  1. May 26, 2020 at 7:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How did you go about this? My seats are old so I’ve wanted to replace them.
  2. May 26, 2020 at 7:50 PM
    UnrestrictedPilot
    UnrestrictedPilot Well-Known Member
    Josh
    2008 Tacoma Double Cab
    Interesting. Im wondering how strong that is for towing. Im curious if the aluminum holds up compared to the stock one that is steel.
  3. May 26, 2020 at 7:53 PM
    Rorschach
    Rorschach Active Member
    Robert
    Orange County, CA
    2013 Black Tacoma DCSB TRD T/X Baja Series
    I debated that too. My seat material was in really good shape though. When I priced the foam from the dealer I was surprised it wasn't more expensive. I purchased a new pan and back piece, fought my way through the install, and I am good now.
    GonzoQuick, DG92071 and EatSleepTacos like this.
  4. May 26, 2020 at 7:57 PM
    andrewiniguez
    andrewiniguez Active Member
    Andrew
    Vista, Ca
    2009 Black Tacoma TRD Sport DCLB
    I haven't been on here in a few moths, here's how my truck sits right now. I just got all the parts pictured below, tomorrow I'll get my JBA UCA, and Baja Designs SAE Fog Lights. Can't wait to install everything this weekend. Front end will be new uca, lca, coilover, outter tie rod ends, and sway bar end links. Rear will just be new shocks. Let me know if you have any other recommendations while I'm at it.
    Also my truck is about to hit 175,000 miles, I bought it at 127,000 and all I've done is regular oil changes, filters, and spark plugs. I drive my truck daily on the freeway to and from different job sites sometimes pretty far, I want to do a full tune up on my truck , is there a guide or recommendations on maintenance I should do? Thanks for any info in advance.
  5. May 26, 2020 at 7:57 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    The roof is on my to-do list as well. Getting tired of the tin foil sound when it rains.
  6. May 26, 2020 at 7:58 PM
    20somethingwidataco
    Will
    Washington State
    I would seriously reconsider those baja sae lights...... Worst in the market at the moment. Rigid and Diode dynamics beat it in every category
  7. May 26, 2020 at 8:00 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Me too. Also doing it to hopefully cut down some of the wind noise from my roof rack at highway speeds.
  8. May 26, 2020 at 8:14 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    Here is the link: https://www.uscargocontrol.com/shop/Enclosed-Trailer-Accessories/Airline-Straps-Hardware They sell the strips to cover the track. They are level with the ribs in the bed. I also put a six inch track on the side of the wheel well since it is too hard to reach all the way back under by cover for a securing point. It also makes it easier to reach then going to the bed depending on the load.
    GonzoQuick and srspicer[QUOTED] like this.
  9. May 26, 2020 at 8:20 PM
    tazgohome
    did not seal behind the screws since I normally have my cover closed. Will keep an eye out for any leaks when the top is open.
  10. May 26, 2020 at 8:34 PM
    andrewiniguez
    Andrew
    Vista, Ca
    I get a deal I cant pass up on Bajas , might as well use it.
    BrashBrusier likes this.
  11. May 26, 2020 at 8:35 PM
    Taco-Obsessed
    There fine as offroad lights, just not fogs on street with other drivers.
    EatSleepTacos and BrashBrusier like this.
  12. May 26, 2020 at 8:57 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    I’m debating pulling the trigger on a similar setup for an AC. What springs did you go with?
  13. May 26, 2020 at 8:57 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I went with the 2885s. I had them on my last taco and loved it!
  14. May 26, 2020 at 9:04 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Sweet! Those are the ones I was thinking, since I don’t have any weight up front and I am not planning on adding any in the near future.
    Now to decide: new mountain bike, or new suspension.
    tamer[QUOTED] likes this.
  15. May 26, 2020 at 9:08 PM
    BrashBrusier
    BrashBrusier Well-Known Member
    David
    Seattle, Wa
    '10 AC TRD OR
    Lots
    Got my final alignment done today and had my Taco Tabs (LCA cam delete tabs) installed.
    Then went down to my local park to flex the new suspension a bit. New on top, old on bottom. Definitely much more articulation in the rear and a noticable amount in the front with the new coils and sway bar delete. Can't wait to get my armor and hit some trails.
    PacTac, GonzoQuick, Rick_Taco and 7 others like this.
  16. May 26, 2020 at 9:08 PM
    tamer
    tamer hamerworx.com
    NorCal
    Suspension FTW! You can’t haul a mountain bike with stock suspension, physics.
    BTW, paying the extra couple bucks to have headstrong assemble the front is worth every penny.
  17. May 26, 2020 at 9:13 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Well dang, I can’t argue with physics. Also I will 100% pay to have them assemble. I messed around with a spring compressor once, and will never do it again. It felt like using it took 10 years off my life due to stress.
    How hard is the install?
  18. May 26, 2020 at 9:16 PM
    Estephe21
    Estephe21 Well-Known Member
    Stephen
    Seattle, WA
    2008 DCLB, 2023 DCLB
    Sadly, not much.
  19. May 26, 2020 at 9:17 PM
    tamer
    tamer hamerworx.com
    NorCal
    Last time the first side took me 6 hours and the second took 45 minutes, lol. I’m hoping this time it’s about an hour each side on the front. The rear is probably about 30-40 min each side as well. It’s about as straight forward of an install as it gets. Hardest part on the front is figuring out what you have to unbolt to snake in the new coilover. It’s been a couple years but IIRC you need to pull off the sway bar and disconnect the LCA from under the brake disc.
  20. May 26, 2020 at 9:24 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Cool I’ll plan on a two day event for me then. Needed a quarantine project anyways!
