  1. May 26, 2020 at 9:49 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    I painted mine with plastidip last year and it was probably about 5 or 6 coats and it didn't last the summer. Small rock chips just keep getting bigger with wind blowing on it.
  2. May 26, 2020 at 10:09 AM
    Bonnie’s Squeeze
    Bonnie’s Squeeze Well-Known Member
    Ross
    Bluffton, SC
    2015 Tacoma TRD Sport DCSB
    Volant CAI, TRD Exhaust, Throttle Body Expansion with vortex, too many others to mention.
  3. May 26, 2020 at 10:39 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Mine took 13qts. Make sure you put the truck trans temp check mode first, to check the level.
  4. May 26, 2020 at 10:58 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Looks like you have a 285? I was wondering if you can adjust the mount up or down to fit different size tires so that the bottom of the tire sits flat on bed.
  5. May 26, 2020 at 11:02 AM
    YukonToyotaTRD
    YukonToyotaTRD Well-Known Member
    Whitehorse, Yukon, Canada
    2015 TRD Sport Doublecab
    none as yet
    I got that same one last week!
  6. May 26, 2020 at 11:05 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Installed this two weeks ago. I did hit 200f Trans temp offroading the next weekend so im going to install a t-stat temp switch and a motorcycle rad fan (puller) in the near future. next on the list is CV Boot replacement.
    20200510_130458.jpg 20200510_151530.jpg 20200510_185901.jpg 20200510_200756.jpg
  7. May 26, 2020 at 11:12 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Tire sits flat in the bed, you can adjust the mount a few inches up and down. It will also hold a 35" tire. Look at the pic of the mount and you can see the slots. This is a very well made product. Good luck with your truck.
  8. May 26, 2020 at 11:14 AM
    loyaltothetaco
    Adam
    Bay Area
    Right on, nice tuck btw! :cheers:
    Taco-Obsessed and Mully[QUOTED] like this.
  9. May 26, 2020 at 12:04 PM
    Northbound_Taco
    09 Off road build
    I did this last fall but used gasket maker on the seal under the screws and taped those slits up and it has held really well
    GonzoQuick likes this.
  10. May 26, 2020 at 12:09 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    What jl's are those? 10 in shallow? I was under the impression that normal mount subs and 12's wouldn't fit behind the seats. If I am wrong then I spent a lot of money for nothing. Not to mention that the pancake subs just dont hit like the normal ones do.
  11. May 26, 2020 at 12:25 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I dig the grille design without the lettering and Raptor style lights. Cool find
  12. May 26, 2020 at 12:38 PM
    Northbound_Taco
    09 Off road build
  13. May 26, 2020 at 12:39 PM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
  14. May 26, 2020 at 12:46 PM
    Rick_Taco
    Rick
    Indiana
    I find it easiest to remove the skid plate by the transfer case. Like @boogie3478 said, I had to turn the one at the front diff a little. I too believe it was a 10mm wrench. Isn't everything 10MM? LoL
    I do not have any trouble after doing those 2 things. I also jack all 4 wheels in the air and put the truck in neutral so I can spin the drive shaft by hand when I am under there. My lube shuttle with a standard tip works great.
    elricfate[QUOTED] and boogie3478 like this.
  15. May 26, 2020 at 1:35 PM
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
    Stealership.
    El Tano[QUOTED] likes this.
  16. May 26, 2020 at 2:02 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Nothing to day or this week phase three of the big house make over my wife wanted. I gave it as she lets me do what I want the tacom and other hobbies. so she go a new back and side last week this week and new driver and concrete walke way to patio, replacing the Decomposed Granite walkway. we talked in 15 years ago. So the the Taco and the Grandkids Venza is across the street and her Mini is in the garage. It's in the100+F degrees for the next 3 day so I am not complaining. 2 guy I hired are doing it in this heat. Slow going but it needs to get done. After this having the house painted, Spending the afternoon checking out tires for the Taco.
    GonzoQuick, TomTwo and Rick_Taco like this.
  17. May 26, 2020 at 3:04 PM
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    More Moab fun
    Kolter45, GARSHA91, CGoss and 18 others like this.
  18. May 26, 2020 at 3:18 PM
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    New tires & alignment. Cooper Discoverer AT3 LT (load range C) 265/75R16 3 peak snowflake symbol. Also about a week ago installed Wheelers superbumps up front.
    Kolter45, mr.trd, GonzoQuick and 6 others like this.
  19. May 26, 2020 at 4:17 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Received my license plate bracket from @ACEkraut
    Thanks again and plugged the license plate holes.
  20. May 26, 2020 at 4:21 PM
    UnrestrictedPilot
    UnrestrictedPilot Well-Known Member
    Josh
    2008 Tacoma Double Cab
    Are you able to send some pictures of the receiver hitch or how it attaches to the frame?
