  1. Apr 28, 2020 at 6:33 AM
    Pizzasteve5717
    Pizzasteve5717 Well-Known Member
    Steven
    Marietta, GA
    2005 Tacoma TRD prerunner
    Just tacks? I would have never guessed that lol
  2. Apr 28, 2020 at 6:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, turn the welder way down and just tack away and then grind smooth. Then I’ll go over it with body filler and sand it so it’s perfectly smooth, like I did in the rear.
  3. Apr 28, 2020 at 6:55 AM
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    It had a spacer lift on it :crapstorm: 3inch body lift and 2 inch spacer lift. I bought it when I was young and dump and didn’t do my research. The cab is off from it rolling. I was good. Spent like 4 hrs in hospital getting stitches and waddled my ass out the place.
    GonzoQuick, Rick_Taco and gabbo2112 like this.
  4. Apr 28, 2020 at 7:19 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    It seems like the body lift was the weakest link.
    Is this why the some members on TW don't like body lift? The potential for thing to go wrong.
  5. Apr 28, 2020 at 7:26 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I've had good results with Raptor Liner and getting it even smoother than the finish pictured. You may want a little texture to hide body imperfections, but if you want it smoother, there's a lot of info out there on how to do it. I used a cheap Harbor Freight gun (the $10 one), drilled the nozzle out to 7/16" and played with the air pressure on some cardboard until I got the finish I was after. My bumpers and sliders are coated in the stuff and finished with a smooth, durable and easy to clean coating. Dead bug guts just vaporize off of my front bumper with a pressure washer and the sliders are easily re-coated when they get scraped up. Good luck!
    EDIT: Oops didn't see you're using Durabak. Looking forward to seeing the finished product!
  6. Apr 28, 2020 at 7:48 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Threw on a coat of sealant. My 2008 clearcoat is def in the early stages of failing. Truck will be parked outside for the entire summer here in AZ so by Christmas, my hood/roof will probably be patchy and white.
  7. Apr 28, 2020 at 7:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Seeing your antenna poke through your fender gave me an idea. I never ever use my radio and don't even have an antenna on the truck. I'm going to remove the base and patch the sheet metal.
  8. Apr 28, 2020 at 8:10 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    You are a bondo bandit, a metal-filling madman. Please don’t stop
  9. Apr 28, 2020 at 8:18 AM
    lenoxluda
    lenoxluda Well-Known Member
    09 Sport
    Nice rig!! Where ya get that lil front license plate?? I dig it!!
    TomTwo likes this.
  10. Apr 28, 2020 at 8:32 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Just rock the license plate relocation bracket from Acekraut + BumperPlugs combo, it will even work with your skid. It's an option anyway.
  11. Apr 28, 2020 at 8:57 AM
    TurtleMonkeyTaco
    TurtleMonkeyTaco Member
    Turtle
    Minnesota
    2012 TRD Off Road
    K&N AirFilter, Ranch Topper
  12. Apr 28, 2020 at 9:03 AM
    YukonToyotaTRD
    YukonToyotaTRD Well-Known Member
    Whitehorse, Yukon, Canada
    2015 TRD Sport Doublecab
    none as yet
    Test fitting the LED bar, had to accommodate for 1” body lift. Really wish I can run no front plate.
    [/QUOTE]
    I have a 20" behind my PRO grille, but you could run one wider! **edit** never mind, I just realized that you had the CAI behind the grille :)
  13. Apr 28, 2020 at 9:16 AM
    skochat
    skochat Well-Known Member
    2015 Magnetic Grey Tacoma 4x4 TRD Sport
    TRD Pro 17" rims, Volant CAI w/ Scoop, TRD Cat Back exhaust, Pedal Commander, Viper Smart Start, front parking camera
  14. Apr 28, 2020 at 9:26 AM
    Nickkos taco
    Nickkos taco Well-Known Member
    Nick
    Sanfrancisco
    2012 regular cab 4x4
    fox lift spc control arms 285 tires off road lights Mazzulla hi clearance bumper many interier and exterior ad ons
    Got the yeti inset Ryan makes for cup holder he had one in orange had to have it inside my truck looking like it would belong to boogie430D3A5B-235C-4CC9-9A0C-C236321B9BB3.jpg8AAC5FEA-4397-456B-9D50-130927EBFF32.jpg
  15. Apr 28, 2020 at 9:30 AM
    lenoxluda
    09 Sport
  16. Apr 28, 2020 at 10:05 AM
    SSFtacoma98
    SSFtacoma98 Well-Known Member
    California
    2013 TRD Off Road
    TRD Pro grill. TRD wheels, skid plate
    eBay. There’s a ton of Toyota dealers that sell old parts on ebay if you want OEM. Or if you don’t care for OEM you can get a pretty cheap version on eBay too
  17. Apr 28, 2020 at 10:50 AM
    soxfan387
    soxfan387 Active Member
    Lee
    Eastern MA
    2012 Tacoma SR5 4x4
    Very small mod, but replaced original antenna with this one from Ronin. Same sound quality around town.unnamed.jpg
  18. Apr 28, 2020 at 11:16 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    Painted the brackets I made to hold my traction boards. Also painted a pair of bed corner gussets I bought off of another member. The original paint had failed in a bunch of spots and rusted so I hit them with some Rustoleum rust converter. I don't remember buying or using it before although apparently I have since the can was half empty. I'm going to topcoat it tomorrow after work. Guess time will tell how well it works. Also took some acetone and removed the 8 from the center caps of my Level8 wheels.
  19. Apr 28, 2020 at 11:30 AM
    lenoxluda
    09 Sport
  20. Apr 28, 2020 at 12:08 PM
    Gnarbuckle85
    Gnarbuckle85 Well-Known Member
    Sean
    H-Town, TX
    2011 TRD Sport DCLB Silver
    DON'T JOIN TACOMA WORLD!! JUST DON'T!
    Got a Bluesea Fuse block to go along with my Off Grid Engineering dual battery set up that is in route. Time to clean up some wiring.
