  1. Jul 14, 2020 at 8:33 AM
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    :rofl::rofl::rofl:**** LEGAL DISCLAIMER **** I AM WELL AWARE THAT WHAT I AM ABOUT TO POST IS NOT A MOD, SO PLEASE REFRAIN FROM :crapstorm: AND HUMOR ME :thumbsup:
    So, I was selected for promotion for the last time in my career, and my beautiful wife surprised me with this really cool custom made hitch receiver cover...
    TWIN SCREWS BABY!
    Cheers!
    Rick.
    winkel, Jpiskura, MurkedYota and 43 others like this.
  2. Jul 14, 2020 at 8:43 AM
    cbarham
    cbarham Well-Known Member
    Hey everyone, planning on applying noico sound deadener this afternoon on just the 4 doors for now and had a question. I got the 80 mil and the 150 mil closed cell. My question is should I apply both to the interior portion of the door panel as well as around the speaker/exterior of the door? or is it better to do 80 and 150mil inside the door and just 80 around the speaker/exterior? Any advice helps thanks!
  3. Jul 14, 2020 at 8:45 AM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Congrats on the promotion! :cheers:
  4. Jul 14, 2020 at 9:41 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    From the threads I have read through 80 on the interior of the door 150 on the area where the speaker mounts. At least that is what I plan to do this weekend.
  5. Jul 14, 2020 at 9:47 AM
    cbarham
    Thanks, I guess it doesn't matter too much how you do it. I might do 80 and 150 inside and 80 where the speaker mounts. I think the 150 is supposed to insulate from heat/cold as well so it seems like it would work best inside the door but maybe I'm wrong.
  6. Jul 14, 2020 at 9:55 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Congrats! Taco looks great too!
  7. Jul 14, 2020 at 10:05 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Insulation works best if its not directly against the heat source or the item directly in contact with the heat source. The heat coming off the outer door panel has to heat the air between the panel and the insulation then has to heat the insulation then the heat has to transfer through the insulation into the cabin then the cabin will start to heat up. If you can make it harder for the sun to heat metal then air from the metal then insulation from the metal and the air THEN the cab.
    Its the same concept as a cooler, Ice stays inside because the sun can heat the outside plastic all it wants. That outside plastic then has to transfer heat into the air space between the outer and inner plastic. Then the inner plastic has to heat up before the ice starts to see a temp rise.
  8. Jul 14, 2020 at 10:08 AM
    cbarham
    That's a good point, I'm still undecided haha found this on Noico's website. https://noico.info/articles/how-to-do-a-complete-sound-deadening/
    Then we take the ruler to measure the interior part of the door, cut the template in the material based on these dimensions. Then, having removed the protective layer from the material, stick it to the interior part of the door. After that, level it in place and roll it down elaborately, to remove all bubbles from under the piece of material. It is special embossing on the foil that lets us see where the material is rolled down well and where not.
    We heavily recommend you to make sure the whole sheet is rolled down properly
    To build in the second layer, we have to degrease the first one again and then stick Noico Green 4mm (170mil) on it. This heat and sound insulation layer should be applied without any openings or gaps between sheets, in order to preclude the possibility of sound intrusion and ensure as high heat insulation as possible.
    Then we cover the exterior metal surface of the door with the sound deadening material. Stick down all the apertures, including those narrow designed for wires and door lock arms. This layer should be carefully rolled down as well.
    GonzoQuick likes this.
  9. Jul 14, 2020 at 10:31 AM
    NavyDiver72
    Rick
    Millington, TN
    Thank you @Rick_Taco !
  10. Jul 14, 2020 at 10:35 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Congratulations:cheers:
  11. Jul 14, 2020 at 10:55 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Maint Reqd light came on so fresh oil and filter was fed to my beast.
    Kuntrykid likes this.
  12. Jul 14, 2020 at 11:25 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Out of curiosity, does anyone know the weight specs that our door hinges are capable of handling?
    I imagine it's more than our door currently weighs (there has to be some safety margin built in), but probably not much more. Is there a shear rating or similar, for the hinges, that I simply can't find?
  13. Jul 14, 2020 at 11:53 AM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    i feel like we need a post (maybe sticky) dedicated to aggregate the options and what peoples experiences are with the sound deadening process
    i say this as im in the market to do the my doors, haha. Double Cab, ive already upgraded the speakers think i should go the extra mile now and get the most out of it.
  14. Jul 14, 2020 at 12:08 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    fill in the blank here with whatever topic you like.
    That's the problem/blessing with this thread. It's full of tons of vital amazing info on EVERYTHING that we do here. such that if you miss a day you miss 120 posts on a variety of cool stuff...then a month later when you want to review that discussion on XXXXX you can't find it.
    Just whining really. I'm addicted.
  15. Jul 14, 2020 at 12:09 PM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    If I don't go back and catch up with the posts after not being on for a few days I'm always afraid of missing something epic. It is an addiction!
  16. Jul 14, 2020 at 12:11 PM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    I think for the most part I was finding a thread here and there, google searching most of it there wasnt a real good sticky I could find where people really talked about it. Lots of threads of people asking the square footage they needed.
  17. Jul 14, 2020 at 12:11 PM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
  18. Jul 14, 2020 at 12:11 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Added some GOAT Armor. If the truck wasn't wild before, it certainly is now. :D
    winkel, MurkedYota, siundon and 19 others like this.
  19. Jul 14, 2020 at 12:18 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
  20. Jul 14, 2020 at 12:25 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
