  1. Jul 11, 2020 at 9:33 AM
    NocturnalTaco
    NocturnalTaco Active Member
    Kadin
    Draper, Utah
    White 2013 TRD Sport DCSB
    285/65/18 - Message for specifics :D
    Finished the vinyl
  2. Jul 11, 2020 at 9:33 AM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    New Plugs today for the first time at 33kspark plugs.jpg . they all look pretty good to me.
  3. Jul 11, 2020 at 9:38 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    I’m needing a new MGM honeycomb grille for my truck at some point down the road.. mind sharing where you got that one and how much?
    Right now I’m rocking a killer hook up From TW chrome one that I plasti dipped
  4. Jul 11, 2020 at 10:10 AM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    With airplane engines we “pickle” the engine with a special oil to prevent corrosion. Might be overkill for our engines but I would at the very least put new oil in it and put the battery on a tender. You can also pull the plugs and spray some oil in there to help coat the cylinders, although it’ll all run down off the walls relatively fast.
    There’s also an oil additive called cam guard you could add to your oil, it thickens it up a little and prevents it from running off metal parts so fast. Not sure if I would run it long term but at least with this oil change then change it back out when you back.
  5. Jul 11, 2020 at 10:21 AM
    Spizike231
    Jesse
    Sacramento, CA
    What part of CA?
    DIRRTY_BOII[QUOTED] likes this.
  6. Jul 11, 2020 at 11:14 AM
    Devicus
    Devicus Well-Known Member
    Devin
    Victoria, CA
    2009 MGM Tacoma V6 SR5
    - Depo Headlights - 2011 Color Matched Honeycomb Grille - Custom Bed SR5 Decals - 265/70/17 Falken Wildpeak A/T3W - ART Replica 208 Wheels - BPF Skid plate and Tow Hook Attachment
    Got it from a dealer in Ontario, Canada that had them on sale for $100 off. Came in around $250 CAD shipped to British Columbia (across the country). There’s a lot more choices when it comes to finding OEM parts in the US so check online for the best deal! 5310004450B1 is the part number.
  7. Jul 11, 2020 at 11:20 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Fun times cutting up a banjo housing to make the SST to do rear wheel bearings. :eek::thumbsup:
  8. Jul 11, 2020 at 11:28 AM
    DIRRTY_BOII
    DIRRTY_BOII Active Member
    Joey
    2006 TACOMA TRD OFFROAD
    Los Angeles
  9. Jul 11, 2020 at 11:34 AM
    DIRRTY_BOII
    Joey
    Thankyou definitely changing the oil before and after
  10. Jul 11, 2020 at 11:51 AM
    Spizike231
    Jesse
    Sacramento, CA
    Aw damn if you were closer I’d go start her up and drive her every few weeks man just to help out.
  11. Jul 11, 2020 at 11:57 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Received and installed my SOS front recovery bracket. Came bare metal so did like 6 coats of paint both primer and black:
    Compared to stock recovery bracket:
    Bracket installed:
    With D-ring attached. I won't keep the D-ring on, just put it on for photo purposes:
    And finally some brand recognition:
    Curious, is there a torque spec for the two bolts holding it on? I just used some major muscle to tighten them down but should probably spec them correctly if there is a spec.
    GonzoQuick, Kuntrykid, TomTwo and 3 others like this.
  12. Jul 11, 2020 at 12:08 PM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    where did you get the grille?
    nvm saw the other post:thumbsup:
  13. Jul 11, 2020 at 12:20 PM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    "Got it from a dealer in Ontario, Canada that had them on sale for $100 off. Came in around $250 CAD shipped to British Columbia (across the country). There’s a lot more choices when it comes to finding OEM parts in the US so check online for the best deal! 5310004450B1 is the part number."
  14. Jul 11, 2020 at 12:41 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  15. Jul 11, 2020 at 12:48 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Think I see a Sub2K in the lineup, fun-stick!
  16. Jul 11, 2020 at 12:50 PM
    JR SLASH 33
    JR SLASH 33 Well-Known Member
    Josh
    Santa Barbara CA
    2010 Tacoma 2wd TRD Off Road
    Morel Virtus 603 3 Way Components in front JL RD900/5 5 Channel Amp in 3 Channel Bridged Mode (Front + Sub) Morel 6.5" Maximo Ultra Coax Speakers in Rear Doors JL MX280/4 4 Channel Amp in 2 Channel Bridged Mode (Rear) JL Stealthbox with 2 10" W1V3-4 Subwoofers Method Race Wheels 17x8.5" Baja Designs LED SAE Fog Lights GTR Lighting Ultra 2.0 LED Headlights
    Replaced the factory engine splash guards with the RAD splash guards from Tacomabeast.
  17. Jul 11, 2020 at 12:50 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Yessir! Its my first rifle
  18. Jul 11, 2020 at 1:00 PM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
  19. Jul 11, 2020 at 1:11 PM
    ROACHYMANG
    ROACHYMANG Active Member
    Max
    VA
    2006 White 4x4 Access Crab
    Comms are in, just waiting on mounting bracket for my Firestick...0711201531_HDR.jpg
  20. Jul 11, 2020 at 1:25 PM
    That one old guy
    Chuck
    Stockish
    Got one recently, eats any kind of cheap junk I feed it. Sure can blow thru a pile of ammo in short order tho.....:D
