  1. May 23, 2020 at 7:36 PM
    lesliechow91
    lesliechow91 Well-Known Member
    Noel
    Orange county
    2014 White DCSB TRD OR 4x4
    Bilstein 8112/8100, 295/75/16
    Thanks, I wired them directly into the fog light lead from the fuse box
  2. May 23, 2020 at 7:48 PM
    OvrlandTaco
    OvrlandTaco IG: Ovrlandtaco
    Colton
    Wyoming/Texas
    '06 Black DCSB TRD Off-Road
    It definitely updates the look of the front end
    DG92071 likes this.
  3. May 23, 2020 at 7:55 PM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    thanks!
    it was not difficult with C4’s YouTube video. I would give it a 4, with 10 being the hardest. Took me about 4 hours total including the wiring. I was pretty worried about installing it myself, but took my time.
    GonzoQuick likes this.
  4. May 23, 2020 at 8:05 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Been staying a bit busy with building this bumper.. pretty close to being done, just have to weld some small components, grind it all down more and paint!
  5. May 23, 2020 at 8:09 PM
    DG92071
    DG92071 Well-Known Member
    Oh hell yes. I want, no - I need that bumper!
  6. May 23, 2020 at 8:11 PM
    DG92071
    Perfect!
    ah805[QUOTED] likes this.
  7. May 23, 2020 at 8:12 PM
    DG92071
    Damn that's a lot of work, nice work.
  8. May 23, 2020 at 8:13 PM
    lechicklet
    lechicklet Well-Known Member
    Chey
    California
    ‘13 4WD DblCab Ltd
    TomTwo, Badderup, AugustaTaco and 6 others like this.
  9. May 23, 2020 at 8:14 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Thank you sir, hope you're doing well!
    DG92071[QUOTED] likes this.
  10. May 23, 2020 at 8:42 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Night shot. Light distribution is pretty good considering half the light is pointed out instead of down. Excited to see how it turns out with my 3D printed brackets pointing the rock lights down.
  11. May 23, 2020 at 8:50 PM
    Nigel4x4
    Nigel4x4 Active Member
    Boulder
    09 RC 4x4
    Bilstein 5100 front and rear; Softopper; Duratracs
    That’s a great tip! Cheers!
    Casper66[QUOTED] likes this.
  12. May 23, 2020 at 9:30 PM
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    Whatcha doin with the pro grill you switched out !?!? :)
    Rick_Taco and ah805[QUOTED] like this.
  13. May 23, 2020 at 9:31 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Cleaned up the engine bay, fixed the clock spring and got the horn working again, got the dent removed from the tailgate, add performed a decontamination wash, iron removal, and autoscrubbed to get ready for polish and coating tomorrow. Put an extra bead of silicon around the Tacomabeast Spyder headlights before I install them this weekend. Also ordered some Rotifform Six OR’s in bronze but not sure if I’ll actually receive them. They are showing in stock but we’ll see. More to come.
  14. May 23, 2020 at 10:07 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Something is wrong with my driver's side headlight. Only noticed today, that's how much I drive the truck lately.
    The halo (I think that's what it's called) on the retrofit doesn't light up when the headlight is on. I checked all the plugs, everything was plugged in fine. Ballasts are fine. They are the Morimoto XB35 (pretty sure that's what they are). The motocontrol is the Morimoto bi-xenon wire harness (I think).
    Any one know anything about headlight retrofits? Trying to figure out if it's the harness itself that's shot and need to buy a new one, or if it's the halo itself that shit the bed & need to drop $$ and buy a new set of retrofits.
    whatstcp likes this.
  15. May 24, 2020 at 12:18 AM
    Cannikin
    Cannikin Well-Known Member Vendor
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Installed the Wheeler's U-bolt Flip Kit and made a video of the install!
  16. May 24, 2020 at 6:21 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    are there springs in the risers? off road how much does the bumper movement pull on the rack?
  17. May 24, 2020 at 7:05 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Sometimes the pins in the connectors work themselves loose over time. Try checking all of the pins first and tighten them up with a pick tool!
    whatstcp and Cativelense[QUOTED] like this.
  18. May 24, 2020 at 7:17 AM
    Cativelense
    Nuno
    CT
    Did that, and still not working properly.
    Thinking about buying the entire harness pc and see what happens. If I looked it up correctly it's only $35.
    will.i.was[QUOTED] likes this.
  19. May 24, 2020 at 7:18 AM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Who makes that shelf? Pretty cool idea!
  20. May 24, 2020 at 8:32 AM
    ah805
    ah805 Well-Known Member
    Alex
    Central Coast, CA
    2013 Trd Sport DCLB
    Keeping it as a spare for a little bit.
    WillyTtaco[QUOTED] likes this.
