brackets, and front skid. Rigid ditch lights. BFG KO(dos) More minor stuff.
    Anyone that could TW express from Fredericksburg to Hampton, Va?
  14. Apr 28, 2020 at 4:49 AM
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    It’s vinyl and holds up pretty well.
    theolee[QUOTED] likes this.
  15. Apr 28, 2020 at 4:57 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    What did you use to get the carpet so clean?
  16. Apr 28, 2020 at 5:02 AM
    danielsthomas57
    Thomas
    Virginia
    I used a vacuum and carpet cleaner. The hair is such a pain in the ass to get up but I just would go over spots with the vacuum 2 or 3 times with a brush attachment.
    GonzoQuick, freddy2923 and Rick_Taco like this.
  17. Apr 28, 2020 at 5:03 AM
    t2ch
    t2ch Well-Known Member
    Travis
    Va.
    2015 TRD OR
    Who did the wrap on the hood Chris?
    I'm down the road from you and don't think there is anyone in Ch-ville who does wraps.
    JKU3000 and Casper66[QUOTED] like this.
  18. Apr 28, 2020 at 5:06 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Lol it’s plasti dip. I wasn’t sure if I would like it so just did it with dip so I could remove it. Wrapping is around $300 from what I was quoted locally. I kinda like the texture of the wrap though and only cost me about $10 and an afternoon
    GonzoQuick likes this.
  19. Apr 28, 2020 at 5:09 AM
    t2ch
    Travis
    Va.
    2015 TRD OR
    Hmmm, I have a couple cans laying around here. I might have to give that a try.
    Casper66[QUOTED] likes this.
  20. Apr 28, 2020 at 5:11 AM
    Venom
    Kevin
    Massachusetts
    Thanks for the reply!
    Did you have to use a motorized brush attachment on the vacuum?
    Did you have to use something like the Little Green Machine from Bissell on the carpets and the seat with the cleaner?
