  1. Jul 13, 2020 at 5:49 PM
    Fishing Grizzly
    Fishing Grizzly Well-Known Member
    Joe
    Southern Idaho
    2011 DCSB TRD OR 6 speed
    ARB Bumper URD Short Shifter Leer 100r Caliraised bed stiffeners Meso dome light Ironman stage 2 w/ constant load leafs
    93k not to bad
    yeah, been wanting one for years. Hit a deer a couple months ago and took the opportunity to upgrade.
  2. Jul 13, 2020 at 7:57 PM
    Taco-Obsessed
    That the Ebay scangauge mount? There is a thread on here about it too, but Ebay right?
    Tacos4ever15 and Willyummk like this.
  3. Jul 13, 2020 at 7:57 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Cleaned up a set of surface mounted BD squadrons. Converted to flush mount. Not looking forward to drilling more holes in the bumper but I did pick up some muscle for that the other week...
  4. Jul 13, 2020 at 7:59 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I believe it is from the same seller. He also recently came out with ultragauge mounts. I almost went ultragauge but the top of the line scangauge 2 is much more capable.
  5. Jul 13, 2020 at 9:15 PM
    Vic916Taco
    Vic916Taco Well-Known Member
    Vic
    Elk Grove, CA
    2015 White Tacoma Sport TRD Access Cab
    LED Interior Lighting, Gecko LED Bed Light, Tail Gate Pop Lock, TRD Wheels with Cooper AT3 4S 265/65/17, HID Retrofits, DD SS3, Rear seat Delete/Molle Panel Wall
    Yes, it's from a eBay seller. I got the same setup and I like the way it turned out.
    will.i.was[QUOTED] likes this.
  6. Jul 13, 2020 at 9:36 PM
    JR SLASH 33
    JR SLASH 33 Well-Known Member
    Josh
    Santa Barbara CA
    2010 Tacoma 2wd TRD Off Road
    Morel Virtus 603 3 Way Components in front JL RD900/5 5 Channel Amp in 3 Channel Bridged Mode (Front + Sub) Morel 6.5" Maximo Ultra Coax Speakers in Rear Doors JL MX280/4 4 Channel Amp in 2 Channel Bridged Mode (Rear) JL Stealthbox with 2 10" W1V3-4 Subwoofers Method Race Wheels 17x8.5" Baja Designs LED SAE Fog Lights GTR Lighting Ultra 2.0 LED Headlights
    I'm not necessarily looking for more volume from the subs, just a cleaner bass with less rattling. This totally fixed the issue I was having. I'd rather leave the back panel on, that's just what I prefer, Even if you can't see it. I'm not much of a bass head. SQ is my style
    dpele[QUOTED] likes this.
  7. Jul 13, 2020 at 9:39 PM
    Vic916Taco
    Vic
    Elk Grove, CA
    Just posting now but swapped out the nerf bars that came with my truck when I bought it with a set of Nfab step bars. I went with the 2 inch tubes and I believe I made the right choice. I also washed the truck. DSC00454.jpg DSC00458.jpg DSC00455.jpg DSC00456.jpg
  8. Jul 13, 2020 at 11:10 PM
    Spruce_bruce_offroad
    Spruce_bruce_offroad Well-Known Member
    Nick
    Colorado Springs, CO
    2012 Dark Green DCSB TRD Offroad
    315/70R17 Procomp at2 xtreme and 7069 wheels, war-fab front and rear bumpers, trailer wiring harness relocation, ATH bed stiffeners, smoked taillights and 3rd brake light, Radio shack CB w/ 2' firestik, Yotashop rear diff breather mod, RCI sliders and skids, derped grille and emblems, SMittybilt X20 10k w/ synthetic line winch
    got my exhaust rerouted today and new muffler welded on with an exhaust dump after the axle. will post pics when i have service
    Kuntrykid, Don5352 and ROACHYMANG like this.
  9. Jul 13, 2020 at 11:12 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    4F0210B5-3C3F-4B68-8F7A-CEB6E8C0DB09.jpg Got the third brake light for the Softopper installed today. Credit to @EatSleepTacos for the light/install idea. Pretty easy to be honest, hooked it up to the tail light.
  10. Jul 14, 2020 at 5:59 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I have never got an alignment after just changing wheels and tires. Only if I have altered the suspension in any way. Changing wheels and tires doesn't change your alignment settings or the geometry of how your suspension is working.
  11. Jul 14, 2020 at 6:10 AM
    TheDirtyMike
    TheDirtyMike Well-Known Member
    If you are changing wheels that have a different offset than before than an alignment is advised. I just had a set of new wheels with 0mm offset and that guys at the shop did an alignment check and said it was out of whack. I didn't get the alignment because it still drives straight and i dont have too much tread left of my tires. But supposedly changing your stance will affect alignment.
    Don5352 likes this.
  12. Jul 14, 2020 at 6:20 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Did you have an alignment done before changing your wheels also to know if you you weren't "out of whack" then too?
    Alignment is toe, camber, and caster. Changing tires and rims doesn't affect tow. It will be the same before and after. Camber might be more noticeable with wider wheels but it doesn't change the working dynamics of the suspension. Caster is only affected with suspension changes also. Scrub radius will change but that does not change the alignment.
  13. Jul 14, 2020 at 6:27 AM
    Don5352
    Don5352 Liberty or Death
    Don
    Oakland, CA
    2014 AC TRD OR
    Some really cool shit
    That looks really nice. I recently added a lot more brush scratches to my finish. Did you have much of that on yours before doing that work?
  14. Jul 14, 2020 at 6:41 AM
    Don5352
    Don
    Oakland, CA
    2014 AC TRD OR
    Did this somehow. These two are the mounting points for the aft two bolts that hold on the IFS skid plate. These are factory threaded into the crossmember that supports the LCA mounts.
    DFEDA90A-445D-4607-A20D-49A92F689ECC.jpg E467C4FF-219F-4D47-A996-C7923AB676FB.jpg
    I was taking my truck in for periodic maintenance at a local stealership. Still have one more oil change on maintenance agreement. Also, thought I had a transmission problem due to noises I was hearing, and feeling. So, removed t-case skid, and mid skid. Back two bolts on IFS skid kept spinning. Couldn't remember what version the mounts were (captive nuts or just threaded into crossmember) so asked them to look at that to see if they could remove. The above pictures reveal how they are designed. Don't know how this happened. I've bashed the front skid pretty hard a few times. Guess I hit it harder than I thought. Anyway, the idiots at the stealership had the same problem I had, and so they just cut up my skid. Without my authorization!
    Pissed. Went back to them and talked with the service manager. Now, if I can find the receipt they are going to reimburse me for the cost of the skid. Luckily I was swapping out to steel. but am forced to do it now, instead of later. IF, if I can get the mounting bolt holes repaired. Not sure how that's going to work, yet.
  15. Jul 14, 2020 at 6:48 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Who made the skid? Call them up, maybe they can help you with the invoice copy.
    Don5352[QUOTED] and whatstcp like this.
  16. Jul 14, 2020 at 6:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yikes. I've had that happen before where the nut just kept spinning. It's just a nut that's tack welded inside the frame so it must've broke free. Anyways, I used that as an excuse to go buy a sawzall and long ass blade and was able to reach in there and cut if off. For now, I've just left those two mounting points unsupported but I have to drop my skid soon anyways, so I'm going to put some rivnuts in the frame.
  17. Jul 14, 2020 at 7:31 AM
    Don5352
    Don
    Oakland, CA
    2014 AC TRD OR
    Already did that, yesterday. Still waiting to hear back.
  18. Jul 14, 2020 at 7:32 AM
    Don5352
    Don
    Oakland, CA
    2014 AC TRD OR
    In this case, it's just threaded. Well, it WAS just threaded. No backing nut. Surprised me. 2nd Gen. Really difficult to get a hand in there for a backing nut. May have to try. Gotta be a real small hand. Since mine is close to that, I can feel the hole, but it's a tight fit.
  19. Jul 14, 2020 at 8:19 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Oh yeah. I had all kinds of scratches and swirls.
  20. Jul 14, 2020 at 8:25 AM
    Vic916Taco
    Vic
    Elk Grove, CA
    I agree with you as well. I never got an alignment when I replaced my wheels and tires and they were a different offset.
